39,456 Members 1,489,922 Posts
Help....Ive got a wet CAI!!!
This is a discussion on Help....Ive got a wet CAI!!! within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi I fitted my CAI about 4 or 5 months ago and its been fine, and still is. I have ...
Old 06-01-2007, 13:29   #1
888
888's Avatar
Members Car: 2002 Octavia vRS
Exclamation Help....Ive got a wet CAI!!!
Hi
I fitted my CAI about 4 or 5 months ago and its been fine, and still is. I have drilled some holes in the right grill in the front bumper to let me air in.
However ive just got in from a 50 mile drive in the pouring rain on the A12, loads of spray coming up from the other cars.
So i took the right hand grill off from my bumber to have a look at the filter, cos i thought it might be wet behind there, and it was dripping I couldnt get my hand fully round the filter to check, but it was very wet!!
How bad is this for the car? Should i put the standard one back on?
The car still drives as normal, i havent noticed any difference, im just concerned about how wet it is.
Thanks
G
888 is offline
Old 06-01-2007, 13:38   #2
Liverpool-Lad's Avatar
Members Car: Octavia vRS
Re: Help....Ive got a wet CAI!!!
Is the filter down in that part of the bumper?!
2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!
Smiles all 'round
Liverpool-Lad is offline
Old 06-01-2007, 14:13   #3
BRISKODA Staff
SkodiRS's Avatar
Members Car:
Probably not doing your fitler much good but, the main concern is how much water is getting into the engine as this is what'll do damage.
As it's spray probably not enough but don't go wading through any puddles that reach up over the heigth of the filter.
Adrian.
SkodiRS is offline
Old 06-01-2007, 14:48   #4
888
888's Avatar
yeah the filter is that low, if you take the cover off, there is the horn there, well i think its the horn , behind that is the filter. It is wet there and thats what i am worried about, getting water in the engine.....
There are no puddles deep enough around here to go through, so thats not a problem. Im just concerned about the spray making the filter wet, surely the oil on the filter cannot keep all the water out?
888 is offline
Old 06-01-2007, 15:15   #5
Id get the filter further up into the bay then and perhaps get a cold air feed there instead of a soggy filter which isnt doing much good at all.
Smiles all 'round
Old 06-01-2007, 17:56   #6
stevenh's Avatar
I would be wary of running a CAI with a behind the bumper filter at this time of year - just in case you get hydro lock - better to keep these for the summer and run a standard setup when it gets wet.
stevenh is offline
Old 06-01-2007, 19:20   #7
888
888's Avatar
cool, thanks for the advise guys, i will take it off and save it for the summer, thats if its a dry one!!! i dont want to risk the engine
888 is offline
Old 06-01-2007, 20:35   #8
Wayne Kerr's Avatar
Just plug the "silly holes" you've drilled up!
Why ,,,,,,,,,,,,,,,,,,,,,,,, you drilled the holes, I dunno. Advise from a know-it-all?
Always ask here first
Deli G ,,,, leader of the Peckham Massif!
KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted.
Was that a 4x4 Skoda??? It's IMPOSSIBLE!
197.2 BHP & 263.1Nm
Wayne Kerr is offline
Old 06-01-2007, 20:57   #9
Om nom nom nom
Neo_VR's Avatar
Members Car: A White Car
the only way you would wreck an engine with water is if the air intake became FULLY submerged in water..
youll be fine... if anything the water should make it faster
ColGod the UberMod
,___,
[O.o]
/)__)
-"--"- ORLY??
Neo_VR is offline
Old 06-01-2007, 21:17   #10
Briskodaholic
Tom_vRS's Avatar
Members Car: '97R BMW 328i Saloon
Yep, I thought the problem with water would be that the extreme temperature difference between cold water and hot engine components that could cause terminal damage... I wouldnt lose too much sleep about it
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 06-01-2007, 21:51   #11
888
888's Avatar
yep, i was advised to drill the holes as it would get enough air otherwise, i didnt know either way so i drilled the holes!! oh well.
888 is offline
Old 06-01-2007, 21:56   #12
Members Car: Octavia vRS 1.8T
Ahem.... whats a CAI
I'm not totally dence, I gather its some kind of after market air filter, but pretty please, just for me, what is it?
Danimal is offline
Old 06-01-2007, 22:59   #13
888
888's Avatar
Cold Air Induction, basically its a cone filter on the end of a long metal pipe, on mine, this places the filter behind the front bumper to get more cold air.
888 is offline
Old 06-01-2007, 23:06   #14
BRISKODA Staff
SkodiRS's Avatar
Members Car:
I thought it was hydrolock....basically trying to compress something which can only be compressed by so much...or something like that.
...and that's as I said before...the fitler would have to be submerged in water.
I had a cold air fed for the lower grill to the CAI...which was situated in place of the standard airbox using the standard ai intake path.
Adrian.
SkodiRS is offline
Old 06-01-2007, 23:08   #15
Ahh yes, with you now. It that a K&N jobby? do you find yuo get any sort of performace upgrade with tah, or is it purely a noise thing?
Danimal is offline
Old 07-01-2007, 12:49   #16
Cupra Bush King
Lummox's Avatar
Images: 2
Spot on. Just think the engine has a capacity of 1.8 litres. One cylinder is therfore is 450cc. Thats less than half a litre which aint alot of water. The air intake from an engine is basically a big vacuum cleaner, it takes a suprising little amount of water to actually knacker an engine.
Hit a fair sized puddle and what happens? You get a bow wave infront of the car, this level raises up higher than the level of the water, and on a car with low air intakes its bad news.
Changed god knows how many engines due to hydrolock, usually the water cant be compressed it bust a con rod or at the very least twists the crankshaft.
www.unit18.co.uk
Lummox is offline
Old 08-01-2007, 12:42   #17
888
888's Avatar
so i the majority vote to take the filter off and wait for dryer weather?
888 is offline
Old 08-01-2007, 13:25   #18
Id find a better position for it, it neednt be on the floor and still give good performance.
Smiles all 'round
