MAF Problem returning?
This is a discussion on MAF Problem returning? within the Octavia I forums, part of the Skoda Model Discussion Area category; Heya. Sorry about the constant posts - having loads of problems with this car! When i bought the 1998 1.9TDI ...
Old 31-05-2006, 21:56   #1
Unhappy MAF Problem returning?
Heya.
When i bought the 1998 1.9TDI 3 weeks ago, the non-skoda dealer changed the MAF as I'd complained that it was running flat, with instant improvements.
Now it appears to be back - running VAG-COM the airflow very, very rarely goes above 550 - indeed, it seems to get stuck at this value.
Is there anything, apart from the MAF, that could cause this? Dealer's being an about warranty repairs as the car has already cost him £130 in fixing a RELAY 109 problem cos his engineer didn't know about it, when the car cost 2.5k
Otherwise, where is the best place to get a new MAF from? Based in Pompey, so a local walk in place would be excellent!
Oh - and disconnected the MAF and performance improved - it's currently in a bath of electrical contact cleaner....
Cheers,
Wolfsbane2k
1998 Octavia 1.9TDi GLX
In the process of building a Carputer into it
Wolfsbane2k is offline
Old 01-06-2006, 00:23   #2
cheezemonkhai's Avatar
Re: MAF Problem returning?
Eurocar parts in southampton have them and are cheap compared to a dealer.
Suggest taking your MAF out and cleaning it with something like isoprop. (Take the MAF off, put it in a freezer bag, pour ina bit of Isoprop and give it a shake around, take teh MAF out and let it dry off, then put it back). Obvioulsy done at your own risk but others on here have used this to correct MAF problems.
Other things, I ignore the 40k air filter change on my 1.9TDI and change it a lot more often. The perfomance on mine was attrocious until i changed the air filter.
cheezemonkhai is offline
Old 01-06-2006, 13:55   #3
General Notice to anybody cleaning the MAF.
If the cleaner comes in contact with the sealant, it is likely to perish the sealant. Protect the sealant in something before shaking the MAF around in Contact Cleaner!
This is from experience - i left the MAF standing in a pool of cleaner for a minute and then shook it about to clean it, but having left it for another minute while making a cuppa tea the sealant perished.
I've have therefore had to strip and re-seal the entire MAF using high pressure vulcanised rubber sealant, which is horrible stuff and a pain to clean.
Oh - but at least it cleaned the MAF and it all works again!
Old 01-06-2006, 14:24   #4
what cleaner did you use? I am suprised a little isoprope would rip the sealent apart that quickly.
Old 01-06-2006, 15:43   #5
Maplins Electrician's Contact Cleaner, comes in a spray can.
http://www.maplin.co.uk/Module.aspx?...eaners&doy=1m6
Old 02-06-2006, 22:33   #6
mbames's Avatar
* Does not cause corrosion
but does like to destroy the sealant!
mbames is offline
Old 02-06-2006, 22:54   #7
I can honestly say i have used isoprope on many seals on old car and never had an issue, leccy contact cleaner i havn't used but guess there may be something else in it.
EDIT:
-->> Ideal for removing grease oil,dirt,stains and coating
that would kind of imply to me that it might damage sealant since they are often oil bbased and anythign that can take a good coating off is pretty nasty. Me thinks it isn't jsut isoprope.
This stuff sounds safer as does plain old isoprop:
http://www.maplin.co.uk/Module.aspx?...0056&criteria=
Old 20-08-2006, 21:13   #8
splash!!!!
bengie's Avatar
with that spray stuff could you just hold the maf and spray this stuff in through the middle to clean the maf's sensor thingy?
owner of a skoda octavia 4xvrs3
bengie is offline
