This is a discussion on How fast with a 6 speed box?? within the Octavia I forums, part of the Skoda Model Discussion Area category; What sort of speeds would I be getting in each gear if i had the 02M TT or Cupra R ...
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Members Car: 345bhp Silver Octavia vRS Thanks: 48
| How fast with a 6 speed box?? What sort of speeds would I be getting in each gear if i had the 02M TT or Cupra R box in my car? RPM limiter is set at 7400rpm. Any advice is welcome Steve ![]()
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() |
Members Car: Skoda Fabia Mongrel Images: 5 Thanks: 75
| Re: How fast with a 6 speed box?? I believe Des has this box, and if I remember right, he could do 180mph without the WRC wing on.
__________________ Jason - Only a Skoda. Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Re: How fast with a 6 speed box?? Speeds would be the same as the Cupra R then in theory. Might have some luck looking for the gear ratios of the box on SCN. |
| | #4 | |
| Re: How fast with a 6 speed box?? Quote:
Any idea what it could do in each gear??
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() | |
| Re: How fast with a 6 speed box?? Hmmm, unsure. I don't even know if he had that box. It went roughly along the lines of (estimate) 1st = 50mph 2nd = 80mph 3rd = 110mph 4th = 140mph 5th = 160mph 6th = 180mph (+?)
| | #6 | |
| Briskodian Join Date: May 2005 Location: belfast
Members Car: skoda octavia tdi 130 bhp [170] Thanks: 98
__________________ when i die, bury me upside down so the world can kiss my a.s.s "I spent all my money on cars, booze and women - the rest I just wasted" - George Best. I was so poor growing up...If I wasn't born a boy..I'd have nothing to play with. -Rodney Dangerfield | |
| | #7 | |
I've heard a lot of people saying you can't get much more than 60 in 2nd with the 02M TT/Quattro or Cupra R box.... Confused now.... ![]()
| Briskodian | Re: How fast with a 6 speed box?? That sounds very much like a diesel box. DaveU said he got 150 in fourth if you remember. |
| Briskodian Join Date: Jan 2003 Location: Winchester
| Re: How fast with a 6 speed box?? Not sure of gear speeds on the TT box as my cars still in bits so I cant check it. Top Ive had out of mine with a wing is 170 on Tom Tom & it was still just creeping (speedo needle was in the trip window) The big plus is the ratios which are very evenly spaced, its not 5 gears & an overdrive like some boxes
__________________ Speed is an addiction for which thankfully there is no cure |
| | #10 |
| Re: How fast with a 6 speed box?? I agree, the figures that jason posted look like those of a diesel six speed box. I thought that the six speed box 02m box would just have shorter ratios through all the gears to give better accelleration, but 6th gear would be more like your current 5th. This is what my old Boxster was like, 6th gear in that was the same as 5th in the 5 speed box.
| | #11 |
| Briskodian Join Date: Mar 2006 Location: Camberley
Members Car: Octavia VRS Thanks: 0
| Re: How fast with a 6 speed box?? Thats right, I was up at Jabba yesterday talking to Micheal about the 6 speed. The 6th gear is the same as a 02J's 5th!! |
| | #12 |
| Re: How fast with a 6 speed box?? How did my car look, Ive almost forgotten what it looks like its been there so long, not Jabbas fault I will add !!
| | #13 | |
Leon Cupra R speeds.... 1st = 35ish 2nd = 60ish 3rd = 85ish 4th = 105ish 5th = 130ish 6th = 160ish I'll pass on that gearbox...... I'd be changing gears very 2-3 seconds!!!! Standard Octavia vRS [mk.i] gearbox (limiter set @ 7000rpm) 1st = 43mph 2nd = 74mph 3rd = 109mph 4th = 140mph 5th = 160mph (+) Diesel gearbox ratios..... (Speeds might be a touch higher due to my limiter being set @ 7400rpm..?) 1st = 50mph 2nd = 80mph 3rd = 110mph 4th = 140mph 5th = 160mph 6th = 180mph (+?) I can't see much wrong with those ratios. My IHI give such a good spread of torque from around 3k up to 7+k so it should pull like b!tch regardless of the slightly longer ratios. I much prefer the longer gears anyway, and the triple shaft 6 speed box should be able to cope with any amount of torque/bhp I’m ever likely to want to put through it, plus the cruising 6th gear would just be a bonus, 90/100mph @ 3k in 6th can't be a bad thing. Steve ![]()
| | #14 | |
| Briskodian Join Date: Jun 2004 Location: West Yorkshire
Members Car: Audi S8 Thanks: 41
Also if the diesel gearbox you are looking at is the same as in our ibiza then from a couple of the gears I know 7400rpm in 4th would be 185mph and in 6th would be 296mph. 90mph in 6th is more like 2krpm in the Ibiza.
__________________ EddyH Audi A6 Avant 2.7 TDI Audi A3 2.0 TDI Sport | |
| | #15 | |
| Briskodian | Re: How fast with a 6 speed box?? Quote:
90mph is 2k rpm? What engine you got, the 6 speeds I have seen tend to do 70@2k RPM, which would be more like 260ish mph in 6th.
__________________ Cars make CO2 and trees absorb CO2. By driving your car you're feeding a tree and helping the environment. | |
| | #16 |
| Re: How fast with a 6 speed box?? It's a 130PD with the longer gears like the early Fabia vRS. Anything below 90mph and 6th is useless as even for cruising 5th is more economical as the revs are just too low in 6th.
| | #17 |
| BRISKODA Staff | Re: How fast with a 6 speed box?? I had the limiter raised to 7.4k and easily hit 80mph in 2nd gear...with the standard 5 speed box. The 6 speed is essentially the saem with a very short 1st gear....6th...as already has been said is the same as 5th in the standard box. What you do get is a stronger box. I preferred the longer gearing of the 5 speed.....I'd imagine there'd be a lot of changing with the 6-speed.
__________________ Adrian. Last edited by SkodiRS; 01-05-2007 at 13:25. |
| | #18 | |
Are they still getting your KW's seviced?? | |
| | #19 | |
Hopefully I will have it back in about 2 weeks I hope someone gets a piccy of it on the stock springs, must look slightly odd
__________________ Speed is an addiction for which thankfully there is no cure | |
| | #20 |
| Re: How fast with a 6 speed box?? Does anyone know if the diesel and petrol 02M gearbox are physically the same?
| | #21 |
| Briskodian Join Date: Jan 2007 Location: Oxfordshire
Members Car: Unmodified Octavia vRS Thanks: 1
| Re: How fast with a 6 speed box?? Isn't it just a case of mathematics or has science been replaced with my dads bigger than yours? ![]()
__________________ If I ever feel like getting fit, I lay down and wait for the feeling to pass over. Sud Sprint preserved in fibreglass! |
| | #22 |
| Briskodian | Re: How fast with a 6 speed box?? i have a vrs mk1 im looking at puttin 6 speed in it wot box do i look for ??? |
