Leon 1,8t 180bhp Gerbox In Octavia 1,9t 150bhp
This is a discussion on Leon 1,8t 180bhp Gerbox In Octavia 1,9t 150bhp within the Octavia I forums, part of the Skoda Model Discussion Area category; A friend here in norway got a 2000 octavia 1.8turbo frondt wheel drive 150bhp. its buildt to 350-400bhp and over ...
Old 29-07-2008, 12:46   #1
A friend here in norway got a 2000 octavia 1.8turbo frondt wheel drive 150bhp. its buildt to 350-400bhp and over 450nm torque.
We are thonking off putting a Leon 1,8T 180bhp 6speed box in this car.
What exactly more than the box do we ned?. like driveshafts. gear/engine mounts? linkage. or just buy a sequential from sqs?
Does the Leon Use the same Quaife diff as the Octavia 5 speed? as the car already got a queife diff
Cosworth87 is offline
Old 01-08-2008, 16:27   #2
Re: Leon 1,8t 180bhp Gerbox In Octavia 1,9t 150bhp
You need gearbox, flywheel, clutch, engine cover on flywheel/engine interface, driveshafts, and nuts and bolts for quite a few things (a lot of stretch bolts and locking nuts along the drivetrain). Then you need custom airco line supports (2x), clutch tubing support, and I am not sure but you might need 6-spd clutch pipework or heavily bend the existing one.
You can keep original gear lever and the cables - I have done TDI110 from 5spd to 6spd and still keep the 6-th gear as a surprise :-)
It's worth to adapt the speedo with VAG-com, otherwise it's too far off. I only did it after a year - didn't know about it until then.
No idea about quaife on Leon, but if it's non-vrs Octy it does not have quaife or anything advanced for that matter.
Superb 2.5TDIV6, manual 6-spd
dieselV6 is offline
Old 01-08-2008, 16:43   #3
splash!!!!
bengie's Avatar
sorry but you need to change box/starter motor/drive shafts/selectors/gear knob thingy/clutch/flywheel/clutch pipe complete plus obvious things like fluids nuts and bolts.
speedo won't be out as it has a speed sensor on it
do not adjust the 5 speed clutch pipe to fit the 6 speed as you might wreck something as the 6 speed has a damper inline.
owner of a skoda octavia 4xvrs3
bengie is offline
Old 01-08-2008, 19:00   #4
claytarget_god's Avatar
If I was you mate I'd go for a deisel 6 speed 02m IIRC.
iirc the 5 n 6 speed petrols are the same top end.
Done: PowerFlex Dogbone Bushes,Forge FMIC,CAI,forge DV,N75j, Longlife 200cel Cat 2.5" cat-back,Weitec GT coilovers,Whiteline 22mm ARB and S3 Front Lower Brace,SuperPRO Wishbone/Front ARB Bushes,Remap,LCR Front Splitter, Milotec front grills,EBC grooved/dimpled Discs,Black Diamond Predator Pads,18" Team Dynamic Pro Race 1.2(StarSilver) To Do: TIP,Tinted Windows, Front Bumper: Milotec Side Vents,Milotec Rear Bumper Splitter, VSport Custom Remap.
claytarget_god is offline
Old 01-08-2008, 19:04   #5
splash!!!!
bengie's Avatar
yeah they are the same top end but the 6 speed is far stronger. diesel is too long i feel, whats the points in having a car geared for 300mph?
bengie is offline
Old 01-08-2008, 19:06   #6
Cupra Bush King
Lummox's Avatar
Images: 2
Also the connection onto the gearbox for the clutch is different as the six speed has an internal slave cylinder.
Just done such a conversion on bengies car.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is offline
Old 01-08-2008, 19:22   #7
splash!!!!
bengie's Avatar
whats the silver thing?
is that a standard part?
bengie is offline
The Following User Says Thank You to bengie For This Useful Post:
pittVRS (01-08-2008)
Old 01-08-2008, 19:43   #8
Cupra Bush King
Lummox's Avatar
Images: 2
www.unit18.co.uk
Lummox is offline
Old 01-08-2008, 19:45   #9
splash!!!!
bengie's Avatar
yeah but what is it? is it the damper?
bengie is offline
Old 01-08-2008, 19:46   #10
Cupra Bush King
Lummox's Avatar
Images: 2
Yes the very damper you were chuffin on about.
www.unit18.co.uk
Lummox is offline
Old 01-08-2008, 19:51   #11
Mongreller
devonutopia's Avatar
Images: 5
Gosh, even I figured that one out Bengie!
Is it going to be ready by 7/9/08?
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is online now
Old 01-08-2008, 19:54   #12
splash!!!!
bengie's Avatar
hopefully
now that the bloody turbo has turned up!!
bengie is offline
Old 01-08-2008, 20:05   #13
fair one, it int that bad though is it? thought it was 180mph for the diesel? better on fuel though.....
Old 01-08-2008, 20:19   #14
Cupra Bush King
Lummox's Avatar
Images: 2
That would take a miracle as i'm booked for all of August....lol
www.unit18.co.uk
Lummox is offline
Old 01-08-2008, 20:31   #15
Mongreller
Images: 5
Leaves around 6 days in Sept then?
Old 01-08-2008, 21:23   #16
splash!!!!
bengie's Avatar
from that picture it looks more like a custom cnc machined piece rather than a standard factory piece
bengie is offline
Old 01-08-2008, 21:24   #17
splash!!!!
bengie's Avatar
the 5 speed will hit 180mph, the diesel gearing is far longer.
bengie is offline
Old 02-08-2008, 17:42   #18
Sorry, forgot the starter motor. Gear knob does not make gear change different, and my clutch has been fine for 5 years without the damper, though
Speedo will be out - speed sensor is one thing, but there is a different number of impulses per km that the 6-speed uses. that's why you need to adapt it in Instrument Cluster
dieselV6 is offline
Old 02-08-2008, 17:43   #19
The error on speedo (or was it odometer?) is not large, 3%-5% or so
dieselV6 is offline
Old 02-08-2008, 18:06   #20
but it will mATTER WHEN YOU GET A PIC TAKEN lol
Similar Threads
95 or 98/99 RON for 2001 Octavia 1.8t- 150bhp ConorM Octavia I 1 02-11-2007 14:04
150bhp or 180bhp? ethos Octavia I 22 06-07-2007 10:59
130BHP VRs + 150BHP FR Leon Paulos19 Fabia I 35 04-04-2006 02:18
skoda octavia 4x4 150bhp tuning? soulfreem Octavia I 4 01-10-2005 15:11
150bhp To 180bhp Fram Maintenance & Performance 4 22-06-2003 09:02
