This is a discussion on Long Life 'OIL Change' within the Octavia I forums, part of the Skoda Model Discussion Area category; My Octy PD estate is on this extended servicing setup, up till now Ive had to use the Castrol 'SLX' ...
| Briskodian Join Date: Nov 2005 Location: Stoke-on-Trent
| Long Life 'OIL Change' My Octy PD estate is on this extended servicing setup, up till now Ive had to use the Castrol 'SLX' oil, however found out to day that this has been superceded with a new Castrol oil entitled 'Edge'. Cant see any changes in specification though. Probably just an excuse to change the packaging. (1 litre over £13)!!! Hope this helps save someone a few moments searching around in Halfords. |
| Yes, Castrol EDGE 5W-30 is a new oil meeting the new VW specs 504 00/507 00. See the FAQ below: http://www.briskoda.net/cms/Frequent...should_I_use?/
| Briskodian Join Date: Jan 2005 Location: kent
| Notice3d the same a few weeks ago , Halfords had cleared ourt all the old SLX , however could not find the VW 506/01 spec reference on the new EDGE brand , so is it ok for Variable service , wonder ??? . I have found it cheaper to buy direct from the skoda dealer , it is cheaper too |
| The front of the bottle say that it replaces the SLX |
| | #5 | |
| Quote:
So the 5w - 30 is now as good as the 0w-30 longlife | |
| Fabia VRs service oil change | STEW | Fabia I | 3 | 17-05-2005 13:07 |
| MORE - What engine oil should I use for my Fabia vRS? | aixlad | Fabia I | 21 | 14-03-2005 21:34 |
| Modded your Skoda? Some Oil Advice! | oilman | Maintenance & Performance | 82 | 11-10-2004 12:09 |
| Oil about this then....... | stopan1j | Maintenance & Performance | 38 | 14-08-2003 15:01 |
| What oils meet specifications VW 503 00, VW 506 00 and VW 506 01, for long life? | ColinD | Technical Guides | 0 | 05-06-2003 23:20 |
