This is a discussion on Help needed within the Octavia I forums, part of the Skoda Model Discussion Area category; Does anyone have any idea if you change an engine would the faults still be there in the old engine ...
| Briskodian | Help needed Does anyone have any idea if you change an engine would the faults still be there in the old engine still be there when you start the new engine. I had an engine that blocked the pick up pipe resulting in the the top end seizing before it did this the oil pressure light came on and then when the engine stopped the engine management light came on but i have now finished putting in the new engine and its running like a dream, BUT i have the samelights on oil and engine lights, would these still be from the previous problem? would i have to go back to the dealer to have these switched off! Any ideas??? Cheers |
| Briskodian Join Date: Oct 2007 Location: Buckinghamshire
Members Car: Skoda Octavia VRS 2002 Thanks: 34
| Re: Help needed I believe you need to clear the faults as they are stored in the ECU.
__________________ Upper & Lower S3 Strut braces-Forge FMDV006 DV-PiperX panel filter-Whiteline adjustable rear arb-Superpro Dogbone, Control arm & Front ARB bushes-LCR Splitter-Milotec Grilles-Golf MK4 Aero wipers-KVW100-Cruise Control-Parking Sensors-18" RS8 Alloys-N75H-Revo Stage 1-TO DO: Turbo back exhaust-Koni FSD and H&R springs (5 Days to go)-Seat & Door Card Leather retrim and a respray. ![]() |
| Help needed | Boxfrog | Diagnostics & VAG-COM | 6 | 06-08-2006 11:25 |
| Help Needed | skodayouth | Fabia I | 0 | 29-05-2006 19:25 |
| PC Help needed | CORDY_SXMAN | The Tech Shed | 12 | 17-10-2005 21:38 |
| Help Needed | funkyjutel | Maintenance & Performance | 10 | 27-01-2005 00:03 |
