This is a discussion on ignition wiring for turbo timer within the Octavia I forums, part of the Skoda Model Discussion Area category; hi all can anyone please help. i have been trying to wire this in all evening but had not luck. ...
| Briskodian | ignition wiring for turbo timer hi all can anyone please help. i have been trying to wire this in all evening but had not luck. can any one let me know which wire is the12v permant, 12v ignition(key on)and acc or ign2. cheers all lee |
| Re: ignition wiring for turbo timer Will your turbo timer work with the transponder immobilizer? If you take the key away the signal will be lost. |
| Briskodian | Re: ignition wiring for turbo timer had not thought about that but it did work on my t reg mk4 golf so it should work on this am i correct |
| | #5 | |
| Re: ignition wiring for turbo timer Quote:
And yes it will fit the same as a MK4 Golf. Look for a term 15 connection, that is ignition live. | |
| Briskodian | Re: ignition wiring for turbo timer thanks all all wired up and working now |
| ignition wiring help | adrian36 | Favorit, Felicia, Fun and Forman | 5 | 14-06-2007 15:50 |
| turbo timer | scousemouse291 | Maintenance & Performance | 17 | 30-01-2007 19:44 |
| Turbo Timer Help! | rana77 | Octavia II | 3 | 11-07-2006 18:22 |
| ignition wiring | bengie | Maintenance & Performance | 6 | 06-01-2005 16:34 |
| Have any of you has install a Turbo Timer in his Skoda 1.8T | Turbo_Boss | Maintenance & Performance | 8 | 04-01-2003 10:44 |
