This is a discussion on Melting battery terminals within the Octavia I forums, part of the Skoda Model Discussion Area category; Have just noticed that the plastic surrounding the leftmost fusable link (110 amps) in the distribution block above the battery ...
| Briskodian Join Date: May 2003
| Melting battery terminals Have just noticed that the plastic surrounding the leftmost fusable link (110 amps) in the distribution block above the battery is melting on my Octavia 1.6. The dealers just replaced the complete distribution box on a coworkers Octavia for the same fault and I decided to go and check mine... and the plastic on mine is melting too! I sanded the surfaces clean, cleaned them with contact cleaner and retorqued the nuts, so I'm hoping it will not get worse. I'd advise everyone to go and check the same on their Octavia.
__________________ Francis Octavia Ambiente 1.6 Auto, Trinidad and Tobago |
| Briskodian Join Date: Jul 2005 Location: UK south east
| Re: Melting battery terminals We get this problem regularly on our SDI Octavias, once they've done that bit, the battery cable itself will start melting, then when thats replaced the other bit will melt again, repeat add infinitum! Obviously a serious design flaw somewhere! (it should be noted however that our cars have a fair amount of electrical equipment in them, drawing more power than usual) |
| Re: Melting battery terminals Ford Galaxys have a similar problem on the PD engined ones
__________________ not so bored now |
| Re: Melting battery terminals caused simply by a bad connection. as you say probably a design flaw somewhere.
| Re: Melting battery terminals I'd insist on a proper solution. Not great to have that kinda energy going through dodgy connections/cables. Aren't electrical faults meant to be the domain of the French cars ![]() Thing I dont quite get though is why replacing cable + melted bits at the same time wouldn't sort it? If it doesnt sort it the cable is not big enoughand/or the clips are cr*p.
__________________ WW --->> Project Journal (pic links in first post there)Lummox'/Ross thread on Unit18 Automotive progress on my car: here |
