This is a discussion on IHI tomorrow within the Octavia I forums, part of the Skoda Model Discussion Area category; My cars going in tomorrow to Jabbasport for the IHI vf34 stage 3 kit to be plumbed in Will post ...
| Silver bullet Join Date: May 2003 Location: Planet Earth......
Members Car: 345bhp Silver Octavia vRS Thanks: 48
| My cars going in tomorrow to Jabbasport for the IHI vf34 stage 3 kit to be plumbed in Will post photo's etc. later of the clobber being fitted.
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() |
| BRISKODA Staff | Re: IHI tomorrow Got to say...there won't be much to see...it looks like standard but definately doesn't drive like it. If you have black silicone TIP there will be even less to show you've got a big turbo fitted.
__________________ Adrian. |
| Briskodian Join Date: Aug 2005 Location: North London
Members Car: Octy 4x4 1.8T Elegance Hatch Thanks: 29
| Re: IHI tomorrow Be very interested in how it goes - keep us upto date and best of luck ![]()
__________________ ![]() Thanks to JKM: REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!! |
| Briskodian Join Date: Dec 2005 Location: North West England
Members Car: Octavia vRS Thanks: 0
| Re: IHI tomorrow What are the expected gains? -a long pause and a VERY BIG kick up the ****? Has anybody tried a sequential dual turbo conversion for reduced lag and monster power?
__________________ Mk1 Octavia vRS. The thinking man's Hot Hatch. PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close |
| | #5 | |
| Re: IHI tomorrow Quote:
Gains will be: 330-340bhp all the way to 7000rpm, rather than peaking at 245 bhp from 3000-4000 then dying away to 200 by 7000rpm. Torque will be about 320 ibs/ft from 3000rpm Spool up will be as quick as standard turbo due to it being a more efficient roller bearing designed turbo. Power delivery apparently is simply awesome compared to the standard KO3s turbo. I have been told that in the wet I will be getting wheel spin in 4th I will have to learn how to drive properly now…. That should give you the general impression
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() | |
| Re: IHI tomorrow nice
| | #7 | |
| BRISKODA Staff | Re: IHI tomorrow Quote:
VF34 kicks around 2.5kish. High boost mode doesn't respond as well as low boost mode....not a critism....just that low boost mode is drives very, very well....espcially for day-to-day running. High boost mode is excellent on motorways...effortless. Spin wheels in 3rd easily in the dry.
__________________ Adrian. | |
| | #8 | |
| Briskodian Join Date: Jan 2003 Location: Winchester
come with it.
__________________ Speed is an addiction for which thankfully there is no cure | |
| Well, I pick the car up tomorrow…… Everything has been plumbed in, the guys at Jabba have put a ‘soft’ map on for me as I’m getting the exhaust replaced with either a 2¾” or 3” straight through cat-back system, and then once everything’s run in for a few weeks I’ll be getting it mapped proper…hopefully to around 330-340bhp ![]()
| | #10 |
| Crossdresser Join Date: Apr 2003 Location: fast lane
Members Car: Citroen C-Crosser 2.2HDI Thanks: 25
| Re: IHI tomorrow |
| | #11 |
| Re: IHI tomorrow Sounds good ![]()
| | #12 |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: IHI tomorrow lots of driving to distance places then to get it run in ![]() |
| | #13 |
| Permanently banned Join Date: Mar 2006 Location: Buckingham Palace Car Park
Members Car: Honda Civic Type-R Thanks: 86
| Re: IHI tomorrow Be interesting to hear about this.. ![]() |
| | #14 |
| Re: IHI tomorrow No feedback yesterday then? Anything today? |
| | #15 |
| Re: IHI tomorrow Well........ Car is done....well almost!! Everything is fitted, and a 'soft' map has been done for it. It is only boosting at around 8 psi for now, and once the exhaust has been changed it will have the proper map done. The exhaust will be done at Milltek (derby), and will be used as a template for all other mk.i vRS Octavia's.....as it will now be either 2.75" or 3". The exhaust will be aimed at Octy drivers with the IHI or other big turbo kits on. Sterling job as ever by the guys at Jabba
__________________ The silver bullet Jabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.![]() Last edited by Steevie Wonder; 04-03-2007 at 13:28. |
| | #16 |
| Re: IHI tomorrow Nice! I bet that they have some good motors up there |
| | #17 |
| Re: IHI tomorrow Sounds like another Happy Jabba chappie
