This is a discussion on Lights pointing too low within the Octavia I forums, part of the Skoda Model Discussion Area category; hi briskodians, my Octi MKI points the lights too down, I moved the regulation wheel ot the upeer position but ...
| Briskodian Join Date: Apr 2007
| Lights pointing too low hi briskodians, my Octi MKI points the lights too down, I moved the regulation wheel ot the upeer position but on highway and avs. the ligth points too down, maybe i need to regulate by hand on the engine bay, is this possible? Are any bolts for regulating the angle of the ligths on the engine bay? Thanks SV |
| Re: Lights pointing too low Sorry about the delay: I had to check the manual before I could answer. Yes, there are normal mechanical adjusters for the headlight alignment on the Octy. However about all the manual says beyond that is "leave it to your dealer, cos it needs optical beam alignment equipment". |
| Re: Lights pointing too low KenONeill, thanka for the comment, gonna check it on next service cheers Alvaro |
| Nuts Join Date: Nov 2006 Location: Greater Manchester
| Re: Lights pointing too low Park up against a garage or wall at night and have a 'mess about'. Usually worked for me.
__________________ "Stupidity, if left untreated, is self-correcting." - Heinlein |
| Re: Lights pointing too low Worked for me too, back in the days when you had proper lenses, and not clear shields with the beam focus being provided solely by the reflector. |
| Briskodian Join Date: Jul 2007 Location: Oxfordshire
| Re: Lights pointing too low what i did when rebuilding fron of my old car was park similar height car near garage put tape on upper levels of beam then parked my car in same spot and adjusted to suit. not perfect by any stretch but did the job fine for me.
__________________ Must Go Faster |
