This is a discussion on Instrument Cluster Query within the Octavia I forums, part of the Skoda Model Discussion Area category; According to both my user handbook and the Haynes 'manual', the display in the centre of the instrument cluster should ...
| Briskodian | Instrument Cluster Query According to both my user handbook and the Haynes 'manual', the display in the centre of the instrument cluster should display oil level info and other information for about 20 seconds when the ignition is turned on. However, mine only displays the brake-pad warning light, fuel level, door open etc but no other text or graphics. Is this correct or is my instrument cluster knackered? And if so, can it be repaired? Thanks in advance. |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
Members Car: Red Octavia vRS 1.8T (20v) Thanks: 46
| Re: Instrument Cluster Query dont worry. mine doesnt do this either, dont think its available in this country. IIRC it still warns you of low oil.
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
Members Car: Octavia TDi110 Thanks: 65
| Re: Instrument Cluster Query Neither does mine. I don't think my Haynes even claims that there's an oil level readout in the car. |
| Re: Instrument Cluster Query Yep
| Re: Instrument Cluster Query You can switch of the warning with a VAG COM or cut of the sensor as in below thread. http://www.briskoda.net/forums/techn...via-mk1/50061/ I did the cut sensor method. Only one sensor on the left front IIRC.
