39,456 Members 1,489,922 Posts
Help Please flat spots & rough power delivery
This is a discussion on Help Please flat spots & rough power delivery within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi all, My 1.8T AGU engine has developed a random flat spot & poor idling usually after I have pushed ...
Old 13-05-2008, 10:49   #1
Land_Raver's Avatar
Members Car: Octavia L&K Turbo
Hi all,
My 1.8T AGU engine has developed a random flat spot & poor idling usually after I have pushed the car heavily on the turbo for a few miles. This usually clears when the engine is cooler?
Have fixed the air leak on the Secondary Air Pump casing, replaced the spark plugs, replaced the boost valve & replaced the coolant temperature sensor which has eliminated most of the poor running.
The car has been re-mapped (unknown map) & is running 200HP (Rolling road dyno) with no engine management lights on. Engine has covered 60K with full service history.
Was wondering if it was the air flow meter or air temperature sensor that was at fault & if it was then why there is no fault code?
Any help or suggestions would be greatly appreciated!
225 BHP L&K Q-CAR
Land_Raver is offline
Old 13-05-2008, 11:47   #2
KenONeill's Avatar
Members Car: Octavia TDi110
Re: Help Please flat spots & rough power delivery
Has this been more of an issue in the last week or 2? If so, then I think you've got a fuel temperature problem.
Easy test for the MAF is to disconnect it. If the engine runs better with the MAF disconnected, then replace the MAF.
KenONeill is offline
Old 13-05-2008, 12:16   #3
Land_Raver's Avatar
Thanks
The fault has been more so the last couple of weeks although has been like it for a while. Will try disconnecting the MAF.
Surely though the engine will not run with MAF disconnected??
225 BHP L&K Q-CAR
Old 13-05-2008, 13:09   #4
KenONeill's Avatar
If it's got bad signals from the MAF, it tries to use them, and runs badly. When you disconnect the MAF it uses a set of default settings.
Old 13-05-2008, 13:44   #5
Land_Raver's Avatar
Will try that out on the way home from work
225 BHP L&K Q-CAR
Old 14-05-2008, 09:25   #6
Land_Raver's Avatar
Many Thanks for the info Ken, the car runs better with the MAF disconnected although will clear the codes for ASR & Engine management (as the check lights are now on) Will get a brand new MAF.
Top Bloke
225 BHP L&K Q-CAR
Old 19-05-2008, 11:09   #7
Land_Raver's Avatar
Have replaced the MAF with a replacement one from a Skoda Dealer £20 surcharge on old unit so guess thate these are reconditioned. The Parts man said that faults with these are common across the whole VAG range.
Engine ran really badly on initial installation coughing sluttering & backfiring with no base idle Revved the engine throuhout the rev range 1K for a few seconds then 2K up to 5K then it was fine. Guess that the Engine Management system has to learn & recalibrate when a new MAF is fitted!
Things are great again
Many thanks again Ken for your advice also Briskoda & everone that uses it what a great resource
225 BHP L&K Q-CAR
Old 19-05-2008, 11:20   #8
Lloyd55vrs's Avatar
Members Car: Octavia VRS
dam mafs, ive heard they break all the time whenever they feel like it
Lloyd55vrs is offline
Old 19-05-2008, 11:34   #9
Land_Raver's Avatar
Yes completely random my last car was a 97 A3 1.8T sport AGU engine 43K & had no Engine management faults in the 3 years I owned it!
225 BHP L&K Q-CAR
Old 21-05-2008, 21:11   #10
Members Car:
being a bit dim here which is the maf sensor on the 18 T
vrscoz is offline
Old 22-05-2008, 04:30   #11
Not anymore
Taxi 219's Avatar
Members Car: Octavia TDi 2006
The MAF sensor is immediately after the air filter housing and has a multi plug on it.
Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver
Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red
Paul
I only live for GTA IV
Taxi 219 is offline
Similar Threads
Rough-ish idle and flat spots (1500-3500rpm) on Felicia 1.3mpi petrol sporegan Favorit, Felicia, Fun and Forman 3 10-03-2008 22:21
flat spots with performance filter smstext Octavia II 12 05-02-2008 18:56
Loss of Power / Flat Spots 110 TDi securespark Octavia I 31 15-12-2007 21:19
flat spots harryhill Favorit, Felicia, Fun and Forman 3 01-08-2007 09:21
flat spots and black smoke george_lungu Octavia I 0 03-02-2007 22:51
