39,456 Members 1,489,939 Posts
Injector prob Help
This is a discussion on Injector prob Help within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi i m having problem with my skoda octavia 1.9tdi, the glow plug light came on and i had them ...
Old 12-07-2008, 14:08   #1
Members Car:
Injector prob Help
Hi i m having problem with my skoda octavia 1.9tdi, the glow plug light came on and i had them changed and it was ok for abt 100 miles than while i was driving it missed and the glow plug light came on again. I took it to my local garage n they recon its 1 injector which has a sensor on it. Has any1 expeienced this? Its 2001 110bhp
riaz67 is offline
Old 12-07-2008, 14:15   #2
Hardcore
Basil's Avatar
Members Car: Fabia vRS
Re: Injector prob Help
Best to do a vagcom scan while its running - there's a brisky member map of vagcom owners maybe someone is local to you- it would show up as torque mismatch between the cylinders. Only fix is to replace the faulty injector - even from a scrappie they are costly I'm afraid. There may be a couple of people on brisk with spare ones I understand.
HTH
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 12-07-2008, 14:20   #3
Members Car:
Thanx matey
riaz67 is offline
Old 14-07-2008, 12:59   #4
KenONeill's Avatar
Members Car: Octavia TDi110
If it's running like it's got a misfire I'd agree with Bas; otherwise I suspect yet another brake light switch problem.
KenONeill is offline
Similar Threads
Injector Upgrade Lloyd55vrs Octavia I 23 30-05-2008 23:04
Injector Mounting S exup Octavia I 3 16-10-2007 14:10
Which Injector Cleaner? Windy Fabia I 4 13-05-2007 06:52
injector question? redbaron Maintenance & Performance 44 16-11-2006 12:41
Which injector cleaner? Goochie Maintenance & Performance 22 27-04-2006 13:41
