Intercooler vent -a slight variation :)
This is a discussion on Intercooler vent -a slight variation :) within the Octavia I forums, part of the Skoda Model Discussion Area category; No need to bother with an expensive Audi part. Here's a quick How-to: Nip down to B&Q with 5 quid ...
Old 06-05-2006, 19:22   #1
MC Bodge's Avatar
Default Intercooler vent -a slight variation :)
Nip down to B&Q with 5 quid in your pocket for a 'flush-fitting' plastic heater vent from the central heating dept.
Grind off most of the 'chrome' plating the surface with an abrasive wheel.
Slap on some black Hammerite.
Cut nicks in the vent surround to allow it to bend a bit.
Remove front wheel.
Remove wheelarch liner (noting where the intercooler sits and where the vent will fit)
Draw lines on wheelarch to show where vent and fastenings go.
Cut out the hole with a Stanley Knife.
Attach vent to the intercooler side of the liner with self-tapping screws and cut off the sharp points (Louvres should face 'outwards')
Re-fit liner and wheel.
-Bob is now your Mother's sister's live-in lover
Smile as you drive your car with its diminished warm temperature effect.
bigger pic here
For < the price of a couple of pints and a couple of hours effort on a suunny day it can't be bad
Mk1 Octavia vRS. The thinking man's Hot Hatch.
PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close
MC Bodge is offline
Old 06-05-2006, 19:34   #2
roblatus's Avatar
Default Re: Intercooler vent -a slight variation :)
I am thinking of doing this mod myself. Does it give any noticable benefits?
1998 Mazda Roadster 1.8 RS Spec. spending a lot of time sideways
roblatus is offline
Old 06-05-2006, 19:39   #3
MC Bodge's Avatar
It's difficult to say...
It could have been a placebo effect, but I reckon that throttle response when starting off from the lights and tootling around the houses today (>20degC, warm enough to sit outside the pub) was better after the vent was fitted than before. The performance didn't seem particularly blunted by the warm day.
As I said though, as it's so simple, why not try it?
MC Bodge is offline
Old 06-05-2006, 19:43   #4
Mongreller
devonutopia's Avatar
you should notice it more at higher speeds/revs, when heatsoak traditionally cuts in.
Looks neat though. Not sure whether the extra cost of the TT vent is equivacle (thats a big, probably mispelt word after 3 cans of export) to the effort put in to make that vent fit.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
See the mongrel's 260bhp Dyno Video!
devonutopia is offline
Old 06-05-2006, 19:48   #5
MC Bodge's Avatar
I've not had chance to test it thoroughly yet.
Apart from painting it (which isn't necessary if you don't mind silver -I already had the paint), fitting the vent is easier than using the TT one as it doesn't need cutting-out of a wheelearch liner first, it already has reinforced mounting holes, it's exactly the right size and looks neater.
MC Bodge is offline
Old 07-05-2006, 08:44   #6
Escorted Estate
It should work well, I was going down the same route but ended up with the Forge FMIC instead
Looks fine in black and it's cheaper for sure, which IIRC was the idea behind the original 'pikey' mod
It's when you're booting it through the gears (standard map) - when it's about 25 degress it usually starts heatsoaking a fair bit in 4th. With remap it would probably start earlier due to higher boost = temperature, so every little helps for that
WW --->> Project Journal (pic links in first post there)
WW_VRS is offline
Old 07-05-2006, 22:16   #7
SimonJ's Avatar
Does anyone know if a Mk4 R32 wheel arch liner would fit a 2001 Octavia without too much trimming?
2001 Octavia 4X4 turbo Estate
1988 LAND ROVER 110 V8 County - Slow, but got in the way nicely!
1986 ROVER SD1 3500 Vitesse twin plenum - SOLD
1981 ROVER SD1 V8-S -
SimonJ is online now
Old 07-05-2006, 23:00   #8
I parked up 1st
ric04vrs's Avatar
done mine on my fab VRS at no cost , with a sharp knife cut slots horizontally at 20mm intervals up the liner then with a hot air gun and screw driver procede to warm slots at the same time folding the top edge out and the lower edge in by pushing screwy through the slots ,haven't noticed any difference yet though
not so bored now
ric04vrs is offline
Old 07-05-2006, 23:04   #9
MC Bodge's Avatar
It's certainly had no adverse effects and the engine pulls to the red line.
I'm not sure if it should have this effect, but fuel consumption was an impressive 35.5 mpg on the way to mid-wales and 38.9 mpg on the way back today. Driven 'moderately' briskly with a few full-bore overtakes.
MC Bodge is offline
Old 09-05-2006, 09:20   #10
MC Bodge's Avatar
In yesterday's drizzle, the car seemed to be driving as it does on a frosty morning. ie. FIERCE!
I can only assume this to be due to an improvement in heat transfer from the increased air (and moisture) flow across the intercooler.
MC Bodge is offline
Old 09-05-2006, 16:21   #11
Nigel26's Avatar
have a vent from B&Q thats been in the boot for months... i will get round to fitting it soon...
true though, as above, why spend money at dealers when a fiver down B&Q can do the same job with less hassle. i have been entertaining fitting mine withough taking the liner off the car... using rivets to secure the vent should be good enough.
Sea Grey Mondeo Titanium X
Nigel26 is offline
Old 09-05-2006, 16:28   #12
MC Bodge's Avatar
Why? the liner takes about 2 minutes to remove. It's not the entire wheelarch. Self-tapping screws did the job for me and can be removed easily.
Do it man!
MC Bodge is offline
Old 09-05-2006, 16:32   #13
Nigel26's Avatar
just cause more than anything i'm lazy
rivets arent going to be a problem for me, my dad and brother work for a company that makes them so supply and fitting will be a piece o cake.
the vent i have isnt the same as yours though. its from the extractors / air brick covers section, its a thin galvanized steel so fitting to the outside will be fine.
Nigel26 is offline
Old 09-05-2006, 16:36   #14
MC Bodge's Avatar
ah, ok. It is a bit neater on the inside though. Do it this evening!
MC Bodge is offline
Old 09-05-2006, 16:40   #15
Nigel26's Avatar
HA... with a 14 week old daughter to entertain in the evenings when i get home from work modifying the car has to wait until the weekend or weeks holiday when i can get over to my parents house to use my dads garage and tools...
i'll post pics when its all done...
Nigel26 is offline
