This is a discussion on Mk1 vRS naff FM radio reception! Need help! within the Octavia I forums, part of the Skoda Model Discussion Area category; Whats the deal with the crap reception on the radio in the mk1 vRS, my mate has one and his ...
| Briskodian Join Date: Jun 2006 Location: Nottingham
| Mk1 vRS naff FM radio reception! Need help! Whats the deal with the crap reception on the radio in the mk1 vRS, my mate has one and his is the same, mines got an Alpine and his has the standard tape and multichanger and the radio is crap! Does anyone know how to sort it all out coz its getting on my nerves, already used the FM booster things off ebay which do feck all! Any help would be appreciated!
__________________ 2.3 Litres with 28PSi boost = Toodle Pip! ![]() Harmon Kardon AS3 Audio, Bi-Xenons, Heated Aero Leather, 280BHP + 400NM |
| Briskodian Join Date: Jun 2007 Location: cornwall
| Re: Mk1 vRS naff FM radio reception! Need help! When the alpine was fitted did it have the arial amplifier adaptor fitted.Without this you will never get good reception.They are about a tenner and you plug the arial into it and send 12 volts through another small wire to feed power to the amp. |
| Re: Mk1 vRS naff FM radio reception! Need help! Not quite the right terminology, but reasonable correct description. Essentially if you change from the factor fit head unit then you need to have a power injector unit fitted inline between the new head unit and the aerial cable. This sends power to the amp at the base of the aerial at the back of the car. if your mates one is rubbish with the factor fit, then maybe his is either now supply power, or the amp at the aerial base has failed. |
| Briskodian Join Date: Jul 2005 Location: Edinburgh, Scotland
| Re: Mk1 vRS naff FM radio reception! Need help! I'll add a bit more to that - VAG aerials around 2000 were prone to leaking water into the head amplifier so that even if you do supply them with 12V they still don't work !! Rob |
| Re: Mk1 vRS naff FM radio reception! Need help! arh.... which might explain why mine seems to have got a bit worse over the last few weeks (unless the cold weather is going to make radio 1 a bit more crackly....) - pioneer head unit and power injector unit fitted. |
| Briskodian Join Date: Jun 2006 Location: Melksham
| Re: Mk1 vRS naff FM radio reception! Need help! I was under the impression 2000-2002 cars didnt have an amplifier in the aerial base... ? |
Images: 2 Thanks: 22
| Re: Mk1 vRS naff FM radio reception! Need help! They all so as far as I know. But when they get folded down water gets into the screw thread. Then when the aerial is screwed back down it hydraulics the bottom of the base and breaks.
| Re: Mk1 vRS naff FM radio reception! Need help! ah.. ok. I will check mine then, as my reception is poor too with an aftermarket head. |
| | #9 | |
| Re: Mk1 vRS naff FM radio reception! Need help! Quote:
When I bought my Y/2001 Octy it already had an aftermarket (pioneer) head unit. A few weeks later when I was having handsfree kit fitted I mentioned it to the installer chap and he suggested the power injector jobbie. He happened to have one with him, and fitted it there and then. That improved my radio reception no end. | |
| | #10 | |
something like this then..? Antenna Aerial Adaptors ![]() | |
| | #11 |
| Re: Mk1 vRS naff FM radio reception! Need help! that looks almost exactly like mine (from what I can remember!) I think he just sourced the power from the Antenna feed from the back of the head unit |
| | #12 |
| Re: Mk1 vRS naff FM radio reception! Need help! |
| | #13 |
| Briskodian Join Date: Apr 2007 Location: Hampshire
| Re: Mk1 vRS naff FM radio reception! Need help! Folks, I bought one of them to boost my reception on my Octy VRS with its standard head unit. It did bugger all effect. Actually it made it worse as it was trying to boost an already boosted signal( strange i know) I ended finding that indeed the original amp booster at the base of the ariel was effected by water getting into it. I changed the whole ariel and works much better now. Still not as good as my old VW Golf was but better. My car is a 2001 for info. This seems to be a common issue on octavia's Bowders1
__________________ Skoda Octavia VRS - Mod's : BlueFlame Exhaust System Turbo back, Forge 007PDV, ABD Induction CAI, Remap, ECS N75 valve, Blue Silicon Hoses, Audi S3 Upper/Lower strut Braces, Whiteline Rear ARB, Weitec Hicon GT Coilovers, Audi RS4 18" Wheels, Polished Inlet manifold and Cam Cover, Poweflex Engine mount, Wishbone Bushes, ARB Bushes, SAT NAV install, Reversing Sensors, Bonnet Lifters, Seat Cupra R Splitter, Milotec Bumper Grills, Audi TT arch Mod, Airvent Boost gauge. to do FMIC..... |
| | #14 |
| Re: Mk1 vRS naff FM radio reception! Need help! The item shown above is a power injector unit, not an amplifier - the amp can be found in the base of the aerial mount of the car. |
| | #15 |
| Briskodian Join Date: Dec 2006 Location: Telford Shropshire
| Re: Mk1 vRS naff FM radio reception! Need help! Did Skoda eventually rectify this problem with the mk1? I ask this because I previously owned a 52 plate vrs and the radio was useless. Now with the 04 plate the radio is so much better can pick up weaker signals much further away. |
| | #16 |
| Re: Mk1 vRS naff FM radio reception! Need help! Sounds like the aerial as I've already got one of those fitted, bugger!!!
| | #17 |
| Here's Johnny ! Join Date: Nov 2004 Location: Edinburgh
| Re: Mk1 vRS naff FM radio reception! Need help! My reception was fine until i changed to a smaller ariel. Now i cant find the original to put back on ! ![]() |
| | #18 |
| Briskodian Join Date: Aug 2006
| Re: Mk1 vRS naff FM radio reception! Need help! Will one of these improve am reception as well as fm? My FM is ok, but could be a lot better, and the am stuff is useless, just a load of buzzing. Not that bothered but sometimes useful for a bit of sport commentary! When wiring, does it need to be connected to the 'switched' live or the 'permanent' live? I would assume 'switched' as this will be when it needs the power to go to the amplifier? Is it as simple as wiring this into that part of the wiring loom? ![]() Thanks. |
| | #19 | |
This is the one I got: Find New VAG Aerial Booster Amplified Antenna Lead VW Cars on eBay within, Terminals Cabling, In-Car Entertainment GPS, Cars, Parts Vehicles (end time 07-Nov-07 20:03:40 GMT) | |
| | #20 |
| Re: Mk1 vRS naff FM radio reception! Need help! Has anyone changed the base unit for the aerial? I have noticed that the radio is starting to get a bit crackerly over the last few weeks, so I am wondering if my base has started to take in water.... |
| | #21 | |
| Stream Radio Reception | Toneboy | Octavia II | 80 | 16-12-2007 11:22 |
| radio reception | graememac | ICE, Security and Insurance | 11 | 22-09-2006 08:43 |
| Radio reception on Octy vRS symphony H/U | VRSPhil | ICE, Security and Insurance | 1 | 29-07-2006 15:59 |
| Poor radio reception | Rastanking | ICE, Security and Insurance | 8 | 22-06-2006 23:47 |
| Octy VRS radio reception | nealmarin | ICE, Security and Insurance | 8 | 09-02-2006 13:33 |
