This is a discussion on Mpg on 18's within the Octavia I forums, part of the Skoda Model Discussion Area category; Since fitting 18's to my Octy Vrs I have noticed a reduction in mpg. I was getting around 31mpg (mixed ...
| Briskodian Join Date: Sep 2004 Location: High Peak
| Mpg on 18's Since fitting 18's to my Octy Vrs I have noticed a reduction in mpg. I was getting around 31mpg (mixed driving) but I now get around 26mpg for the exact same journey. Obviously the new alloys have come with new tyres Federal SS595ZR 225/45/18 so that would account for some reduction in mpg but I wasn't expecting a 5mpg deficit! Is this normal? Oh and should I have the car tracking re-checked? Thx in advance.
__________________ '04 Silver Octy vRS - Revo 4bar, Miltek SS, Mitek Downpipe, 100cel CAT, RS6 18" Alloys, Forge 007p, ABD lan pipe/green filter, Samco TIP, Autogauge Boost,Oil temp, Oil Pressure gauges, ESP, Xenons, RS3 upper & lower braces |
| Briskodian Join Date: Mar 2005 Location: Newcastle
| hmmm, think you might have to take into account that with the bigger wheels the computer is reading the speed differently and thus calculating the MPG wrong. Although it will be a little worse because of the size of the wheels its turning, losing more than 10% economy seems a little "unreal" ?!?!?
__________________ Paul, its a Skoda I know |
Images: 5 Thanks: 76
| The ne tyre size is 3.61% bigger, so having a 10% drop is a little odd. Do they have stickier tyres on than what you were running originally? I know going from 185/60 R14 to 205/40 R17, I got quite a drop in economy, in the region of 10-15%, and I had to pin 3% on the bigger size, and the rest on the Toyo Proxes being stickier than conti eco-contact tyres. ![]()
__________________ Jason - Mongrel owner! WOOOOF! Grrrrr Custom Fabia Bonnet Lifter Kits - £45! Click Me. Cheesy bonnet lifter video to "raise me up" http://www.youtube.com/watch?v=hMnGECEi5Oc See the mongrel's 260bhp Dyno Video! |
| Briskodian Join Date: May 2003 Location: North East
| There should be no difference as the rolling radius should be within +/- 2.5% of the original. Why have you gone for 45 section tyres though? I'm running 18's but am using 40 section... |
| Sorry, they are 40 section not 45 as stated . The 'old' tyres were the standard contis on the octy vrs but had about 2mm left when removed so I guess you could say that the new tyres are stickier! I experimented this morning by 'freewheeling' to see if the speed reduction was greater than normal and sure enough it is therefore I would assume I would have to give it more boot (thereby less mpg) to attain the same acceleration as before?
| Bigger cross-section therefore more drag?
| Briskodian Join Date: Aug 2003 Location: Essex
| Had no problems and no difference when I went to 225/40/18 RS4s over 10,000 miles
__________________ Black '53' Octy vRS - 18inch RS4 in Graphite Grey - Colour coded front grill - Samco TIP - Carbonio filter - OBD Remap by Mike @ Impossible Performance Coming before the end of Jan 2007 - Audi A4 Cabriolet - Ebony Black- 18inch RS4 Wheels - Red Knappa leather |
| Briskodian Join Date: Mar 2005 Location: South Wales
| I too have suffered this since fitting 8x18 RS6 replicas with the 225/40/18 Federal SS595. I have also noticed a slight degredation in acceleration (which is fair enough) The difference in rolling radius between the 205/50/17 Conti and the 225/40/18 Federal is 0.1% At the end of the day a 5/6mpg drop from 30mpg is more like 20% which is not practical when you thing about it, as every journey is costing 20% more with these 18s. Therefore I will be selling mine. I have read on here that these cheap wheels are heavy, and I noticed this when fitting, however I will be weighing them against the standard wheels soon. I also think that it is this extra weight that has killed my gearbox... |
| Briskodian Join Date: Jun 2005 Location: North East UK
