This is a discussion on MPG read out within the Octavia I forums, part of the Skoda Model Discussion Area category; Does the ECU calculate the actual MPG by the rate of dosing against speed, or does it simply compare speed ...
| Briskodian Join Date: Nov 2003 Location: Hampshire
| MPG read out Does the ECU calculate the actual MPG by the rate of dosing against speed, or does it simply compare speed with time? I ask this because if the injectors are changed, to provide greater flow, does this mean the dash read out is giving higher than actual MPG? Thanks
__________________ Lee Want to be carbon-neutral while driving? Hold your breath! |
| Re: MPG read out I think it is done such that this would mean the MPG shown is higher than the true value.
