This is a discussion on how about afan behind OE intercooler? within the Octavia I forums, part of the Skoda Model Discussion Area category; hi i have noticed the dis advantages using the front mounted intercooler in various forums why not try a fan ...
| Briskodian | how about afan behind OE intercooler? hi i have noticed the dis advantages using the front mounted intercooler in various forums why not try a fan behind the existing OE INTER COOLER? WILL IT BE OF ANY HELP? can we explore pros& cons |
Members Car: 4x4 turbo estate Thanks: 17
| Re: how about afan behind OE intercooler? it would no difference at speed only at idle as a fan probably couldn't maove more air than your car doing 50mph+ what disadvantage of the FMIC are you thinking of?
Members Car: Fabia 2.0/Felicia Thanks: 48
| Re: how about afan behind OE intercooler? as allready said above it's probably not necessary to have an interccoler fan..... unless you are doing hillclimb rallying or towing a caravan a lot. |
| Briskodian | Re: how about afan behind OE intercooler? I assume you're sighting the cost of the FMIC as the problem? |
