This is a discussion on Instrument cluster illumination problem within the Octavia I forums, part of the Skoda Model Discussion Area category; The illumination on my temperature and fan selectors has suddenly stopped working. I've checked the fuses and generally fiddled around ...
| Briskodian | Instrument cluster illumination problem The illumination on my temperature and fan selectors has suddenly stopped working. I've checked the fuses and generally fiddled around with the dash but no luck. Has anybody got any ideas?? Also The boot interior light has stopped working as well, once again any ideas??? Thanks ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| ECUless | Re: Instrument cluster illumination problem The bulb behind the fan switch, there is a guide to replacing it on the site, a search should be able to locate it. The micro switch on the catch mechanism. |
| Briskodian | Re: Instrument cluster illumination problem Tried to search for a thread but no luck. Anybody know where to find it on here?? |
| | #4 | |
| Briskodian Join Date: Jan 2005 Location: Ross on Wye, Herefordshire
Members Car: Yellow Octavia vRS Thanks: 3
| Re: Instrument cluster illumination problem Quote:
![]() A search for "bulb behind fan switch" returns this as result one and a technical guide as result two. Try it - you might like it!! ![]()
__________________ You're obviously mistaking me for somebody who gives a 5h1t! | |
| Briskodian | Re: Instrument cluster illumination problem Just in case anybody is looking for the thread it's here: http://briskoda.net/technical-guides...octavia/97885/ |
| | #6 | |
| Briskodian | Re: Instrument cluster illumination problem |
| Briskodian Join Date: Jul 2008 Location: Portsmouth
Members Car: Octavia RS Thanks: 1
| Re: Instrument cluster illumination problem A little tap of the fist and a swear-word normally does it?
__________________ WOW GUYS!!!! look at all my 5 fantastic mods: Green valve caps on each wheel |
| Re: Instrument cluster illumination problem Yes it does, doesn't it ![]()
| problem with INSTRUMENT CLUSTER | aviv | INTRODUCE YOURSELF! First time visitors, say hello here. | 6 | 20-03-2008 13:45 |
| 17 instrument cluster | ChristopherKhan | Diagnostics & VAG-COM | 16 | 13-02-2008 19:39 |
| Instrument Cluster | slxtdi130 | INTRODUCE YOURSELF! First time visitors, say hello here. | 3 | 28-01-2008 21:42 |
| illumination pin on the A/C cluster | arcom | Fabia I | 0 | 13-05-2005 17:50 |
