Mintex 1144 or Ferodo DS2500...
This is a discussion on Mintex 1144 or Ferodo DS2500... within the Octavia I forums, part of the Skoda Model Discussion Area category; Hi guys, Im going to have my 312mm setup installed up front during the service next week. Now Ive been ...
Old 03-02-2006, 13:12   #1
FocusZtec's Avatar
Question Mintex 1144 or Ferodo DS2500...
Hi guys, Im going to have my 312mm setup installed up front during the service next week. Now Ive been thinking, if Im going to pay the labour I may as well have some aftermarket performance orientated pads put in instead.
My decision lays between getting the Mintex 1144's for £80 or the Ferodo DS2500's for £130. Now I am guessing most of you will say ultimately the Ferodo's are superior but are they £50 superior? I know thats hard to quantify but the £50 difference will pay the labour for the brake fitment so Im thinking of making the saving here and going for the Mintex's?
Do any of you have experience of these pads or ideally, of both of these pads?
Cheers for any help/advice in advance,
Lee
http://img.photobucket.com/albums/v610/FocusZtec/neiloctypipersignature.jpg
Thanks to JKM:
REVO STAGE 2+ remap, Evoms CAI, Piper Turbo back Exhaust, Autotech Fuel Pump, Torque Arm Insert, Forge Recirc, Neuspeed Turbo & Intercooler pipes, APR FMIC, Iridium plugs, Koni FSD's, Eibach springs, Eibach F + R anti roll bars. VF short shifter. 345mm Brakes. 280BHP & 330LB/FT - enough room for a proper trip to B&Q and 36mpg on a run!!!
FocusZtec is offline
Old 03-02-2006, 14:37   #2
MC Bodge's Avatar
Re: Mintex 1144 or Ferodo DS2500...
I had some Ferodo pads for my Focus which had very good bite and fade resistance. I'm not sure what the part no. was. They were only ~30quid for a front or rear set from Halfords, which sounds a lot cheaper.....
Do 'performance' pads need warming up before they're effective?
Mk1 Octavia vRS. The thinking man's Hot Hatch.
PS. Give Cyclists Room! We're quite vulnerable. If I can slap your window, you're too close
MC Bodge is offline
Old 03-02-2006, 15:39   #3
FocusZtec's Avatar
At £30 Im guessing they would have been direct OEM replacement pads but good initial bite is important although fade free braking is what Im really after. As to how much warming up they require Id say it depends on the compound of the pad itself. Harder ones will take longer to get the heat through them.
Im swinging towards the Mintex at the moment.
Lee
Thanks to JKM:
Old 03-02-2006, 16:42   #4
FocusZtec's Avatar
... or after reading opinions on here regarding the standard 312mm setup I could save £80 further and keep the standard pads. Hmmmmm...
Thanks to JKM:
Old 03-02-2006, 18:23   #5
CupraR-Rog's Avatar
Brunty 2004 - went there with 1 week old Mintex pads on my Brembo's...
Pads were useless on the road (loads of fade!), and melted(!!) on the 1st track session!! By session 3 they were completely worn out!
Brunty 2005 - Went there with 10,000 mile old Ferodo DS2500 pads, still on Brembo's...
A full day of track action later (running mostly on slicks), and the pads were still on the car about 8,000ish miles later when I sold the car!! No fade from the pads no matter how hard I abused them!! Boiled the fluid tho...
Some people say I'm stark raving bonkers...
...the others just smile and nod...
CupraR-Rog is offline
Old 03-02-2006, 18:39   #6
FocusZtec's Avatar
Interesting post, thanks for that.
Were the Mintex ones 1144's though?
Im never going to take the Octy on track tbh. Maybe I'll use the new standard VW spec pads in the 312mm setup and see how they go. Then I can change them out myself if Im dissapointed.
Thanks to JKM:
Old 03-02-2006, 18:48   #7
CupraR-Rog's Avatar
Fitted them the day after they arrived, and a week later the burnt remains were hitting the bin - never checked the exact compound, but they were that rubbish on the road that I would never touch any Mintex pad again!
Made for Brembo fitment, but couldn't take standard road, yet alone any sport type of driving!! (So, maybe I should have binned them before the track day...)
Old 04-02-2006, 08:41   #8
My votes with Ferrodo, Ive never tried the Mintex but run Ferrodos all the time & they are brilliant, Im running 335 discs & as for wear I got through 2 sets in about 40000 miles & at the end of the second set I needed new discs as well. I dont really mind as the stopping power is brilliant, Ive never had any fade, even on the track. I had a car pull out into the fast lane on an Autobahn when I was flat out & had all tyres howling trying to stop, 150 down to about 70 on initially cold brakes.
Speed is an addiction for which thankfully there is no cure
Stuart_J is offline
Similar Threads
Ferodo DS2500's front and rear? vRS_Si Octavia I 16 20-08-2005 14:31
Ferodo DS2500 Brake Dust? Liam Maintenance & Performance 21 14-08-2004 00:39
Ferodo DS2500 bedding-in SimonT Maintenance & Performance 1 07-04-2004 08:07
Partnumber on Ferodo DS2500 for the RS front? Turbo² Maintenance & Performance 7 07-05-2003 15:13
