Metal impeller for vRS water pump?
This is a discussion on Metal impeller for vRS water pump? within the Octavia I forums, part of the Skoda Model Discussion Area category; Water pumps just gone for a sh!t.......Im well pi$$ed off!!!! ....Just hoping I aint fu*ked the head gasket up..... Is ...
Old 08-04-2007, 22:28   #1
Silver bullet
Steevie Wonder's Avatar
Angry Metal impeller for vRS water pump?
Is there anywhere where I can get an up-rated water pump from.....preferably one with metal impellers rather than the standard plastic ones?
I had mine replace last under warranty October 2003 (only 12,000 miles done!), has the water pump been modified in any way since this time, or is it still the same $hit being used?
Cheers
The silver bulletJabbasport's; IHI Stage 3 vf34, ceramic lined manifold, F.M.I.C, boost controller, Snowperformance methanol injection, ABD Racing ceramic inlet manifold & CAI, K&N monster filter, 02M 6 speed TDi gearbox, Peloquin a.t.b, Sachs SMF & sports clutch, Forge quickshift, APR R1, Blueflame 3" d/p, 100 cell cat, Milltek 2 ¾" system, Samco; i/c, turbo & boost hoses, Bosch 440cc injectors, 3" M.A.F, SuperPro bushes all round + engine mounts, Weitec coilovers, Eibach rear arb, AP Racing 6 pots & 335mm floaters, S3 top & bottom braces, Nomad; turbo, oil pressure, oil temperature & battery gauges.
Steevie Wonder is offline
Old 08-04-2007, 22:30   #2
Briskodaholic
Tom_vRS's Avatar
Re: Metal impeller for vRS water pump?
GSF Car Parts, cheap car parts direct to you should help you out. If you register with your Freedom info you will get 10% discount too!
EDIT to add, there isn't a genuine metal water pump available, only aftermarket ones.
97/R BMW 328i in Boston Green.
Tom_vRS is offline
Old 08-04-2007, 23:20   #3
NOW @ PEUGEOT
piv34uk's Avatar
Use FIRST LINE myself, based in Bicester but not open till Tuesday....sorry
Phil
1)RED ONE, FEW MODS; AND A HEALTHY 237bhp
2)GONE BUT NOT FORGOTTEN, 2ND OWNER OF THE BLACK BEAST, GOD WHAT A HOOT
LACK OF PLANNING ON YOUR BEHALF DOES NOT CONSTITUTE AN EMERGENCY ON MINE
piv34uk is online now
Old 08-04-2007, 23:20   #4
Moderator
Bigw2069's Avatar
There are Audi equivalents that fit though with metal impellors
Bigw2069 is offline
Old 08-04-2007, 23:23   #5
DGW
BRISKODA Staff
DGW's Avatar
I had mine replaced last year with the modified plastic OEM one.
Denis
DGW is offline
Old 08-04-2007, 23:26   #6
Need more power
martziniuk's Avatar
AVS Car Parts - www.vwspares.co.uk
martziniuk is offline
Old 08-04-2007, 23:36   #7
mattbeef's Avatar
I had an OEM one fitted to mine as i requested and it was a plastic one one or so i was told
I few bits here and there but im happy to Performance Torque
Go on click me you know you want to
mattbeef is offline
Old 09-04-2007, 02:40   #8
There is a reason why the impeller is plastic....
Should the bearings go the impeller will just break up and not seize the belt. Potentiallly saving your motor
John
goodridge is offline
Old 09-04-2007, 09:06   #9
Liverpool-Lad's Avatar
John
Hmmm, surely though the toothed pulley and the impeller are on the same spindle. If the bearing goes the lot is going to jam and throw the belt off.
2001 Rally Red Octavia vRS...remap complete Whiteline rear ARB, Superpro dogbone bush - 225/45/17 Goodyear Eagle F1 Aysmmetrics and lots of V-Power!
Smiles all 'round
Liverpool-Lad is offline
Old 09-04-2007, 09:13   #10
Cupra Bush King
Lummox's Avatar
Images: 2
Exactly, if the metal impellor just comes off the spindle it will just sit there in the housing with the shaft spinning inside it. The plastic POS OE one however breaks up into little bits and jams the thermostat.
And as far as I know Audi dont fit the metal type, its not a VAG part.
Unit 18 Automotive Services
www.unit18.co.uk
Lummox is offline
Old 09-04-2007, 09:21   #11
Escorted Estate
I have seen some failed plastic impeller ones already and based on that I replaced mine with a metal impeller one when it made sense (cambelt change time).
Thermostat failure has cost me a LOT on my car, due to the stuff I've got on the engine it didnt help that the temperature sensor is in a place where your top end of the engine can be cooking without the temperature even going over 90C..
WW --->> Project Journal (pic links in first post there)
Lummox'/Ross thread on Unit18 Automotive progress on my car: here
WW_VRS is offline
Old 09-04-2007, 09:40   #12
skodaw's Avatar
Location: This area is under construction - please call back later :)
Correct - they use the same plastic impeller type pump also. Eurocar Parts also do a metal impellar type pump.
