39,456 Members 1,489,929 Posts
How long before air-con re-gas?
This is a discussion on How long before air-con re-gas? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, My 5-year old RS was recently in to the dealer as the climatronic was not blowing any cold air. ...
Old 08-08-2006, 14:10   #1
Members Car: Octavia vRS
Hi,
My 5-year old RS was recently in to the dealer as the climatronic was not blowing any cold air. Turned out that there was little or no pressure in the system, so after refilling with new refrigerant everything is now back to normal.
Is 5 years about average for needing the air-con system re-gassed? Or should it have lasted longer?
The dealer also said something which didn't sound quite right to me (quoting as accurately as I can): "Oh, it's normal for the gas to get used up by running the air-conditioning. We've had customers who run their air-con all the time use up all their gas in only 2 years".
It's a pressurised, sealed system. The gas shouldn't get "used up", unless my understanding is way off. The gas will gradually leak out (I've seen leakages rates quoted of around 10% per year), and not using the car or the air-con may cause premature leakage as the refrigerant carries the lubricating oil to the compressor seals. But to claim that normal usage should "use up" your refrigerant sounds quite wacky - especially from a (supposedly) reputable franchised Skoda dealer...
David.
ginandtonic is offline
Old 08-08-2006, 14:13   #2
Broom Broom!
Mort's Avatar
Members Car: Fabia vRS (red '03)
Re: How long before air-con re-gas?
My dealer has a little notice in a frame saying "Did you know" apparently after one year the air-con can be 85% effective and after two can be 60% effective.
Not quite fantastic advertising for Skoda, but I suppose effective for their £85 air-con servicing service.
I think mine needs doing and thats hitting 3 years with minimal air-con use.
Fabia v/RS, in Red.
Green filter & Cupra Intake, TT brakes, Josh's Sumpguard, Jabba ARB, MOMO strut brace, Powdercoated alloys. KW v1's next...
Mort is offline
Old 08-08-2006, 14:15   #3
ScoobyChris's Avatar
Members Car: Fiat Panda
The air con specialists I've used usually recommend every 3 years if it's used continuously, or more frequently if it's only switched on occasionally. I don't know whether that's to keep them in business or if it's genuinely required. My Mondeo is just over 4 years old and the air con is still uncomfortably cold
Chris
ScoobyChris is offline
Old 08-08-2006, 14:16   #4
That's because the less you use it, the more likely leaks are to develop through lack of the lubricating oil being circulated. Probably not such a big deal on the Fabia as the air con is always on, but worth bearing in mind
Chris
Old 08-08-2006, 14:19   #5
Broom Broom!
Mort's Avatar
Chris
I find I use it lots when its hot and not a lot when it's cold. Due to the whole summer/winter thing that makes half a year of not much use
Fabia v/RS, in Red.
Mort is offline
Old 08-08-2006, 16:44   #6
Members Car: 1.6 slx octy
i rang the main skoda dealer in my area where i bought my tavia and asked about a re-gas. they said they would'nt have anything to do with the air-con system and it was a job for a specialist.typical irish service.
spiggotpaddy is offline
Old 08-08-2006, 16:54   #7
DGW
BRISKODA Staff
DGW's Avatar
I had mine done after 4 1/4 years. The system had lost around 25% of the refrigerant gas in that period.
Denis
DGW is offline
Old 08-08-2006, 17:39   #8
Cuthbert Dibble
gillywibble's Avatar
I tend to use mine just as much in the winter because air circulation prevents the screen misting up.
I drink, therefore I spam.
gillywibble is offline
Old 08-08-2006, 18:05   #9
SUTTS's Avatar
I had mine done today at the dealer at (strangely) precisely three years old to the day. I guess I hadn't noticed that it was becoming gradually less effective over time until it failed completely on Saturday.
Cost for a re-gas, clean, filter change and check (it wasn't leaking) was £88. Now it's like walking into a freezer on 'LO'.
Ian.
'03 Octavia v/RS.
Jabba remap etc
'03 Octavia L&K PD130 Estate.
SUTTS is offline
Old 08-08-2006, 18:14   #10
I parked up 1st
ric04vrs's Avatar
Members Car: silver Fabia VRS
my fabia VRS lost approx 200grams of gas (should be 550g)over a 28 month period , so the figures quoted by the stealer of 60% effective after 2 years sound about right
not so bored now
ric04vrs is offline
Old 08-08-2006, 19:49   #11
musky's Avatar
Members Car: MK1 Octavia 4x4
has anybody tried one of these diy aircon refill kits from Halfrauds. Not sure if they are suitable but may try one on wifes Xsara (should cause a serious loss even if it doesn't work!)
musky is offline
Old 08-08-2006, 19:58   #12
Keeps the car cool in the summer, dries out the moisture in the car in the winter. I use mine all year round
Chris
Old 08-08-2006, 20:43   #13
who...?
AndyC's Avatar
Members Car:
Mines now over 7 years old and is still working, just. It blows cool air now rather than cold and wasn't that much use in the recent hot weather. Time for a regas.
AndyC
1999 Octavia 1.6 GLXi. Oldest one owner Octy on the forum.
2007 07 Fabia 2 1.2 in Silver. Briskoda's first new Fabia.
AndyC is offline
Old 09-08-2006, 13:51   #14
KenONeill's Avatar
Members Car: Octavia TDi110
Chris
Exactly so. I've even managed to persuade my mum to use the air in her Sickbrick in winter to stop it steaming up.
KenONeill is offline
Old 09-08-2006, 22:25   #15
DisturbedMonkey
Quetz VRS's Avatar
Location: In a mental home, whacked out on happy pills talking backwards with Einstein :D
as with all things in life depends how much you use it
I have a contact that is a mobile unit, comes to you and charges £50, for me... maybe more for reg customers But worth all checking around for a independant or non-dealer garage, you could save the extra cost the dealer charges to ensure they have that pretty carpet on the floor....lol
Q
PS:- I arranges it for a friends motor, as my felicia has natures air-con (i.e WINDOWS...lol)
Insanity is not an illness.... it's a way of life !!
Quetz VRS is offline
Old 10-08-2006, 09:49   #16
MC Bodge's Avatar
Mine has lost a bit of gas, I reckon, although it was still adequate in the recent HOT weather.
Mk1 Octavia vRS. The thinking man's Hot Hatch.
PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close
MC Bodge is offline
Old 10-08-2006, 12:58   #17
cheezemonkhai's Avatar
Members Car:
I had mine regassed recently, but that was only because they don't do just an anti-bacterail flush out, and i was feeling really ill after being in the car with the a/c on.
It's a bit cooler, but i think the system was fine before hand apart from the bugs.
cheezemonkhai is offline
