This is a discussion on Loud noise from air intake within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, I'm a new member here but have posted a quick hello in the appropriate thread. I have a problem ...
| Briskodian Join Date: May 2005 Location: North Devon
| Loud noise from air intake Hi, I'm a new member here but have posted a quick hello in the appropriate thread. I have a problem with my Classic 1.6 2001 model which cannot be traced using computer diagnostics at a Skoda Service Centre. When starting the car from cold or sometimes cool a loud fan kicks in. (Loud enough to turn heads in the street). Looking under the bonnet it seems to be coming from the air intake area just past the air filter housing. The fan will usually cut out after about 30 seconds. The vehicle has no extras, no aircon and no turbo. This noise sounds like it should not be there but a Skoda mechanic could not replicate it (apparently, though it does it every time from cold) and the computer could find no fault. If I start the engine and the fan noise kicks in, then stop the engine and restart it even though the engine is still cold it will not happen again, only onthe first start up. It is definatley not the cooling fan, Ive checked. Any one have any idea what this could be? Your help would be greatly appreciated. All the best Daz |
| Quick bump from a newbie, can anyone help?? |
| It could be the secondary air pump, assuming that your car has one. (What is your engine code?) See the FAQ here for a description of the noise.
Images: 2 Thanks: 22
| Sounds very much like the secondary air injection pump. Some noise should occur but if its really noisy chances are the bearings have gone in it. The pump iirc on the 1.6 should sit on the right hand side as you look at the engine, just infront of the manifold. There wil be a flexi pipe comming off the side of the airbox, folow that and it wil lead you to the pump. Pull the plug off the pump, if the noise stops then its that at fault.
| Thanks DGW, that sound about right except mine is a 1.6 not a 1.8t. Lummox, its not a sound I would attribute to a bearing but definatley a loud fan noise. Reading the above seems to make sense but I've never come accross this on any other car I've owned, i.e uno, pug 405, Saab 900, Golf, Espace, Zafira. Maybe I'll return to the owners manual and see if there are any references, but I don't remember any. Many thanks for your help Daz |
| | #6 | |
| Quote:
__________________ Denis 2002 Octavia 1.8T 4X4 turbo Estate - rebreathed on by Jabba ... 31.93mpg2007 Fabia vRS - CC, ESP and full leather trim by Seat Surgeons ...48.57 mpg... | |
| Like I said if you want to try it disconnect the plug on the pump in the evening so first thing in the morning it cant run, see if the noise goes away, bet it does.
| | #8 | |
| Quote:
Daz | |
| | #9 | |
| Quote:
| | #10 |
| Crikey! if it is at fault looks like I'll have to live with it. Daz |
| Introduction to the NEW Octavia | ColinD | Octavia II | 2 | 22-02-2007 20:09 |
| Bonnet air intake? | Thomas | Octavia I | 14 | 18-12-2004 11:06 |
| Ebay Again | Mavrik | General Car Chat | 67 | 19-09-2004 19:06 |
| Fabia 1.4 MPI Air Intake and EGR or ?!? | Akebono | Maintenance & Performance | 4 | 16-09-2004 13:20 |
| New Octavia In Detail | ColinD | General Car Chat | 0 | 22-04-2004 12:18 |
