This is a discussion on How wide is a vRS alloy? (17") within the Octavia I forums, part of the Skoda Model Discussion Area category; Is it 7" or 7.5" as a friend thinks the rim should be 7.5" at least ideally to take the ...
| Briskodian Join Date: Aug 2006 Location: Liverpool
Members Car: Octavia vRS Thanks: 12
| How wide is a vRS alloy? (17") Is it 7" or 7.5" as a friend thinks the rim should be 7.5" at least ideally to take the 225/45 tyres. Cheers
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| Re: How wide is a vRS alloy? (17") Almost sure it is 17x7J |
| Briskodian Join Date: Mar 2006 Location: Liverpool
Members Car: Furby vRS Thanks: 148
| Re: How wide is a vRS alloy? (17") As far as I am aware they are 7x17". Most people put 215/40/17's on them but I'm using 205/40/17's. I'm pretty sure 225/45's will be a bit too wide for them?
__________________ FURBY VRS: cruise, xenons, ESP, heated seats, Revo, Eibachs, Koni FSDs, PD160 pipe, Jabba rear arb, Allard EGR pipe, EGR totally removed, Powertec induction kit, Milltek full system, Garrett GT17, Forge FMIC, 17" Octy wheels, debadged, side strips removed, Seat Cupra splitter, 312mm brakes... ICE: Alpine 9835, Alpine changer, Alpine X-Type sub, Alpine MRDM1000 & MRFV340 amps, Alpine Remote Amp Controller, Boston Acoustics Pro60.... NEXT: re-remap & clutch |
| Re: How wide is a vRS alloy? (17") Hello there fellow scouser ![]() It seems a lot of the peeps use the 225s but it seems like the rim is slightly too narrow??
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
Members Car: Toyota Auris SR180 Images: 3 Thanks: 50
| Re: How wide is a vRS alloy? (17") 225/45/17's fit the standard Octy vRS wheels with no problem at all. |
| Re: How wide is a vRS alloy? (17") Just checking as Demon Tweeks think the wheels should be at least 7.5" wide at least.
| Re: How wide is a vRS alloy? (17") If you join Freedom and use the calculator, you will see it is well within tolerances, and does also not upset the speedo reading. I and many others on here have them fitted without a problem. |
| | #8 | |
| Worthless loser Join Date: Jan 2005 Location: Nowhere of interest to anybody
Members Car: Unimportant Thanks: 0
| Re: How wide is a vRS alloy? (17") Quote:
![]() I am running 225/45/17s on my Octy with no problems at all, 225s are a damn sight cheaper than the 205s fitted as standard as well
__________________ David 2002 Black Magic Octavia V/RS | |
| Re: How wide is a vRS alloy? (17") I know, I was sold, but my mate put the wind up me by saying that!
| | #10 | |
Do the bolts up tight as................... "Careless torque costs lives"... ![]() | |
| | #11 |
| Re: How wide is a vRS alloy? (17") Haha, nice one.
| | #12 |
| Re: How wide is a vRS alloy? (17") What did you expect at this time of night ??? Dave,(DRM_JONES)... your pm box is full up? |
| | #13 |
| Re: How wide is a vRS alloy? (17") And, Toyo T1-R or F1's?
| | #14 |
| Re: How wide is a vRS alloy? (17") Toyo T1-rs, bit noisier than the standard ones, but hard wearing and very grippy. I also have them on my 18"s. |
| | #15 | |
__________________ FURBY VRS: cruise, xenons, ESP, heated seats, Revo, Eibachs, Koni FSDs, PD160 pipe, Jabba rear arb, Allard EGR pipe, EGR totally removed, Powertec induction kit, Milltek full system, Garrett GT17, Forge FMIC, 17" Octy wheels, debadged, side strips removed, Seat Cupra splitter, 312mm brakes... ICE: Alpine 9835, Alpine changer, Alpine X-Type sub, Alpine MRDM1000 & MRFV340 amps, Alpine Remote Amp Controller, Boston Acoustics Pro60.... NEXT: re-remap & clutch | |
| | #16 |
| Re: How wide is a vRS alloy? (17") This is posted in the Octavia section........... What else can you expect from a squirrel?........... ![]() |
| | #17 |
| Re: How wide is a vRS alloy? (17") I'm a Squirrelinie-rat actually ![]()
| | #18 |
| Briskodian Join Date: Oct 2006
Members Car: 02 Octavia 1.9 SDI Classic Thanks: 1
| Re: How wide is a vRS alloy? (17") May I just suggest that 225 is at the upper limit for a 7" wide rim.
__________________ OctaviaBuzz - '02 Octavia 1.9SDi Current Status: 83k miles, currently averaging 51.5mpg |
