Low Power on vRS
This is a discussion on Low Power on vRS within the Octavia I forums, part of the Skoda Model Discussion Area category; Drove to work this morning and the car was driving perfect, on my way home about a tenth into my ...
Old 17-05-2006, 23:08   #1
@(o_0)@
apinner's Avatar
Images: 8
Unhappy Low Power on vRS
Drove to work this morning and the car was driving perfect, on my way home about a tenth into my journey i noticed the octy seemed to be a bit low on power..
I have been out in it this evening and its not right at all, before you could hear the turbo spinning in all gears, now only a small amount in 1st and 2nd anything higher and its just a bit gutless..
sitting at 80 in 5th just in boost if you poked the throttle a bit it would surge and shoot off now it just drived like a standard none turbo car.
Any ideas guys? will VAG-COM tell me is something is up?
Alex
apinner is offline
Old 18-05-2006, 06:45   #2
Re: Low Power on vRS
Sounds like a boost hose has come off. It'd be louder too if it's that.
Parents: '02 Octavia 1.9TDi
Me: '99 V Honda Accord Type-R
Sheaf is offline
Old 18-05-2006, 07:39   #3
Cupra Bush King
Lummox's Avatar
Images: 2
Sounds like the ECU has shut down. MAF problems can feel like this but usually you can still hear it boosting. VAG COM will help in finding the cause. Have a search around for '17705' and see if anything sounds familiar.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is online now
Old 18-05-2006, 09:09   #4
@(o_0)@
apinner's Avatar
Images: 8
Second question, anyone near darlington/middlesbrough with VAG-COM willing to help out a fellow briskodian?
I drove to work this morning hoping it may have sorted itself.. normally if you floor it in second on a wet road the traction control light blinks like crazy.. nothing of the sort!
Alex
apinner is offline
Old 18-05-2006, 10:12   #5
@(o_0)@
apinner's Avatar
Images: 8
Someone at work came up with a suggestion, on his subaru if a sensor or something fails the ecu goes into a derated state to try and protect the engine. Does the octavia ECU do the same?
If so wouldn't i be seeing a engine warning light on the dash?
Alex
apinner is offline
Old 18-05-2006, 10:49   #6
BRISKODA Staff
SkodiRS's Avatar
If you say it feels like NA engine and you can't hear the dv venting...even in a standard car you can hear it a little..then it's gone into limp mode..i.e. ECU by passes/shuts down turbo...no lights come on....IIRC.....basically what Ross said.
IMHO.
*Note: all my usual disclaimers apply.
Adrian.
SkodiRS is offline
Old 18-05-2006, 10:57   #7
cheezemonkhai's Avatar
The Octy engine has a limp home mode.
cheezemonkhai is offline
Old 18-05-2006, 11:19   #8
@(o_0)@
apinner's Avatar
Images: 8
Its not limping.. its still quickish just not the same as it was in the morning.
Ah well i have booked it into the local skoda garage and they are going to diagnose the problem. Fingers crossed its not going to set me back a small fortune!
Alex
apinner is offline
Old 18-05-2006, 11:20   #9
Sounds like a hose problem to me. Without a diagnostic check it is difficult to tell though.
Goochie is offline
Old 18-05-2006, 15:56   #10
mattbeef's Avatar
Just have a quick look around the turbo and intercooler pipes and check all the connections
mattbeef is offline
Old 18-05-2006, 21:32   #11
wahey! bloke from middlesbrough at last ! tho i was only one here .. if i had the vag com i would help but i don't have it but u did the right choice to take it down our friendly skoda derek slack they will sort u out easy.
My octy vrs down derek slack garage at the mo for new front wheel bearing to put in and only cost me 119 quid all in . which i am surprise for a price !
the staffs is very friendly as well.
Rob
VW Touran 2.0 tdi sport 140bhp 6 speed
reflex silver
7 seater
rob-vrs is offline
Old 18-05-2006, 21:53   #12
@(o_0)@
apinner's Avatar
Images: 8
Yeah they werent too bad on the phone!
Middlesbrough eh, aint seen your around! yellow vRS's are quite distinctive. You probably live in one of the nicer parts, i am just off linthorp road in the hood!!
Only for a couple more months though then i go back to uni in huddersfield.
Alex
apinner is offline
Old 19-05-2006, 07:19   #13
i live not far from cineworld cinema mate. My octy vrs don't go out much as i have a other car which use to runner about in.
what colour your vrs mate ? so i will keep my eye out !
my is mellow yellow with private reg.
c ya around
Rob
reflex silver
7 seater
rob-vrs is offline
Old 19-05-2006, 09:20   #14
@(o_0)@
apinner's Avatar
Images: 8
Mine is black, only defining feature from standard is a 'all electric garage' sticker and 'skoda motorsport' sticker in the rear window.
Ill keep my eye out..
Alex
apinner is offline
Old 19-05-2006, 11:49   #15
@(o_0)@
apinner's Avatar
Images: 8
Well the garage just rang. Plugged in the ecu and it had a fault saying there was sparodic pressure in one of the turbo intake hoses.
No one could tell me if thats what was causing the problem, or if fixing the pipe would solve the issue as it may be masking another problem. So they advised the pipe be replaced next wednesday and run some more diagnostics.
But they are going to charge me £125 for the pleasure. And if that doesn't fix it then more on top of that.
pffftttt i have only had the car a fortnight!
Alex
apinner is offline
Old 19-05-2006, 18:50   #16
mattbeef's Avatar
Dang thats expensive i hope that its an expensive pipe they are putting on for you
mattbeef is offline
Old 20-05-2006, 14:14   #17
@(o_0)@
apinner's Avatar
Images: 8
i do too.. gold plated I would hope!
Alex
apinner is offline
Old 14-06-2006, 12:14   #18
Timo's Avatar
Did you ever find out what the problem was? Every now and then, Mine seems to go ok to 80, then even if change to 4th, won't go any faster. Nightmare if overtaking at the time.
Please tell me it was a cheap and easy fix.
Timo is offline
Old 14-06-2006, 16:52   #19
@(o_0)@
apinner's Avatar
Images: 8
Yeah.. it turns out its a common problem! search for "where does this pipe go" or something similar and you will find the pipe.
It goes into the bottom of the intercooler and apparently has a dodgy seal. It cost me £38 for the pipe and took me 15 minutes to fit using nothing more than a trolley jack, axle stands and a flat head screw driver.
Alex
apinner is offline
Old 14-06-2006, 17:18   #20
DGW
BRISKODA Staff
DGW's Avatar
The modified pressure hose part number is 06A 145 790C.
Denis
DGW is offline
