This is a discussion on Lack of ooomph in Vrs within the Octavia I forums, part of the Skoda Model Discussion Area category; Suggestions or advice needed please. In my standard Octy Vrs. When I put my foot hard down in 2nd, I ...
| Legend!! Join Date: Oct 2006 Location: Portsmouth
| Suggestions or advice needed please. In my standard Octy Vrs. When I put my foot hard down in 2nd, I can hear the turbo noise and then it appears to get quieter around 3000rpm and the power seems to die off a little. if I then lift off the gas and reapply it seems to pick up again. If i feed the power through gently it doesn't seem to creat such a problem and there apepars to be more power. Haev I got a problem or is this just a characteristic of a turbo charged engine. Thanks in advance. SC ![]() |
| Re: Lack of ooomph in Vrs Just in second gear?
| Briskodian Join Date: Aug 2006
| Re: Lack of ooomph in Vrs I recognise your symptoms - I find that it is more noticable in 4th gear on my vrs. In going through the gears I quite often find that I feel a stronger surge of power if I dont floor it. I dont know what could be the cause though??? |
| Briskodian Join Date: Jan 2004 Location: Up a tree.
| Re: Lack of ooomph in Vrs Do you know anyone with VAG-COM or other suitable diagnostic tool near you? I suspect they may find a 17705 fault code indicating a boost pressure drop. In your case it sound sliek it could be either a simple boost leak or the diverter valve that is at fault. A diagnostics check will provide significat clues though. |
