39,456 Members 1,489,928 Posts
i have a mouse in my dashboard!!!!
This is a discussion on i have a mouse in my dashboard!!!! within the Octavia I forums, part of the Skoda Model Discussion Area category; seriously though, i have a knocking sound coming from the passenger side dashboard on my 52 octy vRS. i thought ...
Old 10-11-2005, 10:30   #1
Daddy2Coull's Avatar
Members Car: 2002 silver Octy vRS
seriously though, i have a knocking sound coming from the passenger side dashboard on my 52 octy vRS. i thought at first it may be the aircon but it still makes the sound with all fans etc switched off!!!! can anybody shed any light on this, even if its just to tell me it's supposed to be like that!!!
adam
Daddy2Coull is offline
Old 10-11-2005, 10:46   #2
Same noise on our L&K 1.9 Tdi.
Ours has only started in the last 3 weeks, car has done over 90000 miles so its not meant to do it
I thought like you & turned all the fans off but it still does it even when the cars stationary on idle, only does it when the cars properly warmed up though
Likewise any ideas apreciated
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Old 10-11-2005, 11:30   #3
bk1
bk1's Avatar
Have you checked it's not something in the glovebox or the door pocket? I know it sounds daft but it could be worth checking.
bk1 is offline
Old 10-11-2005, 11:36   #4
i have tried
i have totally emptied the whole car incase it was vibration traveling but it isn't. i've only had the car 2 weeks and there is only 10 day skoda warranty left so i'm keen to get it sorted quickly!!!!
adam
Old 10-11-2005, 12:46   #5
Members Car:
Is it a heavy knocking sound or a light vibration?
Rest your thumb on the hand brake button - that is a common vibration that can develop and sound like it is coming from somewhere else.
Goochie is offline
Old 10-11-2005, 12:50   #6
really?
i'll go try it now!!!!
Old 10-11-2005, 12:50   #7
Ours is definately a knocking sound & it does it even when the car is stationary, its intermittent, can be the odd knock, can be 2 or 3 close together. Its definately somewhere behind the Glove box side of the dash. Unfortunately you cant here anything under the bonnet as it will be drowned out by the Engine noise
It dosent sound like a relay as I believe that would be more of a click, I wondered if its an air lock somewhere, could be air bubbling through water type of noise.
I tried all the aircon settings the other day & the cold definately didnt seem as cold, is that a clue ??
Stuart_J is offline
Old 10-11-2005, 12:56   #8
Just had Charcoal filter suggested, any thoughts ??
Stuart_J is offline
Old 10-11-2005, 13:01   #9
charcoal filter?
just been out to try mine, its not the hand brake lever. it's the same as yours, coming from behind the glovebox. it seems to be doing whilst i'm driving along too. its counds like an airlock like knocking central heating pipes but knowing me i'm totally wrong lol. maybe someone while come along in a while and shed some more light!!!!
adam
Old 10-11-2005, 13:02   #10
air con
asfor the air con it still makes the noise when its totally switched off so i doubt it!!
adam
Old 10-11-2005, 13:21   #11
any takers?
any one shed anymore light?
Old 10-11-2005, 13:32   #12
Will try and get ours to the dealers over the weekend for a comunal listen
Stuart_J is offline
Old 10-11-2005, 13:35   #13
Members Car:
When I first collected my car (2nd hand) it had a vibration that sounded like the exhaust was touching something, I took it to Skoda who spent 2 days looking for it but couldnt find anything wrong - they could hear it too but diddnt charge me as they couldn't fix it. Engine noise while the car is running does make it very difficult to find, even on a petrol car
On the way home I noticed it had gone, its never come back. Not very helpful to you I know but; If your car is under warranty I suggest you book it in at the dealer quickly, if the problem occurs in the warranty period they *should* be happy to cover any further work to resolve it even after the warranty has expired.
Goochie is offline
Old 10-11-2005, 14:38   #14
yaktrebor's Avatar
Location: Bakewell, Derbyshire, where the puddings come from. (That's tarts to foreigners!)
Members Car:
It's the Climatronic!
I recently replaced my VW Passat with an excellent Octavia Estate.
About 1 year ago, I had a very similar noise.
