This is a discussion on Help! Octavia 2.0 coil confusion within the Octavia I forums, part of the Skoda Model Discussion Area category; Classic error... changed the coil on my 2000 octy 2.0 and now have no idea where the ignition leads go. ...
| Briskodian | Help! Octavia 2.0 coil confusion Classic error... changed the coil on my 2000 octy 2.0 and now have no idea where the ignition leads go. What an idiot! Can anyone help? Please! I'm in a bit of a pickle! Si |
| Re: Help! Octavia 2.0 coil confusion They are numbered if you look closely. |
| Briskodian | Re: Help! Octavia 2.0 coil confusion I've seen that the coil is lettered A - D, how does this relate to the cylinders? Am I right to assume that the cylinder to the far left of the engine (looking from the front) is A, and that the one to the right is B, etc. |
| Re: Help! Octavia 2.0 coil confusion Give it a go, what ya got to loose? |
| Briskodian | Re: Help! Octavia 2.0 coil confusion I thought that I would get some closure on this for anyone else in my boat! Using the image below, and all directions are taken from the front of the car.. Coil: Top right = Far left cylinder Coil: Bottom right = Far right cylinder Coil: Bottom Left = Middle right cylinder Coil: Top right = Middle left cylinder ![]() |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: Help! Octavia 2.0 coil confusion According to Haynes, for engines with a single distributorless ignition system (DIS) coil, lead A is for No 1 cylinder, lead B is for No 2 etc. No 1 cylinder is at the timing belt end of the engine.
