MAF sensor
This is a discussion on MAF sensor within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi everyone, I am new to this site and this is my first posting. I drive an Octavia 1.9 tdi ...
Old 14-01-2008, 15:16   #1
MAF sensor
Hi everyone, I am new to this site and this is my first posting. I drive an Octavia 1.9 tdi and it would seem that there is a problem with the MAF sensor. After reading several threads on this subject I tried disconnecting it. I drove from London to Lancashire with it disconnected and the Car performed much better. The car still lacked guts however and when on a steady uphill slope cannot seem to get much power and won't go much past 85 mph even with foot to the floor. I plan to replace the MAF but would be interested to hear if there might be another fault aswell or will performance improve with a new sensor? Also, can anyone tell me the purpose of the MAF sensor? If the car runs fine with it disconnected then why not just leave it disconnected? Any help will be much appreciated as I do that journey 3 times a month. Cheers all.
badger7 is offline
Old 14-01-2008, 16:04   #2
Why So Serious
fatty5000's Avatar
Re: MAF sensor
MAF = Metered Air Flow unit Basiclly it measures th air flow into your engine which in turn allows the ecu to to put in the right amount of fuel for the mixture. The reason why the car runs better with it disconnected when faulty is because the ecu has a set of measurements built in so it kind of knows how much fuel with however many revs (if you get me).
You can't leave it uplugged as it will throw a fault code and you mpg will drop as the ecu is really just guessing how much air and therefore fuel you need.
Hope this makes sense and helps you
fatty5000 is offline
The Following User Says Thank You to fatty5000 For This Useful Post:
badger7 (15-01-2008)
Old 14-01-2008, 16:12   #3
cjb
Re: MAF sensor
The car will perform badly with the MAF unplugged, but if it's better than with it plugged in, replace it.
-- Chris
The Devil may care, but I don't mind.
cjb is offline
The Following User Says Thank You to cjb For This Useful Post:
Old 15-01-2008, 05:21   #4
Not anymore
Taxi 219's Avatar
Re: MAF sensor
As above yes replace the MAF sensor.Might also be worth checking your Air filter too.
Car now: 56 Octavia MK2 1.9TDi Ambiente-Debadged-Metallic Flamenco Red DMF Reqiured soon
Previous: 06 Octavia Mk1 1.9TDi Classic with + pack-Diamond Silver
Sadly missed: 97 Nissan Primera 2.0TDi SLX- Red
Paul
I only live for GTA IV
Taxi 219 is offline
The Following User Says Thank You to Taxi 219 For This Useful Post:
Old 15-01-2008, 11:30   #5
Re: MAF sensor
Thanks a lot guys. Obviously will have to replace the MAF.
Cheers again.
badger7 is offline
Old 16-01-2008, 00:38   #6
Ta moko!
RobClubley's Avatar
Re: MAF sensor
Check your hoses too and look for splits or hoses that have come loose.
I assume a diesel turbo will behave in a similar fashion to a petrol turbo if there's a boost leak.
Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand!
Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge
www.pimpmyskoda.co.uk www.clubley.org Facebook
RobClubley is offline
Similar Threads
MAF sensor Danv6saxo Diagnostics & VAG-COM 6 02-10-2007 18:00
MAF sensor location? colkai Fabia I 8 29-04-2007 17:16
MAF sensor zebedee Octavia I 1 20-04-2006 19:48
Where's the MAF Sensor in my Fabia? misael78 Maintenance & Performance 0 06-05-2004 15:44
