This is a discussion on kkk turbo same as k30s within the Octavia I forums, part of the Skoda Model Discussion Area category; I have put in new engine with a kkk turbo on it but the old engine has k30s on it ...
| Briskodian Join Date: Feb 2007
| kkk turbo same as k30s I have put in new engine with a kkk turbo on it but the old engine has k30s on it are they the same? The problem i'm having is a flat spot and was wondering if this was to do with the turbo, i've checked all pipe work and it looks good and tight! Any ideas It boosts ok then goes flat then boosts again, the turbo can be heard quiet loud but i'm not sure if its any louder than the old unit Cheers for any suggestions |
| Re: kkk turbo same as k30s what engine is it? what car is it from and how old is it? it could well have a K03 on it as oppose to a K03s, the only way to tell off the top of my head is to look at the impellor but i won't even suggest i know everything about them, i think though the K03 had 4 blades and the K03s had 8, i think.
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
| Re: kkk turbo same as k30s KKK is the brand name (borg and warner iirc) Ko3s is the product name, as bengie says there is 2 types that relate to octavia's I assume your talking about a vrs which should be fitted with a ko3s or "normal" 1.8t which uses the ko3 as bengie says I'm no expert either so don't hold me to all this info ![]() |
| Bored! Join Date: Apr 2005 Location: Macclesfield - Cheshire
| Re: kkk turbo same as k30s K03 12 Blades K03s 8 Blades |
| Briskodian Join Date: Apr 2006 Location: Sheffield
| Re: kkk turbo same as k30s I thought that there were two versions of the KO3S a so called silenced and unsilenced version? The part number will be a definite way of telling |
| Re: kkk turbo same as k30s the old one is a 2005 vrs mk1 the new engine with the turbo is unknown i'm told 04, the old engine's turbo has K03 on the blue tab and the new engine has kkk on the blue tab then just serial numbers, would it make a difference??? |
| Briskodian Join Date: Mar 2008 Location: Reading
| Re: kkk turbo same as k30s post the serial number and we can tell you.. as above though thats probably a k03 turbo and not the 'sport' model you had before!
__________________ |
| Re: kkk turbo same as k30s every 1.8t in an octavia after march 2001 had a K03s. it was only the 1.8t slxi from the pre facelift octavia that had a K03 turbo. so if your turbo is from a octavia vRS then it'll be the same turbo and the silenced turbo's made no difference really to anything.
| | #9 | |
| Re: kkk turbo same as k30s Quote:
![]() As said I'm no expert ![]() | |
| kkk ko4 turbo | rs_chris_uk | Maintenance & Performance | 10 | 29-01-2005 18:35 |
| Kkk K03 Turbo | FightingDiva | Maintenance & Performance | 19 | 18-06-2003 20:00 |
