This is a discussion on A leaky skoda, never! within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi all, I have a really bad leak appearing in the passenger side rear foot well of my Octavia VRs. ...
| Briskodian Join Date: Apr 2007
| A leaky skoda, never! Hi all, I have a really bad leak appearing in the passenger side rear foot well of my Octavia VRs. The mat and the carpet are soaking. It's happened once before when I just bought the car, and can you believe that Skoda said it wasn't a warranty item so were not willing to fix it! What's the point in buying approved. I had it fixed then by the dealer at the cost of 60 buck, and, from my girlfriends description, I think they cleaned out debris from the conduit that takes water from the windscreen down to the ground. Does any of this sound familiar? Is that what I should be looking to do and if so how do I get in at it etc? Please help, my more simple mates think it's hilarious that my Skoda leaks. Cheers, Russ |
Images: 2 Thanks: 22
| Re: A leaky skoda, never! Does sound famiiliar. I'd be checking its not coming in over the sill if the inner door membrane is not sealed.
| Re: A leaky skoda, never! have a search on here for removing the scuttle cover that shouls get you going. Once you have the cover off, on the passenger side you will see the pollen filter and to the right of that a large drainage hole that is probably full of leaves and has a cable running though it. Just to the right of the pollen filter there should be a rubber bung - some people route power cables, etc though it - I had my laser detector cable runnign though it, but that can cause a leak too - some silicon sealant around that worked a treat. http://www.matthewames.co.uk/briskod...g/PICT2756.JPG http://www.matthewames.co.uk/briskod...g/PICT2757.JPG http://www.matthewames.co.uk/briskod...g/PICT2758.JPG http://www.matthewames.co.uk/briskod...g/PICT2760.JPG Also consider undoing the bottom bit of wheel arch trim and pulling out the leaves / compost that is in there too..... (if your not quite sure where, pour some water in the drain hole at the top and see where it comes out.....) When the door membrain is leaking you normally also expect to see some water on the door sill rubber too (quite often the case when after market speakers have been fitted). |
| Re: A leaky skoda, never! There have been a few similar issues with the rear sunroof drains. They run from where the back of the sunroof is when it's wound right back, down the C-pillars. |
| ECUless Join Date: Mar 2005
| Re: A leaky skoda, never! Don't forget an ill fitting air con drain and a disconnected rear washer pipe as a source of water inside. |
| Briskodian Join Date: Jul 2006 Location: South Birmingham
| Re: A leaky skoda, never! Also blocked pollen filter, causes this. EDIT: didnt read all the posts, sorry.
__________________ Support Briskoda----------------------> ![]() Red Skoda Octavia V//RS Mods to date: Carbonio CAI Forge 007 DV Aero Wipers Briskoda Stickers KVW100 GB Wheel Inserts RS Tuning Remap Delocked Piper Cat Back Kenwood KDC-W6541U Fli Twin 12" Active Sub Parrot CK3100 ------------------------------------------------ ![]() |
| Re: A leaky skoda, never! Thank you so much chaps. I think it might be the pollen filter, as I think that's what they said last time, so I will give it a clean. Great pictures too Mbames. Thanks one and all. Russ |
| Re: A leaky skoda, never! I had a flood in my rear passenger footwell... pretty sure it was the grommet as it only happened after I ran in some extra cabling. I have been lead to believe that with the leaves blocking the drainage holes if you rock the car a bit you can hear water sloshing about..... Happy investigating! |
| Briskodian Join Date: Aug 2006 Location: Liverpool
| Re: A leaky skoda, never! The pollen filter gets discarded, youll need a new one.
__________________ 2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!Smiles all 'round |
| | #10 |
| Briskodian Join Date: Jan 2007
| Re: A leaky skoda, never! I have leakage on my passenger front footwell, it comes in UNDER the door!, but my road is heavily camberd so i park it level and none comes in!.
__________________ Mods- ABD racing CAI --- ABD racing TIP --- Forge DV --- Blue flame full sytem --- Koni FSD's --- Bosch aero twins --- Fuel 4 5 Stud - 18" --- Milotek 3 grill set --- Milotek bonnet lifters --- Eibach springs --- Impossible Performance custom remap 'Impossible' is Nothing |
| | #11 |
| Re: A leaky skoda, never! |
| | #12 |
| Re: A leaky skoda, never! I get that on my Octy too, but the plastic membrain in the door was hacked to pieced by the previous owner (or the person he employed) when they fitted some aftermarket alpine speakers and crossover units.... |
