'Lights left on' buzzer
This is a discussion on 'Lights left on' buzzer within the Octavia I forums, part of the Skoda Model Discussion Area category; Just traded in my Octavia SLXTDI with 123k miles for an 04 Ambiente 90bhp with just 52k. Bought from independent ...
Old 18-01-2008, 21:37   #1
Just traded in my Octavia SLXTDI with 123k miles for an 04 Ambiente 90bhp with just 52k. Bought from independent dealer at a good price - got a great trade-in. Just got it today and have noticed that the 'lights left on' buzzer does not work; or is it a case that there just isn't one?
Anyone got any clues on this. Would have thought that it was a standard feature at this stage.
Thanks
slxtdi is offline
Old 19-01-2008, 13:18   #2
bjorn's Avatar
Re: 'Lights left on' buzzer
never noticed a buzzer on my vRS either
2001 Skoda Octavia vRS
Blueflame Catback Exhaust, CAI, Forge TIP, Forge 007 Valve, N75j, Weitec Dampers and Springs, WRC Spoiler, WRC Graphics.
bjorn is offline
Old 19-01-2008, 13:22   #3
my vrs has one i thought they would be standard throughout the range
Skoda Owners are not image concious.
02 Octy VRS SOLD
94 Supra TT GZ now on the drive.
vrs-si is offline
Old 19-01-2008, 16:20   #4
My '03 Ambiente has one fitted. Have you checked for blown fuses?
simonlb is offline
Old 19-01-2008, 16:50   #5
moley's Avatar
I had an '04 plate Ambiente and that had a lights left on buzzer, so your octy should have the same.
moley is online now
Old 19-01-2008, 17:16   #6
mbames's Avatar
I have one my 2001 Elegance. Only works on the drivers door though, so no good if you park close to a wall and climb out the passenger side (the ex can vouch for that!!!)
mbames is offline
Old 19-01-2008, 17:38   #7
Thanks guys. Will check fuses.
slxtdi is offline
Old 19-01-2008, 19:26   #8
bjorn's Avatar
likewise - cheers
bjorn is offline
Old 19-01-2008, 19:43   #9
VRSPhil's Avatar
Mine has one... it sounds like something out of a poverty spec' 80's fiesta, though
'54 Passat PD130 Sport... 55mpg
Octavia vRS WRC - Gone but not forgotten!
VRSPhil is offline
Old 19-01-2008, 21:06   #10
sdenny's Avatar
What do you want? Something that says "Excuse me sir. You appear to have left your lights on. Would you mind awfully turning them off? Many thanks"?
You're obviously mistaking me for somebody who gives a 5h1t!
sdenny is offline
Old 20-01-2008, 16:34   #11
hello I have the same probleme and was told the buzzer is built into the dash {Speedo area and that it would be expensive to replace. but it must be switched on via the door lock or interior light again no info
tornado is offline
Old 20-01-2008, 16:39   #12
Might just be the door switches. Does the dome light turn on if you open the door?
sebulbus is offline
Old 21-01-2008, 08:48   #13
ECUless
fordfan's Avatar
Is the ignition switch S contact working, the interior light will come on or the radio will turn off when the key is removed.
fordfan is offline
Old 21-01-2008, 10:03   #14
Eire-Andy's Avatar
also check that your puddle light works, the light down by the bottom of your door.
these failed at the same time on mine. mines not a vrs tho its a 1.6 petrol.
if you hold the door closed and open it slowly, does it come on at any stage as you gradually open it? if it does then the switch is ****ey... i have the same problem but never bothered to fix it.
Eire-Andy is offline
Old 21-01-2008, 12:14   #15
VRSPhil's Avatar
What a good idea! I might email SUK
VRSPhil is offline
Old 21-01-2008, 13:45   #16
KenONeill's Avatar
I think the Ambiante has one (although I never left the lights on in the one I hired). I thought it was one of the many things that could be turned on and off with VAGCom though?
KenONeill is offline
Old 23-01-2008, 00:32   #17
madfiddler's Avatar
ok, so I am a driver and know little about engines or how my car works in any way!...just the basic stuff to keep it maintained....
....my light warning buzzer stopped working on my 2002 Ambiente. garage thought it was a simple job to do under warranty. they got it working only to then find various other electrical components go on the fritz including airbags.....basically the problem was relating to some electrical control unit behind the dash. I'm sure others may be able to tell me exaclty what this part was....but it was about £400 to replace!
the garage and skoda had a big argument about who should pay for it as it was just out of skoda warranty but still in the garage's warranty, but at least I didn't have to pay for it!
anyway, I hope this isn't your problem!
madfiddler is offline
Old 23-01-2008, 09:22   #18
Eire-Andy's Avatar
i had a fiddle with my door lock last night for you, the switch in question is activated as the bar is slid into the lock, you can simulate this by sliding a screwdriver shaft (sideways) gently into the lock. the lock has three states, open, slightly locked, and fully locked.
only when my driver door is slightly locking and i apply pressure towards fully open does the puddle light come on, but its very tempermental. The passenger door does not work regardless of locking state. Those micro switches built into the door seem to be completely sh*te as there are thousands of threads on audi/vw forums too about these things.
I really cba tearing down the door again just for a buzzer/puddle light. maybe you are more motivated
Old 26-01-2008, 17:41   #19
Well its not a fuse! Just noticed the dome(puddle) light comes on momentarily when the the door is just open a fraction, and wait for it , the buzzer actually works during this brief illumination! I can hear the door switch clicking on and off- light on/off- but its obviously faulty. Wouldn't mind fixing it if its not a difficult job, since i just got the car- you know the way it is. Anyone done this?
Thanks for all the follow ups.
slxtdi is offline
Old 28-01-2008, 08:22   #20
Eire-Andy's Avatar
Have exactly the same problem here, you can either disassemble the door lock and attempt to fix the locking sensor, or replace the entire door lock. the stealers will generally replace the door lock.
Old 28-01-2008, 09:38   #21
KenONeill's Avatar
In this context, I discovered that the buzzer is activated by the Continental parking lights (leave an indicator on, switch off lights and ignition, and get sidelights on the one side), to my confusion, since I knew the sidelights were off!
Similar Threads
You've left your lights on... runboy Off Topic and Chit Chat 24 01-11-2007 16:03
Light warning buzzer TIB Favorit, Felicia, Fun and Forman 15 14-09-2007 15:46
Warning buzzer not sounding when lights on and door open Goochie Octavia I 4 14-11-2006 15:21
Buzzer and Lights ChrisRs Fabia I 6 20-10-2005 14:42
Beeper/Buzzer - Where is it? CustomSkodaIOM Maintenance & Performance 20 11-11-2003 21:54
