39,456 Members 1,489,938 Posts
How much air? (Tire pressures)
This is a discussion on How much air? (Tire pressures) within the Octavia I forums, part of the Skoda Model Discussion Area category; Wandering if anyone can enlighten me.... Standard oct vrs runs a 205/50/17 and something like 2.1 bar front 2.3 rears... ...
Old 16-11-2004, 17:12   #1
Anton_g's Avatar
Members Car: silver octavia vrs
So seeing as i have 225/45/17 how much should i be filling them with?
Asked skoda they said go away non standard tire size!! Help i don't want to kill tires that cost me 90quid a corner!!
The consensus is that forward is better
Anton_g is offline
Old 16-11-2004, 17:16   #2
DGW
BRISKODA Staff
DGW's Avatar
Use the recommended pressures for starters. (There is no 'book' answer.)
Denis
DGW is offline
Old 16-11-2004, 17:22   #3
If the tyre wall is the same size, and the wheels are the same size, then i would assume you should use the same pressure.
After all the tyres are carrying the same loading.
There is quite a bit of variance between half load, full load, winter and summer pressures anyway, so sorry to say but - Near enough is good enough!
JD
Octy Elegance TDI (110bhp)
cmcm789 is offline
Old 16-11-2004, 17:37   #4
fully boyced.
boyced's Avatar
Members Car: Octavia vRS
I was planning on checking my tyre preasure at the weekend. Are the pressure gauages in bar aswell as psi?
boyced is offline
Old 16-11-2004, 17:51   #5
The one i use at sainsburys is switchable from Bar to PSI. I think the inside of the fuel cap only gives Bar if im correct.
JD
cmcm789 is offline
Old 16-11-2004, 17:52   #6
fully boyced.
boyced's Avatar
JD
Yes you are!
boyced is offline
Old 16-11-2004, 20:23   #7
K44 ENT's Avatar
You could try this....
Tyre pressures change as temperature changes. I know this sounds sad but I have a chart listing what pressure the tyres have in dependant on ambient temperatures (providing the car has not recently been driven). Usually run mine at 32psi all round at 5 deg c, increasing by 1psi for every 5 deg c increase in temperature. Seems to work fine , maybe a bit of a firm ride but handles well. Have not noticed any uneven wear etc. This is only my opinion though
Red Octavia vRS
SOLD...Still got the TVR
K44 ENT is offline
Old 16-11-2004, 22:48   #8
CHRIS ELLIS's Avatar
Members Car: Octavia Vrs MK11
225/45/17s 31psi front 30psi rear thats what i'm told
CHRIS ELLIS is offline
Old 16-11-2004, 22:55   #9
Carsten's Avatar
Members Car: Octavia 1.9TDi
I run mine with roundabout 32psi to 33psi ....
They did about 8.000miles and they show
no unusual wearout .
But now they hilbernate in the cellar
Carsten is offline
Old 16-11-2004, 22:56   #10
i had to have 2.6 bar front, 2.4 bar rear, anything lower and i would get uneven wear. Mind you this was in winter -5 to 10 C. This was with 225/45 17". I have noticed that the TDI's are real heavy in front makeing the suspension go real low (TDI engine + sump guard + driver). The rear seems like it has no weight at all.
Christian
inquirer is offline
Old 17-11-2004, 09:10   #11
Anton
Us caravan tuggers have the same problem with older caravans because the information is often not available:
One of the specialist mags said that:
"In the absence of advice from the caravan or trailer manufacturer, consult Michelin quoting the exact tyre dimensions, (including the Load index) and giving the actual axle load being carried by these tyres,"
You know the weight of the car and the other information is on the tyres. give it a go. in this case Mitchellin were very helpful
Bomber is offline
Old 17-11-2004, 10:57   #12
Freakcrab's Avatar
Members Car: 2001 Octavia RS
JD
Odd. Mine only shows pressures in KPa.
2001 Rally Red RS
Cthulhu dreams on my parcel shelf, not in R'lyeh.
Freakcrab is offline
Old 17-11-2004, 13:39   #13
owlets's Avatar
So does mine! Does enyone know how to convert from KPa to Bar/PSI as I've never found a machine that has KPa on it. I tend to put in 30 PSI for front and 31 for back but would love to know what I'm supposed to run std tires at
owlets is offline
Old 17-11-2004, 14:33   #14
fully boyced.
boyced's Avatar
google calculator! 1 kiloPascal = 0.145037738 pounds per square inch
http://www.google.co.uk/search?hl=en...e+Search&meta=
boyced is offline
Old 17-11-2004, 14:49   #15
Nigel26's Avatar
32psi in all of em, as recommended by my mate at national tyres... he knows his beans as well.
Sea Grey Mondeo Titanium X
Nigel26 is offline
Similar Threads
Introduction to the NEW Octavia ColinD Octavia II 2 22-02-2007 20:09
Ebay Again Mavrik General Car Chat 67 19-09-2004 19:06
Fabia 1.4 MPI Air Intake and EGR or ?!? Akebono Maintenance & Performance 4 16-09-2004 13:20
New Octavia In Detail ColinD General Car Chat 0 22-04-2004 12:18
