This is a discussion on Jabba Induction or Carbonio within the Octavia I forums, part of the Skoda Model Discussion Area category; Easy question, given the choice lol ive been told the carbonio stories lol but also the praise so ..... out ...
| Briskodian Join Date: Nov 2006 Location: Bristol
Members Car: Octavia VRS Thanks: 103
| Jabba Induction or Carbonio Easy question, given the choice lol ive been told the carbonio stories lol but also the praise so ..... out of the 2 .... just the 2 jabba or carbonio ? i will resist causing filterfest 5000 , so im just out to collect votes lol ![]() Jabba or carbonio one in each hand you would take the .........
__________________ |
| Bored! Join Date: Apr 2005 Location: Macclesfield - Cheshire
Members Car: Octavia VRS Thanks: 30
| Re: Jabba Induction or Carbonio My BMC CDA! |
| Briskodian Join Date: Feb 2008
Members Car: 2001 Black Magic Octy VRS Thanks: 4
| Re: Jabba Induction or Carbonio im very interested in this post because im torn between which one to buy! |
| Briskodian Join Date: Apr 2006 Location: Sheffield
Members Car: Red Octy vRS Thanks: 36
| Re: Jabba Induction or Carbonio ebay one with a decent filter on the end and save the cash ![]() |
| Briskodian | Re: Jabba Induction or Carbonio Both way too much, as is said above by mattbeef ebay with a good filter. |
| Re: Jabba Induction or Carbonio lol jabba or carbonio ![]() can see what u mean tho lol but say someone else is paying lol
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
Members Car: a car Thanks: 272
| Re: Jabba Induction or Carbonio None of them, stick with the standard airbox, or you could end up losing power. There was research done iirc that claimed the airbox was better. Although if it's the noise you want either of those should do the job nicely. |
| Briskodian Join Date: Dec 2003 Location: Coventry
Members Car: Octavia vRS Thanks: 8
| Re: Jabba Induction or Carbonio Neither. If you want power go for a panel filter in the standard airbox. If it's for the noise then go for an ABD Racing one ![]() I sold my original ABD one for a Carbonio, but quickly changed back to the ABD as I preferred the noise.
__________________ vRS Mirror polished 9*18" Mercedes Alloys, APR FMIC, ABD TIP & CAI, Powder coated inlet manifold, Jabba Re-map, Blueflame/Pipewerx exhaust, Forge DV, KW v3 coilovers, Neuspeed ARB, S3 strut braces, bonnet lifters, Autostyl rear spoiler, Milotec rear diffuser & bumper grills, side rubbing strips removed, front and rear rubbing strips smoothed and colour coded, scuttle pannel colour coded, chrome grill colour coded, mk2 vRS badge, de-locked, tints, mk4 aero wipers. |
| Briskodian Join Date: Aug 2006 Location: Watford
Members Car: Mondeo 2.2TDCI Thanks: 21
| Re: Jabba Induction or Carbonio ABD for me also
__________________ Octavia VRs ***SOLD*** The futures somkey! The futures diesel ![]() |
| | #10 |
| Re: Jabba Induction or Carbonio i wonder if you could get a blue forge bit of pipe and swap the red to blue lol where do you all get the abd ?
| | #11 |
| Re: Jabba Induction or Carbonio i found this on the ABD site ABD Racing is proud to offer the best available fresh air intake system for your vehicle. The L.A.N. Pipe intake system is manufactured from 3” mandrel bent stainless steel with all brackets TIG welded securely in place. The complete unit is wrapped in heat resistant ceramic coating that offers both great looks and function. The MAF Sensor connection is layered bright red silicone hose. We only use genuine K&N air filters as there proven performance greatly outweighs any competition. This is a complete fresh air intake system; no other parts are needed for installation. Not recommended for use during inclement weather. whats that about? is that the whole water thing again?
