This is a discussion on Mk1 vrs rear wheel bearing within the Octavia I forums, part of the Skoda Model Discussion Area category; What's the deal with changing one, is it easy, will I need any special tools? Cheers guys & gals....
| Briskodian Join Date: Apr 2007
| What's the deal with changing one, is it easy, will I need any special tools? Cheers guys & gals. ![]() |
Images: 2 Thanks: 22
| Re: Mk1 vrs rear wheel bearing Nothing too special except a big socket (30mm iirc) and a big torque wrench.
| Need more power Join Date: Feb 2007 Location: Driffield, Good old yorkshire
| Re: Mk1 vrs rear wheel bearing I think you may need a two or 3 pronged puller to pull the hub off and then to pull the bearing off the shaft according to haynes. |
| Re: Mk1 vrs rear wheel bearing Normally they knock off and should come off complete.
