39,456 Members 1,489,933 Posts
Ignition key light flashing
This is a discussion on Ignition key light flashing within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi folks, An intermittent problem has started on my '99 octaviia TDI. Sometimes when I go to start the car, ...
Old 10-12-2004, 07:09   #1
Members Car:
Hi folks,
Sometimes when I go to start the car, all lights come on OK pre start, except for the ignition key light, which flashes. If I then try to start the car, engine turns then dies.
It's not a key problem I think as I'm now running with the spare key, and the fault still happens.
Any suggestions please?
TBXP.
trailblazerxp is offline
Old 10-12-2004, 08:49   #2
DGW
BRISKODA Staff
DGW's Avatar
Does the engine sometimes cut for no reason while you are driving, or is the problem only there on starting?
Denis
DGW is offline
Old 10-12-2004, 09:13   #3
Kentish's Avatar
Members Car: 4 wheels, 4 doors.
Fuel pump relay or similar? (or is it relay 109)
Sounds like the common VW problem
Andy
Owner of a sense of humour.
Kentish is offline
Old 10-12-2004, 16:57   #4
Members Car:
It's not relay 109. This was changed some time back after an entertaining "stop" on a busy (3 lane) bridge, during rush hour, with no breakdown lane. Hooboy that was fun...... . And the key light didn't flash when 109 was faulty.... .
No this happens before starting - turn the key so that all lights are on and the ignition key symbol flashes. Not all the time thank goodness, but I'd like to find out what it could be before it goes permanent.
If the light remains solid, I can start the car and run it until I switch it back off. Then it's a lottery as to if the fault will show again.
Old 10-12-2004, 17:05   #5
Cupra Bush King
Lummox's Avatar
Images: 2
More than likely the immobilizer loom.
There is a mooded one for Octavia, they made them too tight at the factory and when you pull the steering wheel back/up down on the adjuster it tends to pull the plug out of the reader coil thats around the barrel, this would be my first port of call, after that poss a fault with the reader coil itself.
www.unit18.co.uk
Lummox is offline
Old 10-12-2004, 19:24   #6
dbs
There is a known fault on the reader coil had mine replaced on my last car cost about £80. Its worth geting it done as sooner or later you wont be able to start the car at all.
dbs is offline
Old 10-12-2004, 19:52   #7
Members Car:
Was that 80 pounds for supply and fit of the coil reader, or just for the part only?
I'll have a look for this at the weekend, anybody know where exactly on the steering column it's located?
Thanks
TBXP.
Old 10-12-2004, 20:33   #8
Cupra Bush King
Lummox's Avatar
Images: 2
The reader coil is a black plastic ring that is part of the barrell itself.
www.unit18.co.uk
Lummox is offline
Old 10-12-2004, 20:48   #9
adaadams's Avatar
Members Car: skoda Octavia ll VRS
i agree with ross. replace the loom. if you have vag com fault code should be somthing like poor signal from key. if no joy next step reader coil
ADE
adaadams is offline
Old 11-12-2004, 06:55   #10
Members Car:
Thanks everybody, given me a starting point to go from. Don't have VAG-COM sadly, anybody in Glasgow with one?
Similar Threads
How mant forum members does it take to change a light bulb? roo Off Topic and Chit Chat 15 21-06-2005 20:46
Flashing Glow Plug Light andy ellis Maintenance & Performance 24 10-12-2004 19:00
Glow plug light flashing P R Oban Fabia I 1 16-08-2004 22:49
Engine warning light on, Ignition coils? vRS_Si Maintenance & Performance 22 12-02-2004 10:38
How Many Forum Members Does It Take To Change A Light Bulb? Tavia4x4 Off Topic and Chit Chat 15 30-10-2003 17:09
