This is a discussion on max power within the Octavia I forums, part of the Skoda Model Discussion Area category; just wondering what is the max power you could get out of a 1.8t engine and what sort of upgrades ...
| Briskodian Join Date: Apr 2008 Location: south birmingham
| just wondering what is the max power you could get out of a 1.8t engine and what sort of upgrades and money are we talking to get there can you help i.e turbo, remap, dv, intercooller and all the other bits and bobs?what sort of mods have you done and how do they effect the car and which do i do first to gain more bhp? Last edited by 4x4mark; 22-04-2008 at 23:48. |
| Ta moko! Join Date: Jun 2004 Location: Aotearoa - land of the long white cloud
| Do a search for Eddyh's 4x4 - he's recently sold it but it's running 460bhp. The JBS demo car managed over 600. Big money though!!
__________________ Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand! Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge www.pimpmyskoda.co.uk www.clubley.org Facebook |
| The Following User Says Thank You to RobClubley For This Useful Post: | 4x4mark (24-04-2008)
| Ex-Moddy Join Date: Jul 2005 Location: Hampshire
| But they are not a 'true' 1.8T lump as they have been so heavily modified imo + the money spent on them runs into many thousands!
__________________ Black magic Octy II vRS MY2008 with Maxidot ~ Xenons ~ Cruise ~ Light Assist ~ Dual Zone Climate Control ~ Rain Sensing Wipers ~ MFD2 Satellite Navigation ~ VAG Bluetooth Phone Kit ~ Milltek Exhaust with 2.75" Downpipe ~ EVOM Ram Air Intake ~ Nuespeed Shortshifter ~ Eibach Rear ARB ~ Koni FSD Dampers ~ Eibach Springs ~ Forge Front Mounted Twintercooler ~ Nuespeed Hi-Flo Intercooler Pipe ~ Nuespeed Hi-Flo Turbo Outlet Pipe ~ Eurojet PCV Valve ~ Forge DV ~Autotech Hi Volume Fuel Pump ~ Nuespeed Torque Arm Insert ~ NGK Iridium Spark plugs ~ REVO Stage II+ Software ~ Matt Black Viper Stripes! |
| The Following User Says Thank You to Makefish For This Useful Post: | 4x4mark (24-04-2008)
| True. The biggest gains for a reasonable amount of cash on the 4x4 will be had from a remap. From 250-500 quid gets you up to around the 200bhp mark. Without changing turbos and spending big money, other mods give you minor gains - TIP and air intake maybe 5-10bhp (150-300 quid) Exhaust maybe 15-20bhp for 500 quid or so.
| Briskodian Join Date: Jan 2003 Location: Winchester
| 350 bhp will cost around 10K but negotiable http://briskoda.net/forums/skoda-car...ctavia/107986/ If doing it yourself remember Suspension & Brakes all need looking at. When I started my project I had spent well over 3000 on the brakes & suspension before the car had its initial remap to 225 bhp. Standard internals are not safe much over 300 bhp & the Gearbox is also on its limit with engines around that bhp but its the torque you have to look at more critically on gearboxes. A good mapper will bear this in mind when mapping the car.
__________________ Speed is an addiction for which thankfully there is no cure |
| The Following User Says Thank You to Stuart_J For This Useful Post: | 4x4mark (24-04-2008)
| so just in a remap i could achieve an extra 50bhp thats quite a lot the other mods are quite expensive for what bph you gain i bet eddy's car flew man that must of been quick do all 6 speed boxes fit a 4x4 or do you have to get the 4x4 one? |
| Briskodian Join Date: May 2006 Location: tunbridge wells
| Anythings possible within the VAG parts bin i've read that a lot of people use the 6 speed diesel gearbox. check out VW tuners they've been sticking the 1.8T in everything from polos to mk1 golfs the latest issue of Performance VW has 3 cars all pushing 300bhp !!!! |
| The Following User Says Thank You to jiggad23 For This Useful Post: | 4x4mark (24-04-2008)
| The 4x4 is 150 bhp std as you know A good tuner with a custom remap should be able to stretch the car to as much as 220 bhp but its not just the headline figure, it completely transforms the driveability of the car. The addition of a decent free flowing exhaust will see probably another 20-25 bhp. The other mod worth doing is to fit a front mounted intercooler. I did my first Cannonball with simply a remap (+suspension & brake mods). Even with just the remap the car was very sensative to heat & as the temps rose the performance definately suffered. At some point after that the clutch will die, you can carry on with std clutches but bargain on 30-40K per clutch & thats without drag starts. A cheaper but perfectly adequate upgrade is to fit the Corrado G60 clutch & flywheel, its a common mod & cheaper than a performance clutch, its also not too heavy. It wont cost a massive amount more than a std clutch After that the mods start to cost a lot more but if you can afford it they really make for a very quick & enjoyable road car. If you are looking to do the exhaust do it before the cars remapped to get the best from the remap. Beware of cheap remaps, the car will be better but theres no sunbstitute for a good tuner sticking your car on a rolling road & remapping it, it will guarantee to get the best from the car & also identify any problems you already have. Whenever tuning dont concentrate on just the bhp figures, you need a very wide powerband to give you a car to drive quickly hense the reason I went for the IHI kit. It only gives 350 bhp but makes for a very driveable car. Big power cars often take time to wind up by which time you are long gone ![]() ![]() Re Gearboxes most 6 speed boxes from the 4WD cars will fit, I went for a TT box as I was offered a low mileage box for good money, they are really very cheap but its not a straight swap in the 4x4, drive shafts, prop shafts, starter motor, linkage etc etc all need changing. Its a 2K job If taking the box from a Diesel they are definately stronger but the downside is that because a diesel revs lower the ratios are very different & will stifle a car unless it has a very large increase in power. The std 4x4 box is well capable of handling 300 bhp & if the ratios are too low the gear cluster from the VRs fits in the 4x4 box. The only weak point is the diff & if you have the box in bits a good mod is to remove the rivets from the diff & replace them with bolts. Hope this helps Stuart
| The Following 2 Users Say Thank You to Stuart_J For This Useful Post: | 4x4mark (28-04-2008),
RobClubley (25-04-2008)
| thanks guys learnt that a remap and maby a dv is proballly the best for me as i dont want to spend £1000's |