Dave
'05 Silver Fabia vRS
skodaw is offline
Old 09-04-2007, 10:05   #13
Hardcore
Basil's Avatar
So what is better - metal or plastic? Which could theoretically cause the greatest damage in case of failure?
(I need things spelt out for me more often that I care to admit.....)
Bas
Fab vRS - Black Magic - PD160 intake - Forge FMIC - colour coded front grille -SLC Splitter - K&N Airfilter -SEAT Strutbrace - Jabba ARB - IC Waterspray (need to wire it in!) - 312mm TT brakes - Eibach Springs - Skoda Reversing sensors - Devonutopia Tuning (tm) Custom Exhaust (2 1/4" straight pipe) - Short shifter mod- 5 brake light mod - Helix Steel SMF + Organic Clutch + pressure plate - Peloquin LSD - TD stage 2 Hybrid - Washbrook remapped ECU - Uprated injectors - Cupra bushes -Poly-filled dogbone - Allard racepipe - Pirelli Dragons - Forge Rear Strutbrace - DIY SS upper boostpipe delete -Koni FSD's - elephant pipe CCV mod
Basil is offline
Old 09-04-2007, 10:08   #14
Mongreller
devonutopia's Avatar
Images: 5
I think metal is longer lasting/fails less, which is why I got one from GSF for my car. Not sure on the "what ifs" - I prefer to be optimistic and not think about the failures too much.
Jason - Mongrel owner! WOOOOF! Grrrrr
Custom Fabia Bonnet Lifter Kits - £45! Click Me.
Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc
See the mongrel's 260bhp Dyno Video!
devonutopia is online now
Old 09-04-2007, 10:10   #15
Escorted Estate
Metal one gets my vote any day. Replace as you would normally so when cambelt is changed do the pump at the same time (and other bearings etc). Doesnt cost a lot more, and failure is vastly more expensive.
I am starting to wonder if it's worth replacing the thermostat on every major service or so for this reason
WW_VRS is offline
Old 09-04-2007, 11:03   #16
Groundzer0's Avatar
Hi I intend for Awesome GTI to replace my water pump with a metal one when I take it for a new cambelt at the end of the month. At £330 for the belt tensioners and water pump it isn't cheap but the do guarantee the work so it has its benefits. When I was talking to them about it they told me that on every water pump they have changed there has always been one of the impeller fins that have come away. As you need to changed the cambelt at the same time it makes sense to me.
Black Mk1 Octavia vRS
Black is the new...........Er!!!
Groundzer0 is offline
Old 09-04-2007, 12:36   #17
Moderator
Bigw2069's Avatar
In that case someone has been telling me porkies, just checked my invoice and I have the part number 045121011H, I know for a fact it has a Metal impeller as I seen it before it was installed and I'm pretty sure it was in a VAG box.
Bigw2069 is offline
Old 09-04-2007, 15:30   #18
Silver bullet
Thumbs up Re: Metal impeller for vRS water pump?
Originally Posted by martziniuk View Post
Just ordered it!!!
Cheers
Old 09-04-2007, 16:45   #19
Too Many Organs
biomulv's Avatar
My vRS is going in for its service / belt change at the dealers soon.
When I asked to make sure they change the waterpump for a metal at the same time they said " no, we never do that. No need for it" , " are you sure" I reply. "Oh yes , its not necessary" - OK , indulge me then and fit one I supply. Which they are gonna do. Glad i asked.
Work - 2008 VW Golf Estate 1.9tdi SE spec with bluetooth and park sensors
Wifes Runabout - 2005 Red Fabia vRS
Wifes Old Runabout - 2003 Black Octavia vRS on 18" RS6's
biomulv is offline
Old 10-04-2007, 11:40   #20
This might seem a silly question but how would you know if your engine got too hot after a failure?
It seems to me that if there is a water pump failure it sometimes only gets too hot if your travelling fast fast. Keep it under 50 mph and the temperature doesn't go up.
What signs are there that the engine has been damaged?
Thanks
savanaman is offline
Old 12-04-2007, 11:57   #21
Silver bullet
The answer to my problem....
The Following User Says Thank You to Steevie Wonder For This Useful Post:
morgan349 (02-06-2007)
Old 12-04-2007, 17:04   #22
willy0329's Avatar
Personaly i would go for the metal type impeller when these start to fail you will get a grinding/knocking noise and know you have a problem before u boil your engine .with the plastic one you get no warning as people have said the fins fall off and u dont know till suddenly your temp gauge shoots up the damage may already be done as these engines run very hot and the thermostat is in a poor position.
willy0329 is offline
Old 13-04-2007, 16:20   #23
Timo's Avatar
Trust me, if the pump goes, tick over is fine, as soon as you put any revs on, you'll know
Timo is offline
Old 13-04-2007, 17:23   #24
Briskodaholic
Tom_vRS's Avatar
http://www.briskoda.net/forums/gener...olo+water+pump
Thats why I'd get a metal pump every time!
Tom_vRS is offline
Old 02-06-2007, 21:52   #25
morgan349's Avatar
what supplier is this one from? if gsf have them what is thier part number?
thier site only shows the placcy one
morgan349 is offline
