This is a discussion on hissing noise from vRS under acceleration within the Octavia I forums, part of the Skoda Model Discussion Area category; I'm posting this having read a number of threads from owners that reported strange sounds from their turbos, but none ...
| Briskodian Join Date: Feb 2007 Location: Hampshire
Members Car: Black Octavia vRS Mk1 Thanks: 0
| hissing noise from vRS under acceleration I'm posting this having read a number of threads from owners that reported strange sounds from their turbos, but none quite answered my query. I've only had my 56,000 mile 54 reg vRS for a few weeks - have covered 1000 miles in it. I'm used to the whoosh/whistle of the turbocharger, but last week I started getting a very loud hissing sound under acceleration. It completely drowns out the whoosh/whistle. It sounds like it's coming from outside the driver's door, or maybe somewhere down in the driver's footwell. Performance doesn't seem quite as brisk either, with noticeable stutter sometimes when releasing the throttle after acceleration. Any ideas? Tks |
Members Car: Octavia 2001, 110TDi Elegance estate Thanks: 0
| Re: hissing noise from vRS under acceleration split hose somewhere I guess? As I have TDi i would not really be able to advise where to look - apart from somewhere near to the turbo maybe :-) |
| Re: hissing noise from vRS under acceleration Sounds like the back turbo hose may have popped out. |
| Briskodian Join Date: Feb 2006 Location: Stafford
Members Car: Black Octavia 02 Vrs Thanks: 1
| Re: hissing noise from vRS under acceleration same problem on my 02 vrs turned out to be two split hoses, not sure what for, but apparently a common issue, one S-shaped hose and one twin hose junction thingy at the top of the engine |
| Briskodian | Re: hissing noise from vRS under acceleration I came on here tonight to post the axact same problem. Could someone point out exactly were we should be looking? ie turbo location? Sorry, I`m a complte novice when it comes to these cars ![]() |
| Midnight Mod! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
Members Car: 2004 Octavia vRS Estate Images: 1 Thanks: 155
| Re: hissing noise from vRS under acceleration The turbo's at the back of the engine in the centre I have a replacement TIP (the blue pipe) but it's basically the same. The turbo is on the other end of that pipe! Check all of the hoses which join onto that pipe at each end for a start - I once had the wiggly pipe to the left of the photo pop off under hard acceleration (my fault, jubilee clip not fully tightened) Hope this helps!
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
| Briskodian | Re: hissing noise from vRS under acceleration If you look in the driver's side wheel arch you will see a flat metal pipe that runs from the intercooler to the turbo. Get under the car, remove the covers and have a look at the top end of this pipe. There is a large rubber hose that is attached with a jubilee clip. Thats another place to check. |
| Re: hissing noise from vRS under acceleration Thanks for all the advice guys. I'm taking mine into Willis Skoda, South Ruislip next week. Will report back. |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: hissing noise from vRS under acceleration Thanks for that photo rob Im expecting a TIP next month and was wondering where the exact location was |
| | #10 | |
| Re: hissing noise from vRS under acceleration Quote:
No worries ![]() There's a couple more pics here
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook | |
| | #11 |
| Re: hissing noise from vRS under acceleration Did you do it yourself Rob? If you did any fitting guidelines as ive herd that they are a total pig to do unless you get under the car |
| | #12 |
| Re: hissing noise from vRS under acceleration Mine took me about four hours to fit - it was an absolute pig. I had the car on axle stands to get underneath. Getting the lower end onto the turbo inlet is the hard part. When I'd finished I still wasn't sure it was on properly. I've had no problems with it though. It might help to get a mate to help too - I was on my own, kept having to jump under the car and out again. it would have been much easier to have someone angling the top bit while I pushed the bottom end onto the turbo. Good luck ![]()
| | #13 |
| Re: hissing noise from vRS under acceleration Ahh thats ok then as ive got a mate who owes me a favour after i helped him with a manifold on his 106 GTI ![]() |
| | #14 |
| Re: hissing noise from vRS under acceleration Got it fixed - hose had popped out due to crocodile clip not being tightened up correctly. Thanks for the help. |
| | #15 |
Members Car: Octavia 1.8T 4X4 Estate & Fabia vRS Thanks: 51
| Re: hissing noise from vRS under acceleration Glad to hear it is fixed. Which hose was it?
| | #16 |
| Re: hissing noise from vRS under acceleration To be honest I didn't ask - just glad to get it back to normal! |
