39,456 Members 1,489,938 Posts
IAT Timing Sensor
This is a discussion on IAT Timing Sensor within the Octavia I forums, part of the Skoda Model Discussion Area category; Do those IAT timing sensors really work. I am considering one for my Octy VRS? I would appreciate some advice, ...
Old 14-01-2008, 19:12   #1
Members Car: Octavia 1 vRS
Question IAT Timing Sensor
I would appreciate some advice, plus how do they really work?
johnstonep is offline
Old 14-01-2008, 19:56   #2
Why So Serious
fatty5000's Avatar
Members Car: a car
Re: IAT Timing Sensor
What are they ????
fatty5000 is offline
Old 14-01-2008, 21:25   #3
Apparently they are a resistive load that you connect between the air temp sensor and the connector lead. I have basically read that it fools the ECU into thinking that the air is too cold and therefore advances the timing. It is supposed to give a max increase of 20bhp plus more torque.
Old 14-01-2008, 21:33   #4
Need more power
martziniuk's Avatar
Members Car: octavia VRS
Isn't too much timing advance bad for the car and if the car is remapped the timing would already be advanced to a sensible limit wouldn't it?
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve, Ramair filter, Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is offline
Old 14-01-2008, 21:42   #5
I`ve no idea. My VRS is standard. As far as I know they are tried and tested.
Old 14-01-2008, 22:29   #6
Why So Serious
fatty5000's Avatar
Members Car: a car
It's bollox don't bother unless you want higher fuel bills and possibly and knackered engine.
Out of interest how much are they looking to charge for this thing
Old 14-01-2008, 22:34   #7
A fiver. Go onto ebay and put in skoda octavia in the general search and they are in there with other items.
Old 14-01-2008, 22:46   #8
Why So Serious
fatty5000's Avatar
Members Car: a car
I was gonna say the resistor can be bought for 10p.
Really don't bother they are basically bollox
I'm sure someone can explain better than me but they will tell you the same thing
Old 14-01-2008, 22:50   #9
Why So Serious
fatty5000's Avatar
Members Car: a car
I found this by searching " resistor mod"on this site
This is doing the rounds and some people are getting conned by it but I haven't seen any mention of it here so sorry if it's a scooby in a lake. This was cut from the Integrale forum
Here it is the full info on the mod that people keep buying I got the details off Ebay so for anyone who is sad enough to try it can do so and not get ripped off!
**PERFORMANCE +20BHP TO YOUR ENGINE FOR FREE. This is no joke All the adverts on ebay that state they sell performance chip that boost your cars performane are actully a 4.7k resistor that can be bought in any electrical component shop. This is causing uproar and Im getting alot of stick for publishing this info coz they want you to pay them £5 for a 10p resistor. Not bad for a days work.
Why I'm I giving this info for free? Because I think it is a total rip off so I want to expose it and show you how to boost your cars proformance for the cost of a resistor.
But beware as it dosn't work on all cars
This has caused major uproar with ebayers who are cashing in on the resistor for a fiver. They say your paying for the info
but here is is for free
IAT Timing Sensor Modification
Approximate 5-15 minutes installation time, Please read completely before installing. If in doubt please refer to your Haynes manual to locate you IAT sensor.
Purchase a 4.7k resistor from a electrical componant shop. and a couple of cable ties
Instructions:
1. Turn off engine and remove key from ignition, you may also want to disconnect the negative battery terminal, some ECU's may still detect changes even with the key removed and a check engine light may come on.
2. Locate Ait Intake Temperature (IAT) Sensor. The Sensor will be located in between the air intake box and the throttle body. If you cannot locate the sensor consult a mechanic, your dealer or owners manuel for assistance. Do not confuse the IAT with the 02 or mass air sensor. The IAT circuit is a 5 volt circuit if you wish to test with a voltmeter to locate it. In all case of uncertainty, we recommend either contacting your manufacture or a mechanic for assistance in locating the IAT sensor.
3. After you have located the IAT sensor, disconnect the wire harness from the IAT sensor. Gently pull the tab out and lift the plug from the sensor housing.
4. Take your 4.7k resistor and shape it into a U and place the metal receptacles on the resistor into the sensor plug. Push receptacles as far as they go. The resistor will get deformed and probably appear squashed this is OK and not a problem.
5. Make sure the IAT sensor plug and MOD is tied secure within the engine compartment with a cable tie. + protected from water.
After installation make sure everything is secure and double check your installation. You should feel the extra power almost immediately. But as with all performance accessories use at your own risk. By using this MOD you accept all responsibility.
Just to clarify what the mod actualy does it fools the ECU into thinking the air the engine is breathing in is cold and dense so it thinks the engine will need more fuel (thats where the power gains come from) so in winter you will have little gain because the air is already cold, in the summer you will gain to the point where the engine is not getting enough air for the fuel going in.
Another area of uncertanty is where they got the valye for the resistor as all "IAT (inlet air temperature) sensors" will be different as in the resistance ranges they operate to you can find these details in most Haynes manuals e.g. Renault Clio multi-point injection the sensor reads from 9.72Kohms (coldest) to 1.47Kohms (hottest).
If you do want to perform this mod do some research first and if you know someone interested in buying one show them this first
Print this off put it on a notice board some where just lets stop people buying the rip off mod!!!
The Following User Says Thank You to fatty5000 For This Useful Post:
johnstonep (14-01-2008)
Old 14-01-2008, 22:54   #10
Why So Serious
fatty5000's Avatar
Members Car: a car
http://www.briskoda.net/forums/maint...mod-5-a/83761/
BRISKODA - The Skoda Forum and Community
Do you get my point now
Hope this helps
Old 15-01-2008, 01:15   #11
richm's Avatar
Members Car: vRS
seriously - 3 words...
NO
NO
NO
load of cobblers
richm is offline
The Following User Says Thank You to richm For This Useful Post:
johnstonep (15-01-2008)
Similar Threads
17563 - Manifold Pressure Sensor (G71): Short to Plus, new sensor???? greg123 Octavia I 1 15-10-2007 16:57
IAT (intake air temperature) pippobj Fabia I 13 20-02-2007 19:45
Resistance of lambda probe (Help with o2 sensor / oxygen sensor part II) bigad Diagnostics & VAG-COM 5 16-12-2006 16:17
1.3 GLi filicia IAT?!?!? joew633 Favorit, Felicia, Fun and Forman 1 14-09-2006 23:07
IAT sensor channy86 Fabia I 7 24-11-2004 00:42
