This is a discussion on Metal impeller water pump ?? within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi, Does anyone know a source and/or part numbers for water pumps with a metal impeller instead of the standard ...
| Briskodian Join Date: Jun 2006 Location: Melksham
| Metal impeller water pump ?? Hi, Does anyone know a source and/or part numbers for water pumps with a metal impeller instead of the standard plastic?? 2002 vRS AUQ engine. Cheers! Rich |
Images: 2 Thanks: 22
| Re: Metal impeller water pump ?? First line make em in Oxford iirc. Quite a few motor factors stock them.
| Site Sponsor Join Date: Mar 2006
| Re: Metal impeller water pump ?? Hi Yes GSF I do believe. Sarah |
| Re: Metal impeller water pump ?? ok thanks for replies! I'll have a ring round. Eurocarparts possibly? |
| Re: Metal impeller water pump ?? Yes could possibly be. Get them to check before you part with your money though Sarah |
| Re: Metal impeller water pump ?? Eurocarparts do one - £24 All VAG supplied ones are plastic as far as i can understand from asking them. |
| Re: Metal impeller water pump ?? Hi Mate Yes as far as I am aware all OEM ones are still pplastic. Glad you got one. ![]() Sarah |
