39,456 Members 1,489,922 Posts
Help please... Engine starts and shuts down
This is a discussion on Help please... Engine starts and shuts down within the Octavia I forums, part of the Skoda Model Discussion Area category; Disclaimer: Not sure if this is the right forum or not, the Octavia I and II thing confused me a ...
Old 01-05-2008, 16:35   #1
emp
Members Car:
Disclaimer: Not sure if this is the right forum or not, the Octavia I and II thing confused me a bit, I'm sorry if it isn't.
Hi there... please help me with this if you can, I have a real problem with my Skoda Octavia 2002 (ambiente?), I took it a few days ago to a place where I could get my hood fixed (it was a little bent, the damage was minor and the car was working perfectly fine), they told me that the first day the car worked great, but the second day it wouldn't turn on. They told me they didn't do anything out of the ordinary.
We tried jumping the car to start because we thought it might have been a dead battery, but the car does start but within seconds (1-3 seconds perhaps) it shuts itself down and you can see a blinking yellow car with a key icon saying "Service" below that. We called the local skoda dealer and they told us that the keys/car need reprogramming, however we have to take it down there.
Before I call a tow truck for this, I was reading the car manual and it says in the event of something like this happening then there's an emergency override method by turning the clock knob to the right, then pressing another button/knob down and I'll get on my display four "0" with the first one blinking for me to enter a 4 digit code, however I'm unable to this trick done, can anyone explain me how this is done?
emp is offline
Old 01-05-2008, 16:51   #2
ECUless
fordfan's Avatar
Members Car:
Re: Help please... Engine starts and shuts down
That's the immobiliser cutting in. It is not recognising the signal from the key, can you try another key in it? The manual will tell you the number entry procedure but you will need the secret key code for your car.
fordfan is offline
Old 01-05-2008, 17:01   #3
emp
Members Car:
Yes thank you for answering, I tried both keys and both are giving me problems, I do have the 4 digit code right now, and I tried following the procedure stated in the manual, but I wasn't able to get it working. Could you explain me that procedure maybe?
emp is offline
Old 01-05-2008, 17:09   #4
Briskoda Staff
auroan's Avatar
I've never heard of being able to enter the skc like this. New one on me.
'05 Audi A4 2.0 Tdi SE - no mods until the warrenty expires ... yeah right... interior light pack, 3 spoke mfsw.
'00 Audi A4 2.8 Quattro - Gone.... (bleeding money pit )
Audi A4 2.6 Avant (Breaking - Check out http://shop.ebay.co.uk/merchant/auroan)
auroan is offline
Old 01-05-2008, 17:21   #5
emp
Members Car:
For all I know I could be doing everything wrong, do you know of any other alternate methods I could try?
emp is offline
Old 02-05-2008, 12:32   #6
KenONeill's Avatar
Members Car: Octavia TDi110
You're in the right forum mate.
I've no idea how to solve your problem, but IMO the garage who were working on the hood are responsible for resolving the issue at their expense because it happened whilst the car was in their care.
KenONeill is offline
Old 02-05-2008, 15:14   #7
Members Car:
Talking Re: Help please... Engine starts and shuts down
I was with EMP when we went to pick up the Octavia at the shop. What when wrong at the shop, who knows !!! Maybe they tried to start the car with a different key by mistake. We solved the problem by disconnecting the car battery for about 1 hour and reconnecting it after the hour. Result: OK...the computer or immobiliser reset itself and the car starts as it should, now. We are using the car now to see if the problem arises again.
Still, the question remains unanswered. The manual states a procedure to bypass the immobiliser by inserting the 4-digit code (which we have) and after that the car will start normally within 45 minutes. Future starts would have to continue to use the procedure until the car keys are reprogrammed at the dealer. During the problem event, we could not get to the 4-digit display on the speedometer to display. Have anyone know exactly how to perform the bypass procedure. I am driving the car now and probably will go to the dealer to find out what's the problem.
Cybergrizzly is offline
Old 02-05-2008, 15:26   #8
Briskoda Staff
auroan's Avatar
What page in the manual is the procedure on ?
auroan is offline
Old 02-05-2008, 15:30   #9
cheezemonkhai's Avatar
Members Car:
Daft Question but have you tried replacing Relay 109.
It's totally random, but if the car isn't getting the right power distribution then the immobiliser might go nuts and shut down.
Worth a shot I'd say, but can't be any more help
cheezemonkhai is offline
Old 02-05-2008, 15:34   #10
DGW
BRISKODA Staff
DGW's Avatar
It might help too to have the car scanned for fault codes, eg with VAG-COM, to see if any relevant ones have been logged. In the meantime the procedure in the Owner's Manual for using the 4-digit code is the only one available, ie there is no alternative bypass method.
Denis
DGW is offline
Similar Threads
How do you clean your door shuts? The Ors Styling and Car Care 4 19-06-2007 20:27
Engine starts, after not pushing the fuel pedal it goes off coredumped Octavia I 0 24-04-2006 23:36
Brisk starts? MC Bodge Octavia I 14 13-01-2006 11:07
A Beer Before It Starts scrutineer Off Topic and Chit Chat 2 23-04-2004 16:30
OK....it starts now... Kentish Off Topic and Chit Chat 8 08-12-2003 00:25
