This is a discussion on Home test ? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi All, I was wondering if anyone knows of a home test that can be done to check to see ...
| Briskodian | Home test ? Hi All, I was wondering if anyone knows of a home test that can be done to check to see if an Octy MK1 has been remapped ? We're lucky enough to own two vRS's; a 2003 AUQ and a 2001 AUQ. But the 01 car has more grunt, has more pick up in 5th (e.g. going up hills) and better fuel economy (according to the MFA). Both engines appear to be stock, the '03 is defintley stock but we have questioned if the '01 has been remapped or is it just worn in better? The 03 has done 42K, and the 01 has done 78K miles. Any advice would be welcome, thanks in advance.
__________________ Octavia vRS 2003, Silver, K&N and new style RS4 feet. & Octavia vRS 2001, Black, nice. |
| Light Jockey! Join Date: Jul 2006 Location: Somerset, UK
Members Car: Skoda Octavia vRS Mk1 Thanks: 2
| Re: Home test ? You'd really need to get a vag com lead etc and do a boost log to be sure I guess? ![]() I presume a cheapy ebay one would probably do the job for you if you didn't want to spend full whack money on a legit (although you'll obviously get better support and software with the latest official )See my boost log here for an example of what standard is (confirmed today on a dyno too )Attachment 17458 That would tell you for sure how much boost each car is running - if remapped then one will be significantly higher than the other! (10psi is stock!)
__________________ Regards, Matt ________________________________________________ Assumption is the mother of all foul ups Now proud owner of a Kawasaki ER-6F too! Last edited by LJ_Matt; 17-12-2007 at 13:47. |
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Octavia vRS Thanks: 12
| Re: Home test ? The difference between mine was like night and day, so either it is genuinely in better fettle or something has been tinkered with but not that well?
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Briskodian Join Date: Jun 2006 Location: Melksham
Members Car: vRS Thanks: 3
| Re: Home test ? Yes, I'd agree, a remap makes such a marked difference that it should be pretty obvious side-by-side if that is the case. If it's just a "noticeable" difference then I'd say it's likely to be some other variation unless it's a poor remap. Maybe the slower one is actually sub-standard compared to the other? Either way, a Vagcom log of boost value should answer the question. |
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
Members Car: octavia VRS Thanks: 54
| Re: Home test ? can you read the boost with a restricted vag-com download? I thought you would need the official cable to be able to do that?
__________________ Regards Martin Turbo back blueflame exhaust Last edited by martziniuk; 27-10-2007 at 10:40. |
| Briskodian | Re: Home test ? If you let me know what part of the country your from i will be happy to take a read from the ECU and compare this to a standard map if it helps at all. |
| TEST THE DEALER Screen wash test!!!! | r.carder | Octavia I | 16 | 21-06-2006 17:39 |
| Test Drive Hot Hatch Group Test | micromyth | Octavia II | 0 | 01-04-2006 10:30 |
| KE went home | fredw | Photography and Photoshop | 0 | 26-06-2005 21:44 |
| Leaving home / coming home | Higgy | Octavia II | 4 | 03-06-2005 15:15 |
| Anyone else just got home | mannyo | Off Topic and Chit Chat | 28 | 29-01-2004 16:36 |