| | #12 |
| SMOGUS MAXIMUS Join Date: Jan 2005 Location: Essex
Members Car: Toyota Auris SR180 Images: 3 Thanks: 50
| Re: Jabba Induction or Carbonio Its because of the fear that you might go into water too deep, but as that would have to be deep enough to go over the lower door seal, then who is going to do that? They may be also referring to the extension you can get, if you want to, that takes the filter ever further down to lower bumper level, but with the standard ABD Racing one as it is, you will not get any problems. Also bear in mind that the Carbonio also places the filter in the same place as the ABD one, so if your worried then you will have the same fears with either. I have had my ABD one on for about three years and never had a problem. You can get them from Mike at Impossible who is a site sponsor. Yes, you can get blue pipe if you really want to replace the red one, I think Demon Tweeks sell the Samco on its own. |
| | #13 |
| Re: Jabba Induction or Carbonio Gerry also fails to mention that the ebay one he gave me works just as well its just that he's a tart and had to have the expensive one ![]() ![]() |
| The Following User Says Thank You to mattbeef For This Useful Post: | Beretta (27-06-2008) |
| | #14 |
| Re: Jabba Induction or Carbonio i found some coupling hoses on forge too ![]() so does the abd carbonio and ebay sit at the same level? im alsoe guessing that if i go to a bigger maf at any stage it will be easier to get the carbonio style one to fit over it? has anyone ever gave any thought to the forge kona induction thing like these too? they state track us eonly tho ? Forge Motorsport | Alloy Fabrication
| | #15 | |
| Re: Jabba Induction or Carbonio Quote:
Yes, the e-bay one sits at the same height as both the ABD and the Carbonio, its just a different quality to the them, you should also change the filter as supplied to a larger GREEN one. If your after the e-bay one, then send an e-mail to John at maximumpowered@aol.com, say it came from me and he will then sell you the e-bay one at a discount.
__________________ Skoda performance was "IMPOSSIBLE", now its Japanese and 177 bhp and 295 lb ft torque of SMOG. Gerry "HONI SOIT QUI MAL Y PENSE" Last edited by Beretta; 27-06-2008 at 08:13. | |
| | #16 | |
You should be ashamed of yourself...............................LOL I have to admit that I did run 238bhp with the E-Bay one on the Octy vRS, and, on reliable rollers, its just that I got the ABD Racing one cheaply from another forum member who was selling his car, or else I would probably still be running the E-Bay one. Obviously the quality is lots better in the ABD & Carbonio ones, but its just a bit of pipe that goes behind the front bumper to hold a filter, and give colder denser air. The ABD with a Bailey DV30 does give an awesome whooooooosh though....LOL As with mapping/suspension/brakes and all other tuning bits, its your choice?? | |
| | #17 | |
| Briskodian Join Date: May 2006 Location: Nottingham, J26 M1
| Re: Jabba Induction or Carbonio The STOCK airbox. Better filtration, cold air feed, no problems phoning up the insurance (or finding that it's invalid if you crash due to an unreported modification). The other rather expensive stuff is 99% of the time all show no go, quite often less go. Popular with 'lads' who have no engineering background but seen one in a glossy on a chav's nova etc. However that's just my opinion and I admit I'm almost 100% a utilitarian, if it doesn't actually MAKE the car go better, I tend to think it's sad, regardless if it's got Jabba printed on it. Which by the way always makes me chuckle because for some reason if I see Jabba I presume the owner is Jabba the hut ![]() If you haven't got a rear anti roll bar such as the Eibach, your money would be well spent on that. Votes - 0 to either. Quote:
| | #18 | |
| Re: Jabba Induction or Carbonio What a load of spiv from their maketing. It's the BEST airbox, ps you can't actually use it in rain it's SO good. And the K&N is a lie, in quantitive tests they are found to have WORSE filtration than stock paper and often NO greater flow. Quote:
| | #19 | |
Have you personally ever fitted an ABD to your car and suffered any problems in the rain, or do you personally know anyone on here that has???? You state that ABD are making false claims over the K & N filters, perhaps you should write to both of them with your evidence, as I am sure they would love to see it. | |
| | #20 | |
| Re: Jabba Induction or Carbonio My points about K&N are well known and widely published, I have no reason to go chasing people waving papers at them. You want it, you got it - fine. From an engineering point you'll not hear me say it's better though. I have an engineering/vehicle engineering background and there is more to filtration than people think. Eg micron rating, is that nominal or absolute? Flow - is that part, mid or end life and is it median or mode averaged if average? If better flow, does it make a noticable difference to the pressure in the intake during the operational range of your engine? I presume you realise that if you double the flow of your airbox, but the original exceeded comfortably the requirements of your engine, you gain nothing apart from fat looking pipes. I could go on but why bother, if you like them fine. I'll challenge you to come up with anything that substantially proves that any after market box is BETTER than stock though. I didn't say yours won't work, or won't work in the wet - I just made comment on the mfr's disclaimer which of course is not on the bottom of a VW sales sheet for a VW airbox designed to work in not just wet but all climates/countries. Greg. Quote:
| | #21 |
| Briskodian | Re: Jabba Induction or Carbonio Totally agree with Greg. When i strippped my car to sell it, i took the Carbonio off and replaced the standard airbox. Throttle responce feels better with the standard setup. Darren
__________________ Octavia 2004 in Red. Now for sale http://www.pistonheads.com/classifieds/543161.htm |
| Carbonio induction kit + oem DV | cyberskidz | Maintenance & Performance | 9 | 08-12-2004 19:28 |
