Misfire/stutter after high revs?
This is a discussion on Misfire/stutter after high revs? within the Octavia I forums, part of the Skoda Model Discussion Area category; Recently my Octy 1.8t has developed an odd fault. After revving between 4.5-5.5 k the engine seems to stutter (not ...
Old 27-10-2007, 11:08   #1
Bottler's Avatar
Recently my Octy 1.8t has developed an odd fault. After revving between 4.5-5.5 k the engine seems to stutter (not sure if is is a misfire or not) I get rough running at all revs until the car has been stopped and left for a short while. It then runs as normal, smooth as anything.
The car is a standard 1.8t petrol Elegance. I have done a search on the site but none the wiser. No fault codes have appeared when it was recently checked over by the RAC after a coil packed up. (other than the coil of course). Any ideas?
Cheers
Bottler is offline
Old 27-10-2007, 12:10   #2
Re: Misfire/stutter after high revs?
Similar to how mine runs sometimes. I'v put it down to a dodgy MAF sensor but i think i'll wait untill i get it remapped and change it at the same time.
Darren
V666 VRS is offline
Old 27-10-2007, 12:58   #3
Bottler's Avatar
Thanks, would be interesting to know how that goes.
Bottler is offline
Old 27-10-2007, 13:22   #4
Had a similar occurrence with my 1.8t as well. It came after a prolonged period slow driving, probably plug fouling. After a period of fast driving it runs as normal
Braff is offline
Old 27-10-2007, 15:11   #5
Fezboy's Avatar
I would have thought best check the plugs first.
Is it the same as when you have a coil pack go?
Octavia VRs ***SOLD***
The futures somkey! The futures diesel
Fezboy is offline
The Following User Says Thank You to Fezboy For This Useful Post:
Bottler (28-10-2007)
Old 28-10-2007, 13:20   #6
Bottler's Avatar
No it seems like a fuelling problem, rather than the misfire I had with the coil. I will check the plugs as they have not been changed since 65k I think, now on 82k
Thanks
Bottler is offline
Old 28-10-2007, 15:20   #7
Need more power
martziniuk's Avatar
Have you tried to clean the throttle body?
They get gunked up.
Regards Martin
Turbo back blueflame exhaust ,Forge 007p Dump valve,Prosport boost gauge, Autobahn88 TIP, Ecu Evolution Remap, FMIC
martziniuk is offline
The Following User Says Thank You to martziniuk For This Useful Post:
Old 28-10-2007, 15:55   #8
Still a ****
delcac's Avatar
Try re-gaping your plugs to 6.5.
The Red Devil
delcac is offline
The Following User Says Thank You to delcac For This Useful Post:
Similar Threads
Misfire scottie vrs Octavia I 0 01-10-2007 21:42
Misfire Octygone Maintenance & Performance 6 01-04-2007 14:47
possible misfire bub Octavia II 3 11-07-2006 20:23
Burning Clutch with high revs - any potential problems? sixman9 Octavia I 5 15-02-2005 15:36
