This is a discussion on Instrument Failure within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, Got a 99 slxi 1.9tdi (110) The instruments have failed (rev counter, speedo temp and fuel). They all work ...
| Briskodian | Instrument Failure Hi, Got a 99 slxi 1.9tdi (110) The instruments have failed (rev counter, speedo temp and fuel). They all work when ignition is first switched on then die! Problem started when closing drivers window then moved on to putting the blower on to 4 and they worked and finally yesterday going from side to main headlights cured it but now nothing!! Any ideas.... Help! ![]() Skud 1 Last edited by skud 1; 29-01-2008 at 14:37. |
| Briskodian Join Date: May 2007
Members Car: SLX tdi estate & Mazda MX5 Sport mk3 Thanks: 1
| Re: Instrument Failure I hate to say it but mine has just done the same today. It's also an SLXtdi 1999 with 130000. I had also just started looking at replacing it which is the most annoying thing cause Idont want the expense of fixing it. The needles drop to zero readings then go back to normal and fault is repeated then ok again etc. Any ideas? |
| The Following User Says Thank You to Graham PoLoskie For This Useful Post: | skud 1 (22-02-2008) |
| Briskodian | Re: Instrument Failure Usually dry joints on the board, a search on here might reveal some info. Sorry I can't give you the exact thread
| The Following User Says Thank You to cheezemonkhai For This Useful Post: | skud 1 (22-02-2008) |
| | #4 | |
| Briskodian | Re: Instrument Failure Quote:
regards Ian (skud1) ![]() | |
| Re: Instrument Failure Thanks Ian, Like you I eventually found on the forum to remove fuse 15 and I have the same results as you. Working speedo etc but no memory for clock/trip which is annoying but easily lived with. The car's getting to the age where it isn't worth spending a lot on it but generally it goes very well I'm doing 500 to 600m week so in all honesty it doesn't owe me a lot. |
| Instrument Cluster | slxtdi130 | INTRODUCE YOURSELF! First time visitors, say hello here. | 3 | 28-01-2008 21:42 |
| Instrument help | damienVRS | Fabia I | 3 | 17-08-2005 19:34 |
| What have I been up to with the instrument cluster? | EddyH | General Car Chat | 76 | 08-04-2005 22:49 |
| Instrument Accuracy | TOSH | Octavia II | 8 | 28-02-2005 11:28 |
