This is a discussion on lambda sensor within the Octavia I forums, part of the Skoda Model Discussion Area category; hiya all, have got a skoda octavia vrs and the lambda sensor has gone. does it need to go into ...
| Briskodian Join Date: Apr 2005 Location: midlands, uk
| lambda sensor hiya all, have got a skoda octavia vrs and the lambda sensor has gone. does it need to go into skoda to be done or can i do it myself? if i can, where would be the best place to get one and roughly how much? bit pigged off with it as it was only done by skoda 2 yrs ago and the car has only done 15000miles since done neil |
| Re: lambda sensor Should be able to do it yourself. IIRC there are two, is it for sure the same one that has failed?
__________________ Stu Stu's Websites - http://www.fabia-vrs.com & http://www.octavia-vrs.com Stu's Car - 2008 Audi S3 - Ibis White, Black Optics Pack, Privacy Glass, Auto Bi Xenon Headlights, Rain Sensing Wipers, Bose Sound System, Ipod Prep, GSM Phone Prep, Flat Bottom Multi Function Steering Wheel, Electric Folding Mirrors, Acoustic Parking, Cruise Control, Interior Light Pack, Non Smokers Pack. SWMBO's Car - 2008 Seat LEON TDi Stylance, Black Magic, Sports Pack, Rear Parking Sensors. Something for Weekend - A Patio |
| Re: lambda sensor Didn't know that it had two.![]() Might be best to change the two then. Where abouts are they? Is it a big job? The worst thing is it is booked in for its MOT next week so I will have to get something sorted by then and dont fancy paying loads of bills ![]() Where can I buy them from? Any help gratefully appreciated. Neil |
| Re: lambda sensor No 1 is pre cat, between the exhaust manifold and the cat, No 2 is after the cat and should be more obvious to see. Main dealer is an ideal place to buy, price them up first and then maybe try some 3rd party ones such as Euro Car Parts.
| Briskodian Join Date: Jun 2005 Location: Derbyshire
| Re: lambda sensor Mine went a while ago. replaced it myself to a tune of £93 trade price, so you might want to re-think replacing them both. If you know anyone with a diagnostics machine they'll be able to find which one has gone.
__________________ |
| Briskodian Join Date: Aug 2008
| Re: lambda sensor How do you know the lambda sensor has gone?? My warning light came on a while back which indicated from the codes (according to skoda) lambda sensor issue. They reset it, it came on again quickly with same code error. Skoda replaced both sensors....then gues what light back on and according to skoda garage same code error. It took them a while but eventually they found a very small split in one of the air pipes!!! this was changed and lo and behold car fixed. A very costly exercise, I am informed that Lambda sensor should last a long long time my car had only done 50K and they should last much longer than that!!! you have been warned.... |
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: lambda sensor Mine was swapped at 50k for failing the emissions test...car drove fine however. This was the pre-cat one.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| Briskodian Join Date: Sep 2006 Location: York
| Re: lambda sensor Fitted the pre and post cat lambda's to mine got them from Just Lambda, Skoda lambda sensors, Bosch and NTK zirconia and titania sensors by post was a total of about £210 delivered for the bosch parts or I think you can do the slightly cheaper versions for about £150. Skoda in Leeds wanted £246 not including VAT or Fitting. Hope that helps
__________________ Octavia vRS Mk1 55 Plate Corrida Red Blueflame turbo back exhaust 200 cell Cat, Carbonio C.A.I, Forge T.I.P, Forge Diverter Valve, Forge/Samco Hoses, N75-J Valve, Toyo Proxes TR1's and remap soon to come |
| Re: lambda sensor VAG Trade Pricing - 1.8T AUM; 1.8T vRS Front - 021 906 262B £81.89 +VAT 1.8T AUM; 1.8T vRS Rear - 06A 906 262Q £81.89 +VAT Perhaps if you have an invoice from the last repair it will list the PT Number for the one already replaced.
| | #10 |
| Re: lambda sensor How do you get VAG trade prices rather than normal skoda prices? t
| | #11 |
| Re: lambda sensor You can ask for a discount from your dealer, most will give you 10% or you can apply for an account with Trade Parts Specialists
| Lambda sensor on 1.4 v8 Classic | jchallis | Fabia I | 9 | 09-08-2008 14:32 |
| Lambda Sensor | champ | INTRODUCE YOURSELF! First time visitors, say hello here. | 5 | 01-08-2008 00:05 |
| Lambda sensor malfunction... | ethos | Octavia I | 17 | 14-05-2008 18:19 |
| lambda sensor help required! | yorkshirepuddin | Diagnostics & VAG-COM | 13 | 09-04-2007 13:50 |
| Resistance of lambda probe (Help with o2 sensor / oxygen sensor part II) | bigad | Diagnostics & VAG-COM | 5 | 16-12-2006 16:17 |