| I have recently fitted a set of 18" OZ vello 5 spokes to my vRS. I have not noticed any reduction in fuel economy - I will see what i get from a full tank next time I fill up. With regards to acceleration there does seem to be a slight loss, particularly in 1st, but after this things seem to be fine. Maybe a re-map will help? Looking at my speedo now I am able to reach 70mph in 2nd without hitting the rev limiter. The wheels I have fitted if anything seem lighter than the 17" originals. Was going to get RS4 replicas but was wary about the extra weight. |
| | #10 |
| | #11 |
| Briskodian Join Date: Nov 2003 Location: Notts, UK
| I was looking through a Mondeo brochure the other day. There was around a 5-10% difference in economy between the Zetec and Zetec-S. Only difference is a slight body kit and the change from 16" to 18" alloys. Cheers Lee
__________________ Another Ex-Scooby owner. Mondeo TDCi 130 6 Speed Ghia, Octavia 1.9TDi Elegance (Now Sold), Fabia 1.9TDi Comfort and Felicia 1.9D GLi |
| | #12 |
| Briskodian Join Date: Nov 2003 Location: Hampshire
| Is this reduction in ecomony not chiefly due to the fact unless you spend loads of pennies, 18" rims are significantly heavier in weight compared to 17" with the small sidewall profile making limited difference in tyre weight saving? Am I not right in thinking that unsprung weight (e.g. wheel, trye and hub/brakes etc) make double the difference in terms of performance deficit compared to sprung weight? Lee
__________________ Lee Want to be carbon-neutral while driving? Hold your breath! |
| | #13 | |
| Quote:
As promised I weighed my wheels when I swopped back to the originals this week: OEM 'Spider' 7x17 with 205/50 Continental SportContact : 18kgs approx RS6 Replica 8x18 with 225/40/18 Federal SS595 : 24kgs approx Thats a massive 6kgs per wheel extra unsprung and rotational weight. since going back to the 17s, the car is feels much more responsive and agile, and the all important mpg is back upto 30ish rather than the low 20s. Yes you have to pay around £500 extra for lightweight wheels from the likes of OZ etc, but based on my experience of a 20% loss of economy, they could pay for themselves in 25,000 miles, and you would retain the acceleration and agility of the 17" wheels. E.g. 8x18 OZ Supperleggeras with 225/40/18 would weigh in at around 17kgs a corner, which is lighter than the standard 17s, which may cancel out the wider tyres effect on mpg... I'll let you know... Last edited by Beef; 21-07-2005 at 10:27. | |
| | #14 |
| So if I were to ditch my 18" Team Dymanic Motorsports in favour of OEM 17" rims, my car too would go like pooh off a shovel (which it does already), erm... so, go like the an extra big dollop of pooh off a shovel?
| | #15 |
| Only if you can get the 17 oems (with contis) to stick as well as aftermarket tyres (proxes etc)....there is also cornering to think of. Larger sidewall = less stability. Must admit I noticed a little decrease on 0-60 performance, just didn't feel as 'brisk', saying that I dont get as much wheel spin (with esp off) with the 18's as I did with the 17s so that will no doubt counter the effects. I think it was Continental who ironicly said - "Power is nothing without control"! (maybe it was pirelli).
| | #16 |
| Briskodian Join Date: Mar 2004 Location: Republic of Ireland
| Had my car dyno'd with 18's on and the loss in tranmission was up 6hp ![]() |
| | #17 | |
| Briskodian Join Date: Jan 2005 Location: United Arab Emirates
| Quote:
__________________ Milton Kyvernitis Private Government | |
| Average MPG in the time you've owned your Fabia vRS... | rob1sp | General Car Chat | 52 | 16-04-2005 12:37 |
| MPG Computer - New Octavia | BowsG | Octavia II | 3 | 10-02-2005 21:55 |
| Does a remap increase MPG ? | Chavyboy | General Car Chat | 25 | 06-10-2004 11:39 |
| where's my MPG gone! | andysteele | Fabia I | 38 | 25-09-2004 00:25 |
| Fabia vRS: An averae 67.9 MPG from an 88 Mile journey!!! Beat that! | waynef | Maintenance & Performance | 16 | 03-06-2004 22:23 |
