This is a discussion on Instrument cluster swap within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi. Can I put 1.8T (-1999) instrument cluster to my 1.6 AEE (-2000)? Cluster codes are: 1U1 919 034 C ...
| Re: Instrument cluster swap You may be able to. But bear in mind unless its brand new it will have mileage stored in it and you would need to adapt it to the immobilizer with VAG COM. |
| | #3 | |
| Briskodian Join Date: Oct 2006 Location: Swindon
Members Car: skoda 2002 1600 lx saloon Thanks: 63
| Re: Instrument cluster swap Quote:
I have the relative that has done the similar thing to this and has changed the Iu1 919 034 A on !.6 Mk1 AEE engine, for exchange to IU1 919 034 B, but as he got this one from a mail order scarp yard here. I am not aware of the car that it was coming from, and what type of Octavia model the B type is fitting. (some one here may know an answer for this?) It works fine, and the Lummox is correct that the mileage will be that of the replacement here after ECU is coded by dealer. relative was having an extra 3,000 miles on replacement, but he was not worrying about this, as his instrument faults were now gone away. I would be thinking that it is possible for the C here also! Good luck to you Soviet ![]() | |
| | #5 | |
I am thinking that connections on back of panel will be the same here, but I am not having the knowledge to say that this will, accept new progaming on the ECU. My relative is telling me that the dealer is taking £35 English pounds to do ECU and keys here, and so I think that you should be asking them the question. I hope that this is helping you, and I wish you to have the best of luck with this problem. Regards to you. Soviet ![]() ![]() Last edited by soviet; 11-09-2008 at 08:26. Reason: sp | |
| Briskodian Join Date: Nov 2003 Location: Hull,East Yorkshire
Members Car: 02 black magic octavia vrs Thanks: 0
| Re: Instrument cluster swap Not sure about which instrument panel works with what car but if you get a second hand instrument panel then all you need is vag tacho and this will allow you to retrieve the pin number from the instrument panel and also change the mileage to the same as your existing instrument panel and vag com to then code it in as per the instructions on the ross tech site |
Members Car: Audi S3 Thanks: 145
| Re: Instrument cluster swap I think as long as the rev counter is the same, ie you don't try to put a TDi insert into a Petrol engined car the inserts are quite interchangeable. As Lummox says you will need the 4 digit SKC for both inserts and I'm assuming if the 1.8T one is used you'll not have that. A skoda dealer can do this for you but you'll obviously have to pay. VAG-Tacho is some software which may recover the SKC from the cluster but it isn't 100%. Might be worth a try though, especially if you can borrow it from somone. Edit - Pah, beaten to it. ![]()
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| | #8 | |
Very interesting, that one is able to use this VAG-Tacho for doing this, but where is the software coming from? Is this one a download on the web? It is not always 100% you are saying, and so you must have used this one maybe. Thank you Soviet ![]() ![]() | |
| Re: Instrument cluster swap If you search here for VAG-Tacho you will find that a few people have it. Once you've done that then google will be your friend. VAG-Tacho has some limitations with the later inserts. It requires an interface and software which is not free.
| 17 instrument cluster | ChristopherKhan | Diagnostics & VAG-COM | 16 | 13-02-2008 19:39 |
| Instrument Cluster | slxtdi130 | INTRODUCE YOURSELF! First time visitors, say hello here. | 3 | 28-01-2008 21:42 |
| Instrument cluster swap | SimonJ | Octavia I | 7 | 06-12-2006 21:47 |
| Dying Instrument Cluster | Keefie | Octavia I | 1 | 11-04-2006 21:40 |
| What have I been up to with the instrument cluster? | EddyH | General Car Chat | 76 | 08-04-2005 22:49 |
