This is a discussion on Lambda sensor malfunction... within the Octavia I forums, part of the Skoda Model Discussion Area category; Hello, Thought i'd scan my car cause I haven't done so for a good 2-3 months and came up with ...
| Briskodian Join Date: Jun 2007 Location: Cornwall
| Lambda sensor malfunction... Hello, Thought i'd scan my car cause I haven't done so for a good 2-3 months and came up with this beauty; "16519 - Oxygen (Lambda) Sensor B1 S1: Heating Circtui Malfunction P0135 - 35-10 - - - Intermittent." I cleared it and turned the engine back on for a few minutes and it didn't reappear. Hope it's nothing serious, about to start the engine conversion in the 205 and really don't have the spare cash! Anyone come across this? Is the first sensor (I think the B1 S1 is before the cat) fried?
__________________ Octy vRS mk1; APR Stage 1, Forge 007p DV, THS TIP, Honda s2000 aerial, seat cupra front splitter, MAS alloy center caps, alpine CDE-9871R, infinity 6010cs, Jbl 75.4 and 10" sub. Pug 205 gti; mi16 200bhp/tonne ![]() |
Images: 2 Thanks: 22
| Re: Lambda sensor malfunction... Yes thats the right sensor and it looks like the heating element has a problem with it, will require a new probe.
| The Following User Says Thank You to Lummox For This Useful Post: | ethos (13-05-2008) |
| Re: Lambda sensor malfunction... Awesome, anyone have a rough price on one of these? Does it need to be done asap, or can it wait?
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
| Re: Lambda sensor malfunction... Aftermarket £80 delivered Lambda Sensors - Lambda Sensors o2
__________________ Regards Martin Turbo back blueflame exhaust |
| The Following User Says Thank You to martziniuk For This Useful Post: | ethos (13-05-2008) |
| Re: Lambda sensor malfunction... Aftermarket.... erk! Anyone used them? Guessing that means it'll be £120 from the dealer... ![]() Fed up. What are the implications of not changing it straight away?
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: Lambda sensor malfunction... Well I paid £95 for mine via a mate who owns a garage! Mine was out but it didnt throw a fault code up but the emissions on fast idle were to **** completely.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Re: Lambda sensor malfunction... Can this do any long term damage / any damage at all... Infact, what difference will make if the first sensor is faulty? £95 isn't too bad, wouldn't of known about the fault unless I ran vag-com....
| Re: Lambda sensor malfunction... http://briskoda.net/forums/octavia-i...-probes/74705/ should help with price. I would imagine the fueling will be a little out.
| Re: Lambda sensor malfunction... Thanks mate. Hmm, I've got a service coming up in about 4-5 weeks- wonder if I can wait until then. That way they'll probably fit it alot cheaper. Then again, i'm doing about 250 miles a week at moment. Maybe I'll go for a drive and see if the error code actually reappears.... Can I check lambda readings with vag-com?
| | #10 |
| Re: Lambda sensor malfunction... Did some logs; It's missfiring http://www.aoyt95.dsl.pipex.com/missifre.CSV Some sensor readings, I have no idea what they mean http://www.aoyt95.dsl.pipex.com/LOG-01-030-031-034.CSV Error is not back though.
| | #11 | |
| Why So Serious Join Date: Jan 2006 Location: "What" ...What ain't no god damn country
| Re: Lambda sensor malfunction... Quote: I assume the numbers 1's are the misfire ?? | |
| | #12 |
| Re: Lambda sensor malfunction... Yep ![]()
| The Following User Says Thank You to ethos For This Useful Post: | fatty5000 (13-05-2008) |
| | #13 |
| Re: Lambda sensor malfunction... |
| | #14 |
| Re: Lambda sensor malfunction... Over fuelling can hurt your fuel economy, knacker your cat, and in severe cases give you bore wash issues. |
| | #15 | |
Ken ............Whats bore wash ???? | |
| | #16 |
| Briskodian Join Date: Oct 2007 Location: Buckinghamshire
| Re: Lambda sensor malfunction... Isn't that where the fuel strips the oil from the cylinder walls causing high wear of the piston rings and cylinder walls?
__________________ Upper & Lower S3 Strut braces-Forge FMDV006 DV-PiperX panel filter-Whiteline adjustable rear arb-Superpro Dogbone, Control arm & Front ARB bushes-LCR Splitter-Milotec Grilles-Golf MK4 Aero wipers-KVW100-Cruise Control-Parking Sensors-18" RS8 Alloys-N75H-Revo Stage 1-TO DO: Turbo back exhaust-Koni FSD and H&R springs(16 Days left)-Seat & Door Card Leather retrim and a respray. ![]() |
| The Following User Says Thank You to Lex Dysia For This Useful Post: | fatty5000 (14-05-2008) |
| | #18 |
| Re: Lambda sensor malfunction... Well, i've done about 30 miles today and the error hasn't returned. I'm concerned about the missfires though... although I'm guessing if they're not bringing up the engine management light they can't be TOO much to worry about. Out of interest could someone else do a missfire log for me? Over say 10+ mins ![]() I wonder if it's not that uncommon to get a missfire here and there.
| Lambda sensor on 1.4 v8 Classic | jchallis | Fabia I | 9 | 09-08-2008 14:32 |
| Lambda sensor wire colours. | furzy | Octavia I | 8 | 26-10-2007 17:19 |
| lambda sensor help required! | yorkshirepuddin | Diagnostics & VAG-COM | 13 | 09-04-2007 13:50 |
| 02 oxygen lambda sensor | paul thomas | Fabia I | 5 | 12-02-2007 09:54 |
| Resistance of lambda probe (Help with o2 sensor / oxygen sensor part II) | bigad | Diagnostics & VAG-COM | 5 | 16-12-2006 16:17 |
