39,456 Members 1,489,933 Posts
If in doubt; clean your throttle body!
This is a discussion on If in doubt; clean your throttle body! within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi guys, Just a quick post to say that, if, like me, you have been wondering if this is worth ...
Old 10-06-2007, 08:00   #1
FocusZtec's Avatar
Hi guys,
Just a quick post to say that, if, like me, you have been wondering if this is worth doing - DO IT!
With the help and advice of a good friend with vagcom; last night we gave my throttle body a good clean out and recalibrated it using vagcom (my battery has been disconnected a couple of times recently). The whole job took less than 30 mins and the difference in smoothness and sharpness to the pedal action is very noticeable. (even though it is dbw)
Lee
http://img.photobucket.com/albums/v610/FocusZtec/neiloctypipersignature.jpg
Thanks to JKM:
REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!!
FocusZtec is offline
Old 10-06-2007, 10:48   #2
Txt Spk Police
VRStu's Avatar
Members Car: Audi S3
Re: If in doubt; clean your throttle body!
It certainly is something well worth doing, a lot of people scoff and turn their nose up when mentioned though.
Stu
VRStu is offline
Old 10-06-2007, 11:12   #3
VRSPhil's Avatar
Members Car: Passat Sport TDi
I did mine earlier in the year, it cured my rough idle I was surprised when the dealer told me he had not had to order a gasket in for nearly two years previously SURELY they must use them daily in a Skoda dealer? He looked at me like I had just pi55ed on his kids when I asked for one
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 10-06-2007, 11:17   #4
FocusZtec's Avatar
Being honest I think I was one of them hence my post really. Very surprising result. (...maybe I should cancel the vrs order now?!)
Lee
Thanks to JKM:
Old 10-06-2007, 11:22   #5
Liverpool-Lad's Avatar
Members Car: Octavia vRS
Is there any way to keep the throttle body on and clean it by opening the throttle flap rather than disassembling it? I have no issues, but hey, it can never be too clean, right?
2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!
Smiles all 'round
Liverpool-Lad is offline
Old 10-06-2007, 11:43   #6
VRSPhil's Avatar
I wouldn't leave it on - you risk getting dirt into the inlet manifold which wouldn't be fun. It's only 4 6mm allen-bolts and a couple of clips to remove anyway. Gasket is about £2 IIRC.
VRSPhil is offline
Old 10-06-2007, 19:06   #7
funkymonkey's Avatar
Members Car: octy vrs blk
how did you go about cleaning it and what did you use
drive it like you stole it
funkymonkey is offline
Old 10-06-2007, 19:42   #8
FocusZtec's Avatar
One pipe off, four allen bolts out to access it. Cloth and carb cleaner on the inside - holding the butterfly open to get in as far as possible from each side. Re install and then a re calibration with vagcom. Job done.
Lee
Thanks to JKM:
Old 10-06-2007, 21:49   #9
I dont have VAGCOM, thats the problem
I think Ill leave it, dont want to throw a spanner in the works.
Smiles all 'round
Old 11-06-2007, 07:25   #10
Hardcore
Basil's Avatar
Members Car: Fabia vRS
whats the recalibration procedure mate?
will do this after summer is past (no fun working outside in 45 deg and nearly 100% humidity......)
Cheers
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 11-06-2007, 09:29   #11
mluton's Avatar
Throttle Body Alignment
Turn the key on but do not start the car.
01 - Engine]
[Measuring Blocks - 08]
Group 060 (may be Group 098 on cable-throttle cars)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds, then press the [Switch to measuring blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Red Skoda Octavia V//RS
mluton is offline
Old 15-06-2007, 11:08   #12
Dr. Octavia's Avatar
Members Car: Octavia 1.8t 4x4
I really think this will solve your 17705 issue. It did on mine. Well worth doing, it's actually surprisingly easy to do.
Dr. Octavia is offline