It started as a slight tapping behind the glove box. Over time this increase to a very loud banging. My normal VW agent were unable to find anything wrong !!!!! However, by chance I was at a different agent one day and asked them to have a look. The VAG COM told them the the fresh air/air recirculation flap (behind the glovebox) needed resetting. They tried to do this, but the motor/encoder were not working properly. The service manager said this would require the whole dashboard to be removed!!! about 8 hours labour!!!?? He then went on to say that, this was not the first one he had seen. The cheapest solution, he told me, was to unplug the electrical connector from this motor. to do this, remove the glovebox assembly (not as many screws as you would think), climb into the passenger footwell, stretch your hand behind the glovebox to find the motor, pull off electrical connector.
Before you do this, ensure that the flap is set to fresh (outside) air, as the only way to chage its position once you have removed the power lead, is to reach behind the glovebox, up inside the ducting and move the flap manually.
yaktrebor is offline
Old 10-11-2005, 14:43   #15
oh dear
in that case i think i better get it back to the dealer as i still have ten days warranty left!!!!! hopefully it will be covered!!!
Old 10-11-2005, 17:42   #16
more info
i've also decided that the noise is turning into a nightmare. on top of the knocking it's also making a whirring or water rushing kind of noise, i cant really make up my mind which. this is crazing me. does anyone else have any ideas?
adam
Old 10-11-2005, 22:14   #17
Members Car:
The water rushing noise could be air in the system which, could indicate a leaking heater matrix. Though cars do normally get a small ammount of air in the system over time. My car is a 51 plate with 7ok miles on it and makes a slight rushing/watery sound from the heating system, it is very quiet and only noticable when stationary without the radio on.
I know how frustrating strange noises are - once you notice it you can hear it even when passengers dont know what you're complaining about.
Goochie is offline
Old 10-11-2005, 22:36   #18
yaktrebor's Avatar
Members Car:
Climatronic
Try pressing the 'outside air' / 'air recirculation' button.
If for a breif few (blissful) seconds, everything goes quiet, then it is deffo the motor / encoder on this flap.
The best thing I ever did to my previous car, was to disconnect the power lead to this particular motor!
'No more beer!' (unless it's GF)
Old 10-11-2005, 23:41   #19
plumsoul's Avatar
Members Car: Octavia VRS
I've got that hand brake button rattle! Took me 18 months to figure out that's what it was. Tried taping round it but made it worse. Does anyone know how to cure it?
cheers
derek
Derek
plumsoul is offline
Old 12-11-2005, 13:54   #20
Wendy took ours to the dealers today, sounds like the same problem, dash out, days labour. I will get it done as I prefer aircon to work properly, you get max cold with recirculation on but all other times I want fresh airaircon working properly
Stuart_J is offline
Old 12-11-2005, 20:28   #21
buggered
thanks for all the replies folks, but the octy vRS was stolen friday morning, the very day i had it booked in for the local dealer to look at it!!!!!
adam
Old 13-11-2005, 11:24   #22
Really sorry to hear it.
Hope you dont mind the Joke
Was it a cat Burglar after the Mouse
Stuart_J is offline
Old 13-11-2005, 11:45   #23
lol
hi stuart,
no i don't mind the joke. it did make me smile. just keep hold the remaining key hoping a genie will pop out out and looking at the empty space on the drive where my pride and joy once sat gleaming away in the november sun!!!!
adam
Old 13-11-2005, 12:24   #24
Stuart_J is offline
Old 14-11-2005, 10:57   #25
bk1
bk1's Avatar
What a bummer. At least the squeak went away. (ahem)
bk1 is offline
Similar Threads
New trim noise: the sides of the dashboard Akebono Fabia I 12 21-12-2005 11:00
Re-Calibrate you mouse monkeychild Off Topic and Chit Chat 4 12-10-2005 17:44
Theres a mouse loose in this hoose!! vRS_Si Off Topic and Chit Chat 20 11-10-2005 09:40
Mouse pointer drifting in SP2 ventmore The Tech Shed 19 30-01-2005 22:21
Mouse Balls TaviaRS Off Topic and Chit Chat 0 13-06-2003 11:25
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
