This is a discussion on Just Fitted My Cai But Have A Problem Anyone Help within the Octavia I forums, part of the Skoda Model Discussion Area category; Fitted My Cai About A Week Ago Now Everything Was Fine But Now My Engine Managment Light Has Come On ...
| Briskodian Join Date: Jul 2005 Location: south west
| Just Fitted My Cai But Have A Problem Anyone Help Fitted My Cai About A Week Ago Now Everything Was Fine But Now My Engine Managment Light Has Come On Has Anyone Else Had This Problem? Does Anyone No Why It Does This Obviously Some Thing To Do With The Air? |
| Briskodian Join Date: Nov 2002 Location: North
| Re: Just Fitted My Cai But Have A Problem Anyone Help Mine came on straight away after having the ABD thing fitted. I think it was just a shock to the system, the fault code was cleared and then everything was OK.
__________________ Rich. Skoda Octavia RS |
| Briskodian Join Date: Jun 2005 Location: NW Kent
| Re: Just Fitted My Cai But Have A Problem Anyone Help I fitted mine at the same time, no problems then. Went to IP today for the re-map and there were 1001 fault codes reqistered! Turned out that fitting the CIA involved disconnecting the battery, this lead the ecu to belive there were faults to earth all over the place (rapid no volt syndrome)!I bet if you get yours checked and fault codes cleared, the problem will not re-appear
__________________ Deli G ,,,, leader of the Peckham Massif! KW Coilovers fitted, Forge TIP fitted, KK fitted, Blueflame full system fitted, CAI fitted, Forge 007 D/V fitted, PBVH4 fitted, Forge adjustable rear tie bars fitted, FMIC fitted, 312's fitted, Tints fitted. Was that a 4x4 Skoda??? It's IMPOSSIBLE! 197.2 BHP & 263.1Nm |
| Re: Just Fitted My Cai But Have A Problem Anyone Help ok thanx for your help |
| Briskodian Join Date: Dec 2004 Location: Wotton-Under-Edge, Gloucs
| Re: Just Fitted My Cai But Have A Problem Anyone Help Did you reset the ecu & throttle position sensor? After you've fitted the cai and the car is cold, open the bonnet and driver's door and put the keys in the ignition so all the fans etc in the car come on. You should hear some beeping etc coming from the engine. When all the noises have stopped, close bonnet and door and turn the engine on. Leave to idle for a few mins. Robert's your uncle's brother!
__________________ '05 Octavia vRS Estate::BMC::Forge: erformance Torque::Whiteline::Lifelong, long suffering Hammers fan Last edited by AndyVR6; 15-01-2006 at 13:49. |
| Re: Just Fitted My Cai But Have A Problem Anyone Help no i didnt do that mate will have to put it on the computer i think |
| Octy back,all modifications fitted........ | WrightyRS | Maintenance & Performance | 13 | 13-01-2005 06:10 |
| New Fiat Multipla In Uk | ColinD | General Car Chat | 22 | 28-08-2004 03:28 |
| Starting problem on Sdi Octavia | BAAHEED | Maintenance & Performance | 1 | 10-04-2003 07:42 |
| Passenger door problem | Dmac1969vRS | General Car Chat | 8 | 25-03-2003 21:20 |
| Starting Problem on 2002 L&K 1.8 T (EDITED) | Turbo_Boss | Maintenance & Performance | 6 | 22-02-2003 17:07 |
