This is a discussion on Intermittant shake/rattle @ 75 on a motorway within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, I've had an intermittent rattle/shake from the front driver's side of my car intermittantly when i reach 75-80ish on ...
| Briskodian Join Date: Apr 2006 Location: Portsmouth
Members Car: Octavia GLX 1.9 TDI Thanks: 2
| Intermittant shake/rattle @ 75 on a motorway Hi, I've had an intermittent rattle/shake from the front driver's side of my car intermittantly when i reach 75-80ish on the motorway. It's very loud, can be felt throughout the car, not sure if i can just feel it through the car or through the steering wheel. Once it starts, i have to reduce speed to ~ 65 to stop it from happening. It started after a cambelt change & service and has become worse over time. It doesn't start immediately, car typically have been running for 20 mins before it kicks in, and it's not always there - somedays it kicks in at 90 (cough), others at 75. It's definatley speed related - while it's happening i've popped the clutch and reved the engine with no difference in sound. From digging about on the forum i'm thinking wheel balance, and will try and get that looked at tomorrow. I'm not sure if a knackered engine tray may do this - it has a crack in it, but generally in one bit - possibly air flowing it causing it to resonant? Any other ideas? I need to get it up on a ramp! The mechanic that did the service doesn't believe it's his fault, and i've fallen out with him, since he's done some bad servicing on my car and someone elses, so calling it quits now and changing mechanic, but want to avoid being charged a bomb for someone elses ballsup. |
| Powahhhhhh.. Join Date: Apr 2004 Location: Buckinghamshire
Members Car: 2002 Octy 4X4 Thanks: 10
| Re: Intermittant shake/rattle @ 75 on a motorway Thouroughly check your tyres. I had a similar issue on a Vectra I had, at 65 / 70 it had symtoms similar to yours. Turned out to be a massive bulge on the inside (under car) edge of the front O/S tyre. Dangerous stuff!
__________________ ------------------------------------------------- 4x4 Octavia, now with leaner gerbils ------------------------------------------------- |
Members Car: Octavia TDi110 Thanks: 65
| Re: Intermittant shake/rattle @ 75 on a motorway I'm thinking this has to be related to tyres, wheel balance, wheel bearings, driveshaft balance or CV joints. So I'd start by checking the bearings for wear, then carefully examining the tyres for bulges or out of round wear . |
| 207/340 Join Date: Oct 2004 Location: Around Manchester & Cheshire
Members Car: Skoda Fabia vRS Thanks: 457
| Re: Intermittant shake/rattle @ 75 on a motorway - sounds like it could be a wheel balancing issue. Possibly a sticky wheel weight has come off?Steve
__________________ Wardy's Fabia vRS ![]() xenons : sunroof : cruise : OEM+ ![]() "Racing is life. Anything before or after is just waiting." - Steve McQueen "If in doubt, flat out." - Colin McRae |
| Re: Intermittant shake/rattle @ 75 on a motorway Taken it to a service center for wheel balancing, no problems identified. Just put it up onto a ramp and took a look underneath - sump guard is now in 3 pieces, hanging loose. Didn't have time to pull it off, but removing that'll be the next step. Will take it off this evening and see if it fixes it. Ps: going 1 way down a road hits in at 75, other way 85. Unknown wind direction, but links it to airflow! T |
| Re: Intermittant shake/rattle @ 75 on a motorway Now suspecting the undertray then. As mine is in one piece, I've never had this issue. |
| Briskodian Join Date: Oct 2007 Location: Kilkenny, Ireland
Members Car: Fabia vRS Thanks: 37
| Re: Intermittant shake/rattle @ 75 on a motorway No - to me it sounds identical to the shaking I had in my Fabia. Its speed related and slowing down stops it. Its the DMF IMHO. Mine had nearly shaken its to the disintegration stage before the clutch / flywheel change two weeks ago. If its not, I''l eat my (old) DMF. |
| | #8 | |
| Re: Intermittant shake/rattle @ 75 on a motorway Quote:
Pictures of you eating your old DMF please ![]() Just spend half an hour trying to fix the tray, gave up and pulled it all off. Turns out the entire drivers side and rear of the tray had come away from the mounting points, as the drivers side mounting bit of plastic had completely split in two. Driving without it - no rattle at all. Now i just have to work out if i should replace it - and the sump filled with sump filler that's underneath it! Time to go to a scrappy! | |
| | #10 |
| Re: Intermittant shake/rattle @ 75 on a motorway Having loads of trouble trying to find the right parts. The undertray itself is 1J0 018 930B, but I actually need the plastic bit this screws into the of the drivers side, including how on earth I get to replace it! Any body got info/ideas? Thanks! |
| | #11 |
| Re: Intermittant shake/rattle @ 75 on a motorway Last edited by Wolfsbane2k; 21-05-2008 at 22:28. |
| felica blower intermittant | Darren200sx | Favorit, Felicia, Fun and Forman | 12 | 21-02-2008 22:47 |
| Intermittant starting problem... | WoodieGuthrie | Favorit, Felicia, Fun and Forman | 19 | 25-01-2008 14:03 |
| Intermittant boot light | kprida77 | Octavia II | 0 | 13-01-2008 22:57 |
| more woes engine rattle and shake | scottstuart90 | Favorit, Felicia, Fun and Forman | 4 | 25-06-2007 13:05 |
| Shake rattle and roll. | keltmoss | Fabia I | 20 | 18-06-2005 17:49 |
